I have a problem that my microphone has a lot of noise while speaking. But I found out that the pulseaudio sampling rate was too low and therefore I tried to change the settings of the samling rate by changing the value from 44100 to 48000.
But when I kill and restart pulseaudio and also then try to make a audio record it shows me that it uses still the old settings (and the noise is still there):
pulseaudio -k
pulseaudio --start
arecord -f cd -d 5 test_mic.wav
result:
Recording WAVE ‘test_mic.wav’ : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
This means that the changes of the daemon.conf in (/etc/pulse/) did not get applied even if the .conf file did not change.
Any ideas what is wrong or maybe if there are other .conf files that override mines?
That’s probably not what it means - and
… you did change it …
I don’t know how to check the current, now changed, configuration - to see whether it’s valid or contains errors -
but it should be easy to find out.
Without knowing anything about recording
this looks like you are recording through alsa (you use arecord)
when you probably should or would want to use pulseaudio, which you just reconfigured. parec
would be the command, I guess
for example:
Command arecord records audio from ALSA and would not be affected by settings configured in PulseAudio
Option -f sets the recording format in ALSA as explained in manpage man arecord
-f --format=FORMAT
Sample format
Recognized sample formats are: S8 U8 S16_LE S16_BE U16_LE U16_BE
S24_LE S24_BE U24_LE U24_BE S32_LE S32_BE U32_LE U32_BE FLOAT_LE
FLOAT_BE FLOAT64_LE FLOAT64_BE IEC958_SUBFRAME_LE IEC958_SUB‐
FRAME_BE MU_LAW A_LAW IMA_ADPCM MPEG GSM SPECIAL S24_3LE S24_3BE
U24_3LE U24_3BE S20_3LE S20_3BE U20_3LE U20_3BE S18_3LE S18_3BE
U18_3LE
Some of these may not be available on selected hardware
The available format shortcuts are:
-f cd (16 bit little endian, 44100, stereo) [-f S16_LE -c2 -r44100]
-f cdr (16 bit big endian, 44100, stereo) [-f S16_BE -c2 -r44100]
-f dat (16 bit little endian, 48000, stereo) [-f S16_LE -c2 -r48000]
If no format is given U8 is used.
To check PulseAudio configuration use this command:
pulseaudio --dump-conf
Changes made to settings in /etc/pulse/daemon.conf might not be effective if the semi-colon comment tag at the start of each line is not removed
man pulse-deamon.conf
The configuration file is a simple collection of variable declarations.
If the configuration file parser encounters either ; or # it ignores
the rest of the line until its end.
PulseAudio might not restart and load new settings correctly if the daemon is killed with pulseaudio -k .
Only one command is needed to correctly restart PulseAudio
