Since the stable update 2020-11-04 there’s no airplay / RAOP sink available anymore. It might have to do with the pulseaudio upgrade to v13.99.3 that was included in that update, although on gitlab (Regression: Apple airplay device not detected anymore since 13.99.3 (#1033) · Issues · PulseAudio / pulseaudio · GitLab) I was told there weren’t any major changes to RAOP. I didn’t change any settings.
Any hints as to what to look into? Thanks!
pa-info output is:
pulseaudio_ps_do
gdm 1407 0.1 0.0 686108 12572 ? S<sl 18:12 0:00 /usr/bin/pulseaudio --daemonize=no --log-target=journal
daniel 1764 0.0 0.0 1211088 14024 ? S<sl 18:12 0:00 /usr/bin/pulseaudio --daemonize=no --log-target=journal
daniel 4701 0.0 0.0 3080 840 pts/0 S+ 18:20 0:00 grep pulseaudio
which pulseaudio
/usr/bin/pulseaudio
pidof pulseaudio
1764 1407
pulseaudio --version
pulseaudio 13.99.3
pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 34
Server Protocol Version: 34
Is Local: yes
Client Index: 14
Tile Size: 65472
User Name: daniel
Host Name: daniel-hpenvyx360
Server Name: pulseaudio
Server Version: 13.99.3
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
Default Source: alsa_output.pci-0000_00_1f.3.analog-stereo.monitor
Cookie: 4b89:9ec8
pactl list
Module #0
Argument:
Usage counter: n/a
Properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "13.99.3"
Module #1
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the volume/mute/device state of streams"
Module #2
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore profile of cards"
Module #3
Argument:
Usage counter: n/a
Properties:
module.description = "Augment the property sets of streams with additional static information"
Module #4
Argument:
Usage counter: n/a
Properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
Module #5
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available audio hardware and load matching drivers"
Module #6
Argument: device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
Usage counter: 0
Properties:
module.description = "ALSA Card"
Module #7
Argument: channels=2
Usage counter: n/a
Properties:
module.description = "Adds JACK sink/source ports when JACK is started"
Module #8
Argument:
Usage counter: n/a
Properties:
module.author = "Frédéric Dalleau, Pali Rohár"
module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
Module #9
Argument:
Usage counter: n/a
Properties:
module.author = "João Paulo Rechi Vita"
module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
Module #10
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
Module #11
Argument:
Usage counter: n/a
Properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
Module #12
Argument:
Usage counter: n/a
Properties:
module.description = "Native protocol (UNIX sockets)"
Module #13
Argument:
Usage counter: n/a
Properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
Module #14
Argument:
Usage counter: n/a
Properties:
module.author = "Colin Guthrie"
module.description = "mDNS/DNS-SD Service Discovery of RAOP devices"
Module #15
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the default sink and source"
Module #16
Argument:
Usage counter: n/a
Properties:
module.description = "Hält stets ein Ziel geladen, selbst wenn dies ein Null-Ziel ist"
Module #17
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically set device of streams based on intended roles of devices"
Module #18
Argument:
Usage counter: n/a
Properties:
module.description = "When a sink/source is idle for too long, suspend it"
Module #19
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each ConsoleKit session of this user"
Module #20
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each login session of this user"
Module #21
Argument:
Usage counter: n/a
Properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Module #22
Argument:
Usage counter: n/a
Properties:
module.description = "Mute & cork streams with certain roles while others exist"
Module #23
Argument:
Usage counter: n/a
Properties:
module.description = "Detect when various filters are desirable"
Module #24
Argument:
Usage counter: n/a
Properties:
module.description = "Load filter sinks automatically when needed"
Module #25
Argument: display=:1 xauthority=/run/user/1000/gdm/Xauthority
Usage counter: n/a
Properties:
module.description = "X11 credential publisher"
Module #26
Argument: display=:1 xauthority=/run/user/1000/gdm/Xauthority session_manager=local/daniel-hpenvyx360:@/tmp/.ICE-unix/1744,unix/daniel-hpenvyx360:/tmp/.ICE-unix/1744
Usage counter: n/a
Properties:
module.description = "X11 session management"
Sink #0
State: SUSPENDED
Description: Internes Audio Analog Stereo
Driver: module-alsa-card.c
Sample Specification: s16le 2ch 48000Hz
Owner Module: 6
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_00_1f.3.analog-stereo.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC285 Analog"
alsa.id = "ALC285 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xb431c000 irq 152"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "02c8"
device.string = "front:0"
device.buffering.buffer_size = "384000"
device.buffering.fragment_size = "192000"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Internes Audio Analog Stereo"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Ports:
analog-output-speaker: Speakers (type: Speaker, priority: 10000, availability group: Legacy 2)
analog-output-headphones: Headphones (type: Headphones, priority: 9900, availability group: Legacy 3, not available)
Active Port: analog-output-speaker
Formats:
pcm
Source #0
State: SUSPENDED
Description: Monitor of Internes Audio Analog Stereo
Owner Module: 6
Mute: no
balance 0.00
Monitor of Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = "Monitor of Internes Audio Analog Stereo"
device.class = "monitor"
alsa.card = "0"
device.bus = "pci"
device.string = "0"
Formats:
pcm
Client #0
Driver: module-systemd-login.c
Owner Module: 20
Properties:
application.name = "Login Session 3"
systemd-login.session = "3"
Client #3
Driver: module-x11-xsmp.c
Owner Module: 26
Properties:
application.name = "XSMP Session on gnome-session as 104b26898146351c22160485557282364800000017440058"
xsmp.vendor = "gnome-session"
xsmp.client.id = "104b26898146351c22160485557282364800000017440058"
Client #4
Driver: protocol-native.c
Owner Module: 12
Properties:
application.name = "GNOME Shell Volume Control"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "34"
application.id = "org.gnome.VolumeControl"
application.icon_name = "multimedia-volume-control"
application.version = "3.38.1"
application.process.id = "1762"
application.process.user = "daniel"
application.process.host = "daniel-hpenvyx360"
application.process.binary = "gnome-shell"
application.language = "de_DE.UTF-8"
window.x11.display = ":1"
application.process.machine_id = "a05ecfba844d4e98a47fb1410cd993ec"
Client #5
Owner Module: 12
Properties:
application.name = "GNOME Volume Control Media Keys"
application.version = ""
application.process.id = "1954"
application.process.binary = "gsd-media-keys"
Client #7
Owner Module: 12
Properties:
application.name = "Firefox"
application.icon_name = "firefox"
application.version = "82.0.2"
application.process.id = "2346"
application.process.binary = "firefox"
Client #13
Owner Module: 12
Properties:
application.name = "Mutter"
Client #15
Owner Module: 12
Properties:
application.name = "pactl"
application.process.id = "4706"
application.process.binary = "pactl"
application.language = "C"
Sample #0
Volume: (invalid)
balance 0.00
Duration: 0.1s
Lazy: no
Filename: n/a
Properties:
media.role = "event"
event.description = "Klangereignis"
event.id = "bell-window-system"
media.name = "bell-window-system"
media.filename = "/usr/share//sounds/freedesktop/stereo/bell.oga"
Card #0
Owner Module: 6
Properties:
alsa.card = "0"
device.bus = "pci"
device.string = "0"
device.description = "Internes Audio"
Profiles:
input:analog-stereo: Analog Stereo-Eingabe (sinks: 0, sources: 1, priority: 65, available: no)
output:analog-stereo: Analog Stereo-Ausgabe (sinks: 1, sources: 0, priority: 6500, available: yes)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: no)
output:hdmi-stereo: Digital Stereo (HDMI)-Ausgabe (sinks: 1, sources: 0, priority: 5900, available: no)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI)-Ausgabe + Analog Stereo-Eingabe (sinks: 1, sources: 1, priority: 5965, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI)-Ausgabe (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI)-Ausgabe + Analog Stereo-Eingabe (sinks: 1, sources: 1, priority: 865, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI)-Ausgabe (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI)-Ausgabe + Analog Stereo-Eingabe (sinks: 1, sources: 1, priority: 865, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2)-Ausgabe (sinks: 1, sources: 0, priority: 5700, available: yes)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2)-Ausgabe + Analog Stereo-Eingabe (sinks: 1, sources: 1, priority: 5765, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2)-Ausgabe (sinks: 1, sources: 0, priority: 600, available: yes)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2)-Ausgabe + Analog Stereo-Eingabe (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2)-Ausgabe (sinks: 1, sources: 0, priority: 600, available: yes)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2)-Ausgabe + Analog Stereo-Eingabe (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3)-Ausgabe (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3)-Ausgabe + Analog Stereo-Eingabe (sinks: 1, sources: 1, priority: 5765, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3)-Ausgabe (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3)-Ausgabe + Analog Stereo-Eingabe (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3)-Ausgabe (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3)-Ausgabe + Analog Stereo-Eingabe (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4)-Ausgabe (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4)-Ausgabe + Analog Stereo-Eingabe (sinks: 1, sources: 1, priority: 5765, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4)-Ausgabe (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4)-Ausgabe + Analog Stereo-Eingabe (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4)-Ausgabe (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4)-Ausgabe + Analog Stereo-Eingabe (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5)-Ausgabe (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra4+input:analog-stereo: Digital Stereo (HDMI 5)-Ausgabe + Analog Stereo-Eingabe (sinks: 1, sources: 1, priority: 5765, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5)-Ausgabe (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra4+input:analog-stereo: Digital Surround 5.1 (HDMI 5)-Ausgabe + Analog Stereo-Eingabe (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5)-Ausgabe (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra4+input:analog-stereo: Digital Surround 7.1 (HDMI 5)-Ausgabe + Analog Stereo-Eingabe (sinks: 1, sources: 1, priority: 665, available: no)
off: Aus (sinks: 0, sources: 0, priority: 0, available: yes)
Active Profile: output:analog-stereo
Ports:
analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71+input:analog-stereo, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1+input:analog-stereo, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2+input:analog-stereo, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3+input:analog-stereo, output:hdmi-stereo-extra4+input:analog-stereo, output:hdmi-surround-extra4+input:analog-stereo, output:hdmi-surround71-extra4+input:analog-stereo
analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability group: Legacy 2)
Properties:
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
Part of profile(s): output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71, output:hdmi-surround71+input:analog-stereo
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 5, available)
Properties:
device.product.name = "EV2450"
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1, output:hdmi-surround71-extra1+input:analog-stereo
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 6, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2, output:hdmi-surround71-extra2+input:analog-stereo
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 7, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3, output:hdmi-surround71-extra3+input:analog-stereo
hdmi-output-4: HDMI / DisplayPort 5 (type: HDMI, priority: 5500, latency offset: 0 usec, availability group: Legacy 8, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra4, output:hdmi-stereo-extra4+input:analog-stereo, output:hdmi-surround-extra4, output:hdmi-surround-extra4+input:analog-stereo, output:hdmi-surround71-extra4, output:hdmi-surround71-extra4+input:analog-stereo
cat /etc/pulse/daemon.conf
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out. Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; remixing-produce-lfe = no
; remixing-consume-lfe = no
; lfe-crossover-freq = 0
; flat-volumes = no
; rescue-streams = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
cat /etc/pulse/client.conf
## Configuration file for PulseAudio clients. See pulse-client.conf(5) for
## commenting.
; default-sink =
; default-source =
; default-server =
; default-dbus-server =
autospawn = no
; autospawn = yes
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; auto-connect-localhost = no
; auto-connect-display = no
cat /etc/pulse/default.pa
#!/usr/bin/pulseaudio -nF
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
cat /etc/pulse/system.pa
# This startup script is used only if PulseAudio is started in system
# mode.
.else
### Use the static hardware detection module (for systems that lack udev/hal support)
.endif
.endif
### during runtime
ls -alt /dev/snd/*
crw-rw----+ 1 root audio 116, 2 Nov 8 18:19 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116, 3 Nov 8 18:12 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 8 Nov 8 18:12 /dev/snd/pcmC0D10p
crw-rw----+ 1 root audio 116, 7 Nov 8 18:12 /dev/snd/pcmC0D9p
crw-rw----+ 1 root audio 116, 6 Nov 8 18:12 /dev/snd/pcmC0D8p
crw-rw----+ 1 root audio 116, 5 Nov 8 18:12 /dev/snd/pcmC0D7p
crw-rw----+ 1 root audio 116, 4 Nov 8 18:12 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116, 11 Nov 8 18:12 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 9 Nov 8 18:12 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 10 Nov 8 18:12 /dev/snd/hwC0D2
crw-rw----+ 1 root audio 116, 33 Nov 8 18:12 /dev/snd/timer
crw-rw----+ 1 root audio 116, 1 Nov 8 18:12 /dev/snd/seq
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Nov 8 18:12 .
drwxr-xr-x 3 root root 300 Nov 8 18:12 ..
lrwxrwxrwx 1 root root 12 Nov 8 18:12 pci-0000:00:1f.3 -> ../controlC0
lsof /dev/snd/*
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
pulseaudi 1764 daniel 17u CHR 116,11 0t0 420 /dev/snd/controlC0
pulseaudi 1764 daniel 24u CHR 116,11 0t0 420 /dev/snd/controlC0
jacks_do
card=0
numid=40,iface=CARD,name='HDMI/DP,pcm=10 Jack'
; type=BOOLEAN,access=r-------,values=1
: values=off
numid=16,iface=CARD,name='HDMI/DP,pcm=3 Jack'
: values=off
numid=22,iface=CARD,name='HDMI/DP,pcm=7 Jack'
: values=on
numid=28,iface=CARD,name='HDMI/DP,pcm=8 Jack'
: values=off
numid=34,iface=CARD,name='HDMI/DP,pcm=9 Jack'
: values=off
numid=12,iface=CARD,name='Headphone Jack'
: values=off
numid=11,iface=CARD,name='Mic Jack'
: values=off
numid=13,iface=CARD,name='Speaker Phantom Jack'
: values=on
aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=PCH
HDA Intel PCH, ALC285 Analog
Default Audio Device
front:CARD=PCH,DEV=0
Front output / input
surround21:CARD=PCH,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
hdmi:CARD=PCH,DEV=0
HDA Intel PCH, HDMI 0
HDMI Audio Output
hdmi:CARD=PCH,DEV=1
HDA Intel PCH, HDMI 1
HDMI Audio Output
hdmi:CARD=PCH,DEV=2
HDA Intel PCH, HDMI 2
HDMI Audio Output
hdmi:CARD=PCH,DEV=3
HDA Intel PCH, HDMI 3
HDMI Audio Output
hdmi:CARD=PCH,DEV=4
HDA Intel PCH, HDMI 4
HDMI Audio Output
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
arecord -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
sysdefault:CARD=PCH
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
alsa_info_do
dmesg: read kernel buffer failed: Operation not permitted
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Sun Nov 8 17:20:03 UTC 2020
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: HP
Product Name: HP ENVY x360 Convertible 15-dr1xxx
Product Version: Type1ProductConfigId
Firmware Version: F.06
System SKU: 8FB66EA#ABD
Board Vendor: HP
Board Name: 86B2
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/ELAN2514:00/status 15
/sys/bus/acpi/devices/HPIC0003:00/status 15
/sys/bus/acpi/devices/HPQ6001:00/status 15
/sys/bus/acpi/devices/HPQ6007:00/status 15
/sys/bus/acpi/devices/INT0E0C:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT33D2:00/status 11
/sys/bus/acpi/devices/INT33D3:00/status 15
/sys/bus/acpi/devices/INT33D5:00/status 15
/sys/bus/acpi/devices/INT3400:00/status 15
/sys/bus/acpi/devices/INT3403:00/status 15
/sys/bus/acpi/devices/INT3403:01/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INT34BB:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 15
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/LNXPOWER:05/status 1
/sys/bus/acpi/devices/LNXVIDEO:01/status 15
/sys/bus/acpi/devices/MSFT0101:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0B00:00/status 15
/sys/bus/acpi/devices/PNP0C02:00/status 3
/sys/bus/acpi/devices/PNP0C02:01/status 3
/sys/bus/acpi/devices/PNP0C02:05/status 3
/sys/bus/acpi/devices/PNP0C09:00/status 15
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PRP00001:00/status 11
/sys/bus/acpi/devices/SYNA328C:00/status 15
/sys/bus/acpi/devices/USBC000:00/status 15
/sys/bus/acpi/devices/device:17/status 15
!!Kernel Information
Kernel release: 5.4.74-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.4.74-1-MANJARO
Library version: 1.2.4
Utilities version: 1.2.4
!!Loaded ALSA modules
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
!!PCI Soundcards installed in the system
00:1f.3 Multimedia audio controller [0401]: Intel Corporation Device [8086:02c8]
Subsystem: Hewlett-Packard Company Device [103c:86b2]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
dmic_detect : N
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 0
power_save_controller : N
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC285
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0285
Subsystem Id: 0x103c86b2
Revision Id: 0x100002
No Modem Function Group found
Default PCM:
rates [0x560]: 44100 48000 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 D3cold CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=3, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Device: name="ALC285 Analog", type="Audio", device=0
Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
Amp-Out vals: [0x00 0x00]
Converter: stream=1, channel=0
PCM:
rates [0x40]: 48000
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Speaker Playback Volume", index=0, device=0
Amp-Out vals: [0x57 0x57]
PCM:
rates [0x40]: 48000
formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x411: Stereo
Converter: stream=0, channel=0
PCM:
rates [0x40]: 48000
formats [0x1]: PCM
Node 0x07 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
Amp-In vals: [0x97 0x97]
SDI-Select: 0
PCM:
rates [0x40]: 48000
formats [0x1]: PCM
Connection: 1
0x24
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In vals: [0x27 0x27]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0d [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0e [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Amp-In vals: [0x00 0x00]
Pincap 0x00000020: IN
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x13 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Pin Default 0x40000000: [N/A] Line Out at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0x0, Sequence = 0x0
Pin-ctls: 0x00:
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x80 0x80]
Pincap 0x00010014: OUT EAPD Detect
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Unsolicited: tag=00, enabled=0
Connection: 1
0x02
Node 0x15 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Pincap 0x0000001c: OUT HP Detect
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Connection: 2
0x02* 0x03
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Speaker Playback Switch", index=0, device=0
Pin Default 0x90170180: [Fixed] Speaker at Int N/A
Conn = Analog, Color = Unknown
DefAssociation = 0x8, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 3
0x02 0x03* 0x06
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Pincap 0x00000024: IN Detect
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Control: name="Mic Boost Volume", index=0, device=0
Pincap 0x00003724: IN Detect
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x03a11040: [Jack] Mic at Ext Left
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=02, enabled=1
Node 0x1a [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Misc = NO_PRESENCE
Pin-ctls: 0x00: VREF_HIZ
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pincap 0x00013734: IN OUT EAPD Detect
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Connection: 2
0x02* 0x03
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x40600001: [N/A] Modem Line at Ext N/A
DefAssociation = 0x0, Sequence = 0x1
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400501: Stereo
Pincap 0x00000010: OUT
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=142
Node 0x21 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x03211020: [Jack] HP Out at Ext Left
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP
Unsolicited: tag=01, enabled=1
Connection: 2
0x02* 0x03
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 5
0x19 0x1a 0x1b 0x1d 0x13
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 5
0x19 0x1a 0x1b 0x1d 0x12
Node 0x24 [Audio Selector] wcaps 0x300101: Stereo
Connection: 3
0x12* 0x13 0x18
Codec: Intel Kabylake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086280b
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled KAE
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1a]: 16 24 32
formats [0x5]: PCM AC3
Power states: D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pincap 0x0b000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x00:
Devices: 0
Connection: 0
In-driver Connection: 3
0x02 0x03 0x04
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x40: OUT
Devices: 0
Connection: 3
0x02 0x03* 0x04
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
0x02 0x03 0x04
Node 0x08 [Vendor Defined Widget] wcaps 0xf00000: Mono
--endcollapse--
!!ALSA Device nodes
/dev/snd/by-path:
total 0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC285 Analog [ALC285 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card hw:0 'PCH'/'HDA Intel PCH at 0xb431c000 irq 152'
Mixer name : 'Realtek ALC285'
Components : 'HDA:10ec0285,103c86b2,00100002 HDA:8086280b,80860101,00100000'
Controls : 51
Simple ctrls : 12
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 39 [62%] [12.00dB] [on]
Front Right: Capture 39 [62%] [12.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface MIXER
name 'Headphone Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -6525
dbvalue.1 -6525
control.2 {
iface MIXER
name 'Headphone Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Speaker Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Speaker Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Auto-Mute Mode'
value Enabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.6 {
iface MIXER
name 'Capture Volume'
value.0 39
value.1 39
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 1200
dbvalue.1 1200
control.7 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.8 {
iface MIXER
name 'Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.9 {
iface MIXER
name 'Master Playback Volume'
value 87
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
control.10 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.11 {
iface CARD
name 'Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.12 {
iface CARD
name 'Headphone Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.13 {
iface CARD
name 'Speaker Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.14 {
iface PCM
name 'Playback Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.15 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.16 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.17 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.18 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.19 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.20 {
iface MIXER
name 'IEC958 Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.21 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.22 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.23 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.24 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.25 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.26 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.27 {
iface PCM
device 7
name ELD
value '1000070066160001000000000000000015c33125455632343530090707000000'
comment {
type BYTES
count 32
control.28 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.29 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.30 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.31 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.32 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.33 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.34 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.35 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.36 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.37 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.38 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.39 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.40 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.41 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.42 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.43 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.44 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.45 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.46 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.47 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.48 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.49 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.50 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.51 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
--endcollapse--
!!All Loaded Modules
ac
ac97_bus
acpi_thermal_rel
aesni_intel
af_alg
agpgart
ahci
algif_hash
algif_skcipher
atkbd
battery
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cfg80211
cmac
cmdlinepart
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cros_ec
cros_ec_ishtp
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
evdev
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_multitouch
hid_sensor_accel_3d
hid_sensor_gyro_3d
hid_sensor_hub
hid_sensor_iio_common
hid_sensor_incl_3d
hid_sensor_magn_3d
hid_sensor_rotation
hid_sensor_trigger
hp_accel
hp_wireless
hp_wmi
i2c_algo_bit
i2c_hid
i2c_i801
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
industrialio
industrialio_triggered_buffer
input_leds
input_polldev
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_hid
intel_ish_ipc
intel_ishtp
intel_ishtp_hid
intel_ishtp_loader
intel_lpss
intel_lpss_pci
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_spi
intel_spi_pci
intel_uncore
intel_wmi_thunderbolt
ip_tables
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kfifo_buf
kvm
kvm_intel
ledtrig_audio
libahci
libarc4
libata
libps2
lis3lv02d
loop
mac80211
mac_hid
mbcache
mei
mei_hdcp
mei_me
memstick
mmc_core
mousedev
msr
mtd
nls_cp437
nls_iso8859_1
ofpart
pcspkr
processor_thermal_device
psmouse
rapl
rfcomm
rfkill
rng_core
rtsx_pci
rtsx_pci_ms
rtsx_pci_sdmmc
scsi_mod
serio
serio_raw
sg
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_nhlt
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_sof
snd_sof_intel_byt
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_intel_ipc
snd_sof_pci
snd_sof_xtensa_dsp
snd_timer
soc_button_array
soundcore
sparse_keymap
spi_nor
squashfs
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
typec
typec_ucsi
ucsi_acpi
uinput
usbhid
vboxdrv
vboxguest
vboxnetadp
vboxnetflt
vboxsf
vfat
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_hcd
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x12 0x411111f0
0x13 0x40000000
0x14 0x411111f0
0x16 0x411111f0
0x17 0x90170180
0x18 0x411111f0
0x19 0x03a11040
0x1a 0x411111f0
0x1b 0x411111f0
0x1d 0x40600001
0x1e 0x411111f0
0x21 0x03211020
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D2/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
