I’ve previously had no problems, but since a recent update to pulseaudio 14.2, the alsamixer auto-mute setting seems to be getting disabled every time I remove my headphones from the 1.8mm jack port.
This only occurs on disconnect. On reconnect, the automute function stays disabled and I then have sound from both my speakers and my headphones (which I don’t want) and the only way I can correct this is to go into alsamixer and re-enable it. (sudo alsactl store does not work)
I’m thinking this is either pulseaudio or KDE, but I can’t figure what config file to change in what manner to make this stop.
PulseAudio Output - Pastebin.com (Pulse Audio)
http://alsa-project.org/db/?f=110609f443f0034e19f912aa01c29f91186766ee (Alsa)
