Pulse -> Pipewire: How to Loopback Line-In Only?
I am trying to get my line-in separated from the rest of my rear audio ports so that I can loopback only that port’s audio when I plug-in another audio source I want to listen to.
Currently Line-in has my phone’s audio jack connected. I want to loopback that port to capture its audio and play it through my speakers or headphones. Timely notifications are important and I don’t want the notification or ringtone leaking into my mic during zoom meetings.
Getting loopback turned on is super easy with alsamixer, but I ultimately want to enable loopback for only a specific port on the card instead of all the ports.
I tried How to separe ports into different devices on pulseaudio? - #4 by nikgnomic and Listen to line-in while keeping a working mic - #4 by nikgnomic from a few forum searches.
I tried to make a card profile like output:analog-stereo+input:analog-stereo+input:analog-linein with a custom analog-linein mapping but the configuration kept giving failed initialization errors and returning to the default so I reverted my changes.
I added the following to /etc/pulse/default.pa
default.pa
#hw:1 for 1080ti
#3 for DVI-D-0/TSBA
#7 for DP-0/LGEP
#8 for DP-3/ASUS
load-module module-alsa-sink device=“hw:1,3” format=s16 rate=48000 sink_name=1080ti_dvi_0 sink_properties=device.description=DVI
#load-module module-alsa-sink device=“hw:1,7” format=s16 rate=48000 sink_name=1080ti_dp_0 sink_properties=device.description=DP0
load-module module-alsa-sink device=“hw:1,8” format=s16 rate=48000 sink_name=1080ti_dp_3 sink_properties=device.description=DP3
The rest of it is unchanged from default.
Relevant hardware info:
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC1220 Analog [ALC1220 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC1220 Digital [ALC1220 Digital]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 0/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 0/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 12: HDMI 6 [HDMI 6]
Subdevices: 1/1
amixer --card=0
amixer --card=0
Simple mixer control ‘Master’,0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 63 [72%] [-18.00dB] [on]
Simple mixer control ‘Headphone’,0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [on]
Front Right: Playback 0 [0%] [-65.25dB] [on]
Simple mixer control ‘PCM’,0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control ‘Front’,0
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control ‘Front Mic’,0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [on]
Front Right: Playback 0 [0%] [-34.50dB] [on]
Simple mixer control ‘Front Mic Boost’,0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control ‘Surround’,0
Mono:
Simple mixer control ‘Center’,0
Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control ‘LFE’,0
Simple mixer control ‘Line’,0
Mono:
Front Left: Playback 31 [100%] [12.00dB] [on]
Front Right: Playback 31 [100%] [12.00dB] [on]
Simple mixer control ‘Line Boost’,0
Limits: 0 - 3
Simple mixer control ‘IEC958’,0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control ‘IEC958 Default PCM’,0
Simple mixer control ‘Capture’,0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 55 [87%] [24.00dB] [on]
Front Right: Capture 55 [87%] [24.00dB] [on]
Simple mixer control ‘Capture’,1
Front Left: Capture 0 [0%] [-17.25dB] [off]
Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control ‘Auto-Mute Mode’,0
Capabilities: enum
Items: ‘Disabled’ ‘Enabled’
Item0: ‘Enabled’
Simple mixer control ‘Input Source’,0
Capabilities: cenum
Items: ‘Front Mic’ ‘Rear Mic’ ‘Line’
Item0: ‘Line’
Simple mixer control ‘Input Source’,1
Capabilities: cenum
Item0: ‘Front Mic’
Simple mixer control ‘Loopback Mixing’,0
Capabilities: enum
Item0: ‘Disabled’
Simple mixer control ‘Rear Mic’,0
Mono:
Simple mixer control ‘Rear Mic Boost’,0
Limits: 0 - 3
Forgot to include my capture options.
arecord -l
**** List of CAPTURE Hardware Devices ****
Subdevices: 0/1
card 0: PCH [HDA Intel PCH], device 2: ALC1220 Alt Analog [ALC1220 Alt Analog]
Subdevices: 1/1
I’m certain I can capture at least 2 of my 3 input ports (rear mic, rear line-in, front mic), just not sure how to setup the card profile or configuration.
Also, I found that plugging in my headphones to the front headphone port disables my line-out completely, even though the “Show additional options for Built-In Audio Analog Stereo” does show ports line-out and headphones which I should be able to switch between. I really want to be able to swap between headphones (front headphone) and IEMs (rear line-out) without unplugging my headphones from the front or IEMs from the rear. Can I set them to the same priority maybe?
If you only want to hear the Line-in connection via ALSA loopback to headphones or speakers
configure the ALSA capture inputs not to use Line-in as a capture source, so PulseAudio
cannot use Line In instead of microphone
amixer --card=0 sset ‘Input Source’,0 ‘Front Mic’
amixer --card=0 sset ‘Input Source’,1 ‘Rear Mic’
and save the ALSA settings
sudo alsactl store
Changing the 2nd (Alt Analog) capture source is not critical as ‘Capture’,1 is set to [0%] [-17.25dB] [off]
The playback level controls for Front Mic and Rear Mic are set to 0% but you may also want to mute any loopback audio from the microphones
amixer --card=0 sset ‘Rear Mic’,0 mute
amixer --card=0 sset ‘Front Mic’,0 mute
Turn off Auto-Mute Mode so rear jack is not muted when headphones are plugged in
amixer -c1 sset 'Auto-Mute Mode' Disabled
Auto-mute is useful on a laptop to disable internal speakers, but it is usually not wanted for a desktop systems or users that want to keep headphones plugged in
If you want to mute or unmute either Headphones or IEMs
amixer sset -c0 Headphone toggle
amixer sset -c0 Front toggle
or two commands to change both outputs
amixer sset -qc0 Headphone unmute && amixer sset -qc0 Front mute
amixer sset -qc0 Headphone mute && amixer sset -qc0 Front unmute
After making your changes and enabling loopback, only the Line In is played back in the IEMs and Headphones. Success!
However, with loopback enabled there is a significant static soundfloor in my IEMs (lineout) but not in the headphones (headphone). If I mute Front in alsamixer it goes away, but that also mutes the IEMs… so close.
Also, disabling auto-mute sends sound through both devices simultaneously. That’s not exactly what I hoped for, but disabling auto-mute in the alsamixer CLI, then switching between Line Out and headphones in the plasma-pa tray applet is disabling the headphones on Line Out and enabling both on headphones. I can settle for that, but toggling between one and the other (always one active and one muted) would be optimal.
Should loopback persist on reboot if set in alsamixer?
I use the plasma-pa applet daily and rarely use alsamixer.
Big update to my problems, I just switched to manjaro-pipewire and switching between devices was completely taken care of. I’ve now left my headphones plugged-in (front headphone and front mic) simultaneously with my line out (rear) and each one activates independently when swapping them in plasma-pa applet (as in prior image). The only issue I have left now is the static hissing/soundfloor in Line-Out when using loopback.
Could I use ‘Capture’,1 as the source for line-in in a loopback command or would that require altering the card profile to enable the line-in for ‘Capture’,1 since it’s not an option yet?
Enabling Loopback Mixing no longer plays line-in through any of my sink devices.
Help me please, im new user and i hope same to ( can hear my microphone input in my speaker )
aplay -l
card 0: PCH [HDA Intel PCH], device 0: ALC887-VD Analog [ALC887-VD Analog]
  Subdevices: 0/1
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
card 2: AUDIO [LZY USB AUDIO], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
amixer --card1=1
Simple mixer control 'IEC958',0
  Mono: Playback [on]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
please help me
To check your onboard audio controls:
amixer --card=0
Audio codec ALC887-VD has an additional control for loopback mixing that may need to be disabled
amixer --card=0 sset 'Loopback Mixing' Disabled
This topic is about Line In, not Rear Microphone. You may want to create a different thread.
