So far, I’ve only used jack2 with qjackctl and a2jmidid …
Since the previous update, a2jmidid stopped working, so I’ve now replaced pulse/jack with pipewire (pipewire-jack, pipewire-pulse, pipewire-alsa). Everything seems to be working now, and the error messages have disappeared.
What happens to qjackctl and a2jmidid? Can it be removed and is there a pipewire-jack configuration GUI similar to qjackctl?
Are there any other recommendations for use with Reaper, Ardour, Mixbus?
Details on my previous issues & system information
$ cat /proc/asound/cards
0 [USB ]: USB-Audio - Scarlett 2i2 USB
Focusrite Scarlett 2i2 USB at usb-0000:00:14.0-4, high speed
1 [Interface ]: USB-Audio - USB MIDI Interface
USB MIDI Interface at usb-0000:00:14.0-7, full speed
Kernel: 6.19.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
clocksource: tsc
Desktop: KDE Plasma v: 6.5.6 tk: Qt v: N/A wm: kwin_wayland
with: cairo-dock vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
Type: Desktop System: Dell product: OptiPlex 7040 v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Dell model: 0HD5W2 v: A00 serial: <superuser required> part-nu: 06B9
uuid: <superuser required> Firmware: UEFI-[Legacy] vendor: Dell v: 1.11.1
date: 10/10/2018
Info: quad core model: Intel Core i7-6700 bits: 64 type: MT MCP smt: enabled
arch: Skylake-S rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 2800 min/max: 800/3400 cores: 1: 2800 2: 2800 3: 2800
4: 2800 5: 2800 6: 2800 7: 2800 8: 2800 bogomips: 54398
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel Skylake-S GT2 [HD Graphics 530] vendor: Dell driver: i915
v: kernel arch: Gen-9 ports: active: HDMI-A-2,HDMI-A-3 empty: DP-1, DP-2,
DP-3, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1912 class-ID: 0300
alternate: fbdev,vesa dri: iris gpu: i915 d-rect: 3840x1080 display-ID: 0
Monitor-1: HDMI-A-2 pos: primary,left model: Acer K242HL serial: <filter>
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92
size: 531x299mm (20.91x11.77") diag: 609mm (24") modes: max: 1920x1080
min: 720x400
Monitor-2: HDMI-A-3 pos: right model: Acer K242HL serial: <filter> res:
min: 720x400
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
device-ID: 8086:1912 display-ID: :0.0
API: Vulkan v: 1.4.341 layers: 2 surfaces: N/A device: 0
type: integrated-gpu driver: mesa intel device-ID: 8086:1912
de: kscreen-console,kscreen-doctor wl: wayland-info,wlr-randr
x11: xdpyinfo, xprop, xrandr
Device-1: Focusrite-Novation Focusrite Scarlett 2i2 driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-4:3 chip-ID: 1235:8016
class-ID: fe01
Device-2: USB MIDI Interface driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 bus-ID: 1-7:5 chip-ID: fc02:0101 class-ID: 0103
API: ALSA v: k6.19.8-1-MANJARO status: kernel-api
Server-1: sndiod v: N/A status: off
Server-2: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wireguard1 state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 1.39 TiB used: 218.49 GiB (15.4%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDH3 500G size: 465.76 GiB
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 20RL scheme: GPT
ID-2: /dev/sdb vendor: Silicon Power model: SPCC Solid State Disk
size: 953.87 GiB speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 916a
scheme: GPT
ID-1: / size: 57.37 GiB used: 33.35 GiB (58.1%) fs: ext4 dev: /dev/sda2
ID-2: /boot size: 511 MiB used: 94.8 MiB (18.5%) fs: vfat dev: /dev/sda1
ID-3: /home size: 152.74 GiB used: 58.82 GiB (38.5%) fs: ext4
dev: /dev/sda3
ID-1: swap-1 type: file size: 5 GiB used: 0 KiB (0.0%) priority: -1
file: /swapfile
System Temperatures: cpu: 31.0 C pch: 51.5 C mobo: 32.0 C
Fan Speeds (rpm): cpu: 1115 mobo: 1241
Memory: total: 32 GiB available: 31.1 GiB used: 4.26 GiB (13.7%)
Processes: 243 Power: uptime: 31m states: freeze,mem,disk suspend: deep
wakeups: 0 hibernate: platform Init: systemd v: 259 default: graphical
Packages: pm: pacman pkgs: 1906 Compilers: clang: 22.1.1 gcc: 15.2.1
Shell: Bash v: 5.3.9 running-in: konsole inxi: 3.3.40
