Hi, after latest updates “ruah” if I move away whit my ps4 controller it disconnects, about 50 cm. I don’t understand which update has changed settings/range of the bluetooth. Until recently I did not encounter this problem on manjaro. I dual boot manjaro, in windows i have no problems, the connection remains over a meter away.
Any suggestion to troubleshoot? Check?
Thx.
Hi,
You can check if all is as in the Gamepad - ArchWiki
If you used the AUR driver package, you might have to rebuild it and then pair again the controller to the system.
Not used aur package or added official repo package. Simple plugged in bluetooth receiver and paired ps4 controller. Fixed by using my keyboard usb slot… but it’s a workaround beaucause is more close. Simply whit latest updates something is changed in bluetooth range…
