I have been trying to get PrusaSlicer working on my arm64 Pinebook Pro. When I try to start it from the commandline I get the following error.
[aaron@pinebookpro ~]$ prusa-slicer
prusa-slicer: error while loading shared libraries: libopenvdb.so.8.0: cannot open shared object file: No such file or directory
It looks like a problem with the openvdb libraries. If the package is not working by default what is the correct way to update the build of the package to correct it? The package shows it’s packager is builder+n1@archlinuxarm.org.
I manually built it using their files on github but wasn’t sure what the correct way was for getting any fix or rebuild submitted to the main repo. I see what @Strit trit posted below and I will see if I can get it working.
