como colocar proxy do manjaro?
não conseguir localizar o local onde coloca o mesmo no meu manjaro
System-wide proxies in Xfce must be set via environment variables
If you use the Xfce desktop environment, it does not contain a graphical settings tool to set systemwide proxies.
1. Set up the proxy/proxies for most programs
Execute:
sudo nano /etc/environmentThis file stores the system-wide variables initialized upon boot.
Add the following lines, modifying appropriately. You must duplicate in both upper-case and lower-case because (unfortunately) some programs only look for one or the other:
http_proxy=http://myproxy.server.com:8080/ https_proxy=http://myproxy.server.com:8080/ ftp_proxy=http://myproxy.server.com:8080/ no_proxy="localhost,127.0.0.1,localaddress,.localdomain.com" HTTP_PROXY=http://myproxy.server.com:8080/ HTTPS_PROXY=http://myproxy.server.com:8080/ FTP_PROXY=http://myproxy.server.com:8080/ NO_PROXY="localhost,127.0.0.1,localaddress,.localdomain.com"
2. Then set up proxies for GTK3 programs such as Rhythmbox:
Some newer GTK3 programs such as Rhythmbox ignore the environment variables set above, and rely on Gnome settings instead. To make sure they are covered, open a terminal and paste the below line-by-line, modifying as appropriate:
gsettings set org.gnome.system.proxy mode 'manual'
gsettings set org.gnome.system.proxy.http host 'myproxy.server.com'
gsettings set org.gnome.system.proxy.http port 8080
3. Finally, set up the proxies for apt-get and Update Manager
These programs will not obey the environment variables either. Create a file called
95proxiesin/etc/apt/apt.conf.d/, and include the following:Acquire::http::proxy "http://myproxy.server.com:8080/"; Acquire::ftp::proxy "ftp://myproxy.server.com:8080/"; Acquire::https::proxy "https://myproxy.server.com:8080/";
Finally, logout and reboot to make sure the changes take effect.
