Hi Guys,
I have to set my proxies in system settings every time I boot into KDE. it resets on reboot.
Is there any way I can automate the process ?
I am using Privoxy and tor.
Let me know.
Cheers.
Hi Guys,
Let me know.
Cheers.
Have you consulted the all-knowing-wiki?
I don’t think there’s any issue with Tor & Privoxy.
They work perfectly fine, its just I need to go to the settings to set the proxies every single time I login.
I had trouble getting those services start on boot but I got them to autostart by editing .config files.
I think, Its an Issue with KDE, I have seen other people having the same issue of settings not saving in KDE system settings.
So you didn’t see the topics - especially the service files you need to enable?
And environment you need to configure either per app or for your user - even systemwide?
Alternatively you can set
http_proxy
environment variable, which is respected by Firefox, Chromium and other applications:http_proxy="http://localhost:8118"
Thanks.
sudo nano /etc/profile
Edited at the bottom, wrote.
export http_proxy=localhost:8118
export SOCKS_proxy=localhost:9050
