ProtonVPN killswitch not fully functional
So I was torrenting today and when I went to check my vpn I realized that protonvpn was not connected and that killswitch was enabled. the killswitch seemed to work everywhere else but I was wondering if the protonvpn client for manjaro is just poorly made and how I can fix it (ive heard the cli client is more reliable) because I dont want to get throttled by/receive a complaint from my isp. Im going to test whether or not I can torrent with kill switch on unconnected to see if this is just a one time issue. I will report back when I get the results of that test.
i tried torrenting for a few seconds with killswitch on again and qbitorrent is able to bypass the killswitch for some reason while when I try to browse the internet I cant connect. How do I rectify this and how do i check to ensure that other forms of traffic arent leaving my laptop when killswitch is enabled?
If I turn the killswitch on, then I loose browsing, e-mail access, and gosh knows what else. However, the local police radio scanner live stream is still functional in the mpv media player.
If I recall correctly, I think I read somewhere some time ago that there’s a problem with the killswitch in the ProtonVPN GUI.
yeah I just switched to the cli its not actually that difficult to use even for a noob like me. and it uses fewer system resources which god knows I need with my piece of shit $120 computer.
I switched from connecting directly from network manager to the ProtonVPN GUI to see what it’s like, to test it out. I had used in the past the CLI method and may end up reverting to it, rather than the other two methods.
Manjaro has no protonvpn client.
All protonvpn packages comes from AUR and is built from protonvpn python packages.
Protonvpn is a paid service - and as such you should contact the provider.
I’m using Kill switch third party extension. This help me more if vpn default option does not work properly.
