jmosby
7 February 2022 18:42
1
Hi, I have Proton VPN installed but encounter a couple of issues.
The app will not launch from launcher when clicked. It worked when I installed it but suddenly stopped.
I can only access it from the network icon in the tray, and then I can only choose one connection instead of the many that are available in the app user interface.
Launch it from terminal and share output of protonvpn-gui. Also see this thread:
I’m not very sure if it caused issue but after i added chaotic-aur and updated , protonvpn no longer opens. clicking .Desktop file does nothing . Tried reinstalling several times . typing protonvpn-gui in terminal open this window which is very different from what i’m used to .
[image]
annoyingly enough it shows a window that always stays on top when connecting
[image]
but it doesn’t manage to connect
terminal says
(protonvpn-gui:19994): Gtk-WARNING **: 20:23:47.666: Failed to set text 't…
jmosby
8 February 2022 08:49
3
Output: zsh: command not found: protonvpn-gui
linub
8 February 2022 15:24
4
when you install this package,it installs also protonvpn-gui
https://aur.archlinux.org/packages/protonvpn
jmosby
8 February 2022 17:29
5
Okay, but I have already installed a package by that name.
ydar
8 February 2022 19:31
6
Did you recently update, sometimes AUR packages need to be rebuilt/re-installed.
jmosby
9 February 2022 16:59
7
I re-installed the package now and it worked. Thanks.
system
Closed
12 February 2022 07:00
8
