How would I automate that?
Pretty obvious - I have not programmed for years and am quite new to Manjaro.
Thank you again for your help.
Basically running a bash script. Nothing too hard and in general it not âprogrammingâ. Maybe I will take some time and write something up to automate it⌠Iâll let you know when it is ready for the public.
It seems that in step 4, I enter the password but then I have to enter it again when using the Network Manager.
Is this expected?
With the CLI, I can add the suffix -f to the command and connect to the fastest network. Is there a good way to automatically check via the Network Manager?
Yeah I came across this issue as well. Solved it at the script. Will update it ASAP.
Meanwhile here is the working script.
Usage: bash scriptname.sh /path/to/yourfile.ovpn
#!/usr/bin/env bash
set -o errexit
set -o pipefail
# Enter your VPN login details here so you won't be asked.
VPN_USER=""
VPN_PASS=""
# Check if file is provided
if [ -z "$1" ]; then
echo "Usage: $0 /path/to/yourfile.ovpn"
exit 1
fi
OVPN_FILE=$1
# Check if the file exists
if [ ! -f "$OVPN_FILE" ]; then
echo "File not found!"
exit 1
fi
# Extract the base name of the file without extension
CONN_NAME=$(basename "$OVPN_FILE" .ovpn)
# Check if the connection already exists
if nmcli connection show | grep -q "$CONN_NAME"; then
echo "Connection $CONN_NAME already exists. Delete it?"
echo "y -> yes | n -> no | c -> connect"
read -p "[y/n/c] > " yn
case $yn in
y) echo "Connection $CONN_NAME is deleted."
nmcli connection delete $CONN_NAME
exit 0
n) exit 0
c) if nmcli connection show --active | grep -q "$CONN_NAME"; then
echo "Connection $CONN_NAME is already active."
exit 0
else
nmcli connection up "$CONN_NAME"
echo "VPN connection $CONN_NAME has been successfully connected."
fi
esac
else
# Import the .ovpn file
nmcli connection import type openvpn file "$OVPN_FILE"
# Set username and password
if [ -z "$VPN_USER" ]; then
read -p "Enter VPN username: " VPN_USER
fi
if [ -z "$VPN_PASS" ]; then
read -sp "Enter VPN password: " VPN_PASS
fi
# Make the connection available for all users
nmcli connection modify "$CONN_NAME" connection.permissions ''
# Modify the connection with the username
sudo nmcli connection modify "$CONN_NAME" +vpn.data username="$VPN_USER"
# Create a secrets file for the password
SECRETS_FILE="/etc/NetworkManager/system-connections/$CONN_NAME.nmconnection"
sudo sed -i "s;\[ipv4\];\[vpn-secrets\]\npassword=$VPN_PASS\n\n\[ipv4\];g" $SECRETS_FILE
sudo sed -i "s;password-flags=1;password-flags=0;g" $SECRETS_FILE
# Ensure that sed modified $SECRETS_FILE
if ! sudo grep -oq "$VPN_PASS" "$SECRETS_FILE"; then
if ! sudo grep -oq "password-flags=0" "$SECRETS_FILE"; then
exit 1
fi
fi
# Ensure the file has the correct permissions
sudo chmod 600 "$SECRETS_FILE"
# Restart NetworkManager to apply changes
sudo systemctl restart NetworkManager
# Connect to the VPN
echo "VPN connection $CONN_NAME has been successfully configured and connected."
fi
Thank you. How do I use it? I filled in the name & password in a text editor and pasted into Terminal but Terminal quit. So I guess that wasnât how?
Paste it into a text-file. Name it how ever you like. Fo example: ovpn-import.sh
. Then open the terminal change the working directory to the directory where file exists (cd /path/to/dir/
) and then do as I wrote:
Perfect! Thank you!
