Hello, i have problem with running steam games with proton. Native linux games like CS2 works fine. The problem appeared after a complete system reinstallation, before i had no problems (
I had an updated system ).
There some system informations:
inxi -Fazy ✔
Kernel: 6.9.3-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.9-x86_64
root=UUID=e9d10a33-4775-476b-bd21-9b5c6b835085 rw rootflags=subvol=@ quiet
splash udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop Mobo: ASUSTeK model: PRIME X370-PRO v: Rev X.0x
serial: <superuser required> part-nu: SKU UEFI: American Megatrends v: 6042
date: 04/28/2022
Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 4092 high: 4100 min/max: 2200/4409 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4087 2: 4088
3: 4087 4: 4094 5: 4094 6: 4094 7: 4087 8: 4100 9: 4087 10: 4094 11: 4100
12: 4094 bogomips: 91245
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2
empty: DP-1, DP-3, HDMI-A-1, Writeback-1 bus-ID: 0a:00.0 chip-ID: 1002:73bf
class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-2 mapped: DisplayPort-1 model: Acer ED323QUR built: 2018
res: 2560x1440 hz: 75 dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 XT (radeonsi
navi21 LLVM 17.0.6 DRM 3.57 6.9.3-3-MANJARO) device-ID: 1002:73bf
memory: 15.62 GiB unified: no
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: discrete-gpu
name: AMD Radeon RX 6800 XT driver: amd v: 2024.Q2.1 (LLPC)
device-ID: 1002:73bf surfaces: xcb,xlib
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.9.3-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.61 TiB used: 1.05 TiB (65.4%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Plextor model: PX-512M8PeGN
lanes: 4 tech: SSD serial: <filter> fw-rev: 1.06 temp: 40.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: A-Data model: LEGEND 800
lanes: 4 tech: SSD serial: <filter> fw-rev: V1122B0 temp: 36.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: A-Data model: SU750 size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: 4R25 scheme: GPT
ID-1: / raw-size: 144.99 GiB size: 144.99 GiB (100.00%)
used: 27.57 GiB (19.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
ID-2: /boot/efi raw-size: 520 MiB size: 519 MiB (99.80%)
used: 612 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
ID-3: /home raw-size: 144.99 GiB size: 144.99 GiB (100.00%)
ID-4: /var/log raw-size: 144.99 GiB size: 144.99 GiB (100.00%)
System Temperatures: cpu: 74.5 C mobo: N/A gpu: amdgpu temp: 55.0 C
mem: 54.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Memory: total: 32 GiB available: 31.25 GiB used: 6.6 GiB (21.1%)
Processes: 397 Power: uptime: 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1358 libs: 436 tools: pamac,paru pm: flatpak
pkgs: 0 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
vulkaninfo --summary ✔
VULKANINFO
Vulkan Instance Version: 1.3.279
Instance Extensions: count = 23
VK_EXT_acquire_drm_display : extension revision 1
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_EXT_surface_maintenance1 : extension revision 1
VK_EXT_swapchain_colorspace : extension revision 4
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_portability_enumeration : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
VK_LUNARG_direct_driver_loading : extension revision 1
Instance Layers: count = 10
VK_LAYER_AMD_switchable_graphics_32 AMD switchable graphics layer 1.3.280 version 1
VK_LAYER_AMD_switchable_graphics_64 AMD switchable graphics layer 1.3.280 version 1
VK_LAYER_MANGOAPP_overlay Mangoapp Layer 1.3.0 version 1
VK_LAYER_MANGOHUD_overlay_x86 Vulkan Hud Overlay 1.3.0 version 1
VK_LAYER_MANGOHUD_overlay_x86_64 Vulkan Hud Overlay 1.3.0 version 1
VK_LAYER_VALVE_steam_fossilize_32 Steam Pipeline Caching Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_fossilize_64 Steam Pipeline Caching Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_overlay_32 Steam Overlay Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_overlay_64 Steam Overlay Layer 1.3.207 version 1
Devices:
GPU0:
apiVersion = 1.3.280
driverVersion = 2.0.304
vendorID = 0x1002
deviceID = 0x73bf
deviceType = PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
deviceName = AMD Radeon RX 6800 XT
driverID = DRIVER_ID_AMD_OPEN_SOURCE
driverName = AMD open-source driver
driverInfo = 2024.Q2.1 (LLPC)
conformanceVersion = 1.3.5.2
deviceUUID = 00000000-0a00-0000-0000-000000000000
mhwd -li INT ✘
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
I tried:
- many proton versions
- both RADV and AMDVLK vulkan
- PROTON_LOG and PROTON_LOG_DIR but no logs are saved
- PROTON_USE_WINED3D=1 %command%
- few different games - installed on diffrent drives
Please help
