Hi, I’ve installed the Protonmail proton-bridge app from the AUR. It requires a keyring, which I have installed (pass). When I run proton-bridge it says no keyring found, even though I’ve created a gpg key using
gpg --gen-key
and then initialized pass using
pass init <mykeyid>
The key id I used was the one marked
gpg: key blahblahblah marked as ultimately trusted
did I enter the correct value, or am I missing something else. Thanks!
