I have Timeshift setup on my machine to take a snapshot weekly and keep 2 copies. I have the standard ‘ignore user files’ and set it to exclude all on both /home/user and root. When I go into Timeshift I can see my snapshot (I manually deleted what would have been my 1 and 2 week old after excluding ollama models and created a manual one to save some space) and when I click browse it brings me to /timeshift/snapshots/date. I am using rsync as I don’t use a BTRFS filesystem.
Running a du on the snapshots folder gets me:
97G snapshots
73G snapshots/2025-03-23_17-56-56
72G snapshots/2025-03-23_17-56-56/localhost
32G snapshots/2025-03-23_17-56-56/localhost/opt
30G snapshots/2025-03-23_17-56-56/localhost/opt/rocm
29G snapshots/2025-03-23_17-56-56/localhost/opt/rocm/lib
25G snapshots/2025-03-23_17-50-56/localhost
24G snapshots/2025-03-23_17-50-56/localhost/opt
23G snapshots/2025-03-23_17-56-56/localhost/var
23G snapshots/2025-03-23_17-50-56/localhost/opt/rocm
22G snapshots/2025-03-23_17-50-56/localhost/opt/rocm/lib
19G snapshots/2025-03-23_17-56-56/localhost/var/lib
18G snapshots/2025-03-23_17-56-56/localhost/usr
17G snapshots/2025-03-23_17-56-56/localhost/var/lib/flatpak
Which seems larger than I would want it to be? Are there some more files/folders I should be ignoring? (I found it was backing up ollama models which I have ignored and reclaimed ~96G). rocm seems to eat a bunch of space. as well as flatpak. Should I be ignoring those? Worse case scenario I have to reinstall my flatpaks and rocm?
However, I was curious as to what on my system is eating the most space because I feel like I am always out of space so I ran
du -h * | sort -rh | head -n 20
320G home/user
320G home
250G run
237G run/timeshift/8265/backup
237G run/timeshift
// other entries
Which leads me to question, what the hell is this run/timeshift and why does it take up 1/4 of my drive (according to du)?
/run/timeshift/8265/backup ls -la ✔
total 128
drwxr-xr-x 19 root root 4096 Feb 18 23:11 .
drwxr-xr-x 3 root root 60 Mar 23 17:31 ..
lrwxrwxrwx 1 root root 7 Dec 2 16:33 bin -> usr/bin
drwxr-xr-x 5 root root 4096 Mar 23 17:00 boot
-rw-r--r-- 1 root root 22560 Dec 23 2022 desktopfs-pkgs.txt
drwxr-xr-x 2 root root 4096 Jan 5 2023 dev
drwxr-xr-x 121 root root 12288 Mar 23 17:16 etc
drwxr-xr-x 3 root root 4096 Jan 5 2023 home
lrwxrwxrwx 1 root root 7 Dec 2 16:33 lib -> usr/lib
lrwxrwxrwx 1 root root 7 Dec 2 16:33 lib64 -> usr/lib
drwx------ 2 root root 16384 Jan 5 2023 lost+found
-rw-r--r-- 1 root root 8 Dec 23 2022 .manjaro-tools
drwxr-xr-x 3 root root 4096 Jul 30 2023 media
drwxr-xr-x 2 root root 4096 Oct 19 2022 mnt
drwxr-xr-x 8 root root 4096 Feb 4 22:53 opt
drwxr-xr-x 2 root root 4096 Jan 5 2023 proc
drwxr-x--- 6 root root 4096 Mar 23 17:21 root
-rw-r--r-- 1 root root 5289 Dec 23 2022 rootfs-pkgs.txt
drwxr-xr-x 2 root root 4096 Jan 5 2023 run
lrwxrwxrwx 1 root root 7 Dec 2 16:33 sbin -> usr/bin
drwxr-xr-x 4 root root 4096 Dec 23 2022 srv
drwxr-xr-x 2 root root 4096 Jan 5 2023 sys
drwxr-xr-x 9 root root 4096 Mar 10 21:02 timeshift
drwxrwxrwt 2 root root 4096 Jan 5 2023 tmp
drwxr-xr-x 9 root root 4096 Mar 23 17:16 usr
drwxr-xr-x 13 root root 4096 Mar 23 17:00 var
it seems to have a copy of my home folder? I have the home folder as set to ignore in the gui. Is this because I am using rsync? Why does it have this whole separate backup when I have the /timeshift/snapshot folder? It seems to update anytime I update something in my regular /home/user.
Also it seems to include the /timeshift/snapshot folder
73G run/timeshift/10816/backup/timeshift/snapshots/2025-03-23_17-56-56
Also here is the settings json
cat timeshift.json ✔
"backup_device_uuid" : "3e6e4c0f-26d2-4b14-af4a-9bee693e02f7",
"parent_device_uuid" : "",
"do_first_run" : "false",
"btrfs_mode" : "false",
"include_btrfs_home_for_backup" : "false",
"include_btrfs_home_for_restore" : "false",
"stop_cron_emails" : "true",
"schedule_monthly" : "false",
"schedule_weekly" : "true",
"schedule_daily" : "false",
"schedule_hourly" : "false",
"schedule_boot" : "false",
"count_monthly" : "2",
"count_weekly" : "2",
"count_daily" : "5",
"count_hourly" : "6",
"count_boot" : "5",
"snapshot_size" : "0",
"snapshot_count" : "712223",
"date_format" : "%Y-%m-%d %H:%M:%S",
"exclude" : [
"/home/user/**",
"/var/lib/ollama/**",
"/home/**",
"/root/**"
"exclude-apps" : []
