I have a handful of programs that have to be built and then installed. Now ever since the Testing updates on the 7th I’ll get ask if I want to preview the changes. I tell it no and get asked if I want to try again instead of it building and installing. Was this a deliberate change or did the updates from the 7th break something?
~ inxi -Fxxxza ✔
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=0e474eb0-4b46-41af-8757-51221e62c250 rw rootflags=subvol=@ quiet
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 2423 date: 08/10/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325 serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 3 MiB
bogomips: 86272
Speed: 3468 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3468 2: 3862 3: 2195 4: 2197 5: 2094 6: 2196 7: 2201 8: 2195 9: 2165
10: 3910 11: 2035 12: 2193
conditional, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: eVga.com.
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 08:00.0
chip-ID: 10de:2187 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 2560x1080 s-dpi: 97 s-size: 670x283mm (26.4x11.1")
s-diag: 727mm (28.6")
Monitor-1: HDMI-0 res: 2560x1080 hz: 60 dpi: 97 size: 673x284mm (26.5x11.2")
diag: 730mm (28.8")
OpenGL: renderer: NVIDIA GeForce GTX 1650 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 495.44 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.40 running: yes
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 20.82 TiB used: 11.51 TiB (55.3%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Seagate model: XPG GAMMIX S11 Pro
lanes: 4 type: SSD serial: <filter> rev: 32B3T8EB temp: 33.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Patriot model: Viper M.2 VPN100
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: ECFM22.6 temp: 30.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Seagate
model: ST8000AS0002-1NA17Z size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5980 serial: <filter> scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate
model: ST3000DM 001-1E6166 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 7101 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: ST330006 51NS
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B type: N/A
ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate model: Expansion HDD
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 1801 scheme: GPT
ID-7: /dev/sde maj-min: 8:64 type: USB vendor: PNY model: USB 3.0 FD
size: 115.38 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
used: 93.54 GiB (19.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
Message: No sensor data found. Is lm-sensors configured?
Processes: 400 Uptime: 3h 41m wakeups: 43 Memory: 31.33 GiB
used: 7.27 GiB (23.2%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1701 pacman: 1657 lib: 446 flatpak: 33 snap: 11
Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
