Anyone knows how to kill that process?
sudo lsof -p 254507;sudo kill -9 254507;sleep 10;sudo lsof -p 254507
lsof: WARNING: can't stat() fuse.gvfsd-fuse file system /run/user/1000/gvfs
Output information may be incomplete.
lsof: WARNING: can't stat() fuse.portal file system /home/username/.cache/doc
lsof: WARNING: can't stat() fuse.gvfsd-fuse file system /home/username/.cache/gvfs
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
txg_sync 254507 root cwd DIR 254,0 4096 2 /
txg_sync 254507 root rtd DIR 254,0 4096 2 /
txg_sync 254507 root txt unknown /proc/254507/exe
i think that the process is related to ZFS filesystem (in my case based on ext. drive) (has kernel module), trying to kill via “su” command line not helped. 5.10.23-1-MANJARO
