I have ‘some’ process that is holding up my system. To the point that I can’t even load System Monitor to see what is causing it… It will clear up in around 3-5 minutes… but by then system monitor isn’t helpful.
Is there any log/app/method I can use to log what is going on and try to fix this? I suspect it is the Librewolf browser…
open a terminal and type:
top
Also, if you are running xfce, there is Task Manager (xfce4-taskmanager)
If my computer is already hanging -then I can’t open up a terminal window - or if it is open I can’t swap over to it… any ideas on how TOP can help me after the fact?
You have already tried to see whether there is something in the system log?
journalctl -r
for example,
lists it, most recent first
you can also filter for priority with the -p flag
man journalctl
and/or have a terminal open with top continuously running in it …
there is also the file ~/.xsession-errors if your session runs under xorg
dgdg
17 March 2024 23:07
7
If the entire system is hanging for 3-5 minutes, then that sounds like the OOM (out of memory) killer deciding to kill something. If so, then that should be in dmesg. You could try doing sudo dmesg -T | grep -Ei 'killed process' and you may find some info there.
But it’s also true that if it is the OOM killer, it may be worth having a system monitor open and sorting by RAM usage. I’d expect you to be able to see something gradually using up all the memory before it happens (unless you’re doing your own software development, where bugs can sneak up on you whenever).
I have been finding some OOM messages after my system is hanging…
Different processes are being killed (makes sense as it does not appear to be a particular app causing the issue)
My system only has 8gb ram (fixed) so I can’t expand it)
Is there any system settings I can adjust (caching? Swap space???) Any way to set priorities of what gets killed?
I guess I can just be careful with what I’m launching and when.
cscs
23 March 2024 01:23
9
System information would help …
inxi -Farzy
Sure
Info: model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1700 min/max: 400/3100 scaling: driver: intel_pstate
governor: powersave cores: 1: 1700 2: 1700 3: 1700 4: 1700 bogomips: 20810
dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer
vme x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: gather_data_sampling status: Vulnerable: No microcode
Type: itlb_multihit status: KVM: VMX unsupported
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
cscs
23 March 2024 01:33
11
Most of it is missing.
Please include the full output, as well as make use of the code format buttons.
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links whene…
Speed (MHz): avg: 627 high: 726 min/max: 400/3100 scaling:
driver: intel_pstate governor: powersave cores: 1: 685 2: 726 3: 400 4: 700
bogomips: 20810
Packages: 1848 pm: pacman pkgs: 1822 libs: 473 tools: pamac,yay pm: flatpak
pkgs: 26
1: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
3: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
8: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
Thought I’d add the killed processes:
~ sudo dmesg -T | grep -Ei 'killed process' ✔ 3s
[sudo] password for admin:
[Fri Mar 22 17:12:29 2024] Out of memory: Killed process 6404 (pamac-manager) total-vm:3658456kB, anon-rss:1880440kB, file-rss:476kB, shmem-rss:0kB, UID:1000 pgtables:4220kB oom_score_adj:200
[Fri Mar 22 18:10:57 2024] Out of memory: Killed process 6543 (beeper) total-vm:1195346836kB, anon-rss:450824kB, file-rss:128kB, shmem-rss:14464kB, UID:1000 pgtables:2108kB oom_score_adj:300
[Fri Mar 22 18:52:51 2024] Out of memory: Killed process 21969 (beeper) total-vm:1195334036kB, anon-rss:382084kB, file-rss:256kB, shmem-rss:13052kB, UID:1000 pgtables:1932kB oom_score_adj:300
cscs
23 March 2024 02:06
15
Still missing most of the inxi output … like swap, memory, kernel, etc.
Note: Your terminal emulator can scroll.
We have established its an out-of-memory condition.
Which likely is related to your memory and swap, which we would like to see.
But also … seems to be caused by pamac.
I would advise trying to clean it, and/or opting to use something else.
See also all the threads;
https://forum.manjaro.org/search?expanded=true&q=pamac%20memory%20order%3Alatest
Sorry - was running -farzy - not -Farzy
Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=148e2495-7438-48f3-8529-ca67fcc5f4bf rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: HP product: HP Spectre x360 Convertible v: N/A
Mobo: HP model: 804E v: 33.23 serial: <superuser required>
part-nu: N5S04UAR#ABA uuid: <superuser required> UEFI: American Megatrends
v: F.2D date: 10/23/2015
ID-1: BAT0 charge: 50.7 Wh (100.0%) condition: 50.7/50.7 Wh (100.0%)
volts: 12.8 min: 11.4 model: Hewlett-Packard Primary type: Li-ion serial: N/A
status: full
Device-1: hidpp_battery_0 model: Logitech Marathon Mouse/Performance Plus
M705 serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1 model: Logitech MK700 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
Speed (MHz): avg: 500 high: 800 min/max: 400/3100 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 800
bogomips: 20810
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: HDMI-A-1 off: eDP-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Device-2: Sunplus Innovation HP Truevision Full HD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4
chip-ID: 1bcf:2c7d class-ID: 0e02
Display: x11 server: X.Org v: 21.1.11 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary
model: LG (GoldStar) FULL HD built: 2015 res: 1920x1080 hz: 60 dpi: 102
gamma: 1.2 size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9
modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 note: disabled model: LG Display built: 2013
res: 1920x1080 dpi: 222 gamma: 1.2 size: 293x165mm (11.54x6.5")
diag: 336mm (13.2") ratio: 16:9 modes: 2560x1440
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 7.49 GiB unified: yes
API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
name: Intel HD Graphics 520 (SKL GT2) driver: mesa intel v: 24.0.2-manjaro1.1
device-ID: 8086:1916 surfaces: xcb,xlib
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:2725 class-ID: 0280
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 8087:0032
class-ID: e001
Local Storage: total: 238.47 GiB used: 197.85 GiB (83.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNTE256HMHP-000H1
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2H0Q scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 197.85 GiB (84.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 35.0 C pch: 32.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1848 pm: pacman pkgs: 1822 libs: 473 tools: pamac,yay pm: appimage
pkgs: 0 pm: flatpak pkgs: 26
Memory: total: 8 GiB available: 7.67 GiB used: 5.39 GiB (70.3%)
Processes: 240 Power: uptime: 5h 53m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.06 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
cscs
23 March 2024 04:58
17
Yup, no swap.
Which means … aside from oom-killer being able to get rid of things, your system would otherwise be expected to lock up when it reaches the end of its memory.
Theres lots of options for SWAP.
https://wiki.archlinux.org/title/Swap
I usually suggest zram these days unless hibernation is required.
Heres an example that would create zram for swap equal to the size of your memory;
Continuing the discussion from Awful performance since install :
sudo pacman -Syu zram-generator
Then edit the configuration file. (use your preferred editor)
sudo micro /etc/systemd/zram-generator.conf
You want it to look like:
[zram0]
zram-size = ram / 1
compression-algorithm = zstd
swap-priority = 100
fs-type = swap
You may want to ensure zswap is disabled as well. One way is to add to the boot options, at /etc/default/grub the option zswap.enabled=0.
That is to add it to one of the CMD lines so that (Assuming no other options) it would look like:
GRUB_CMDLINE_LINUX="zswap.enabled=0"
Then run
sudo grub-mkconfig -o /boot/grub/grub.cfg
And reboot.
You can check the configured swap/zram using
swapon
zramctl
Though that still wont ‘fix’ the runaway memory usage.
For that … please see related threads on pamac as linked above.
dgdg
23 March 2024 16:11
18
I’d point out that while Pamac isn’t helping things, the fact that beeper is getting OOM killed substantially later on to me suggest that @LuigiCalamar might just be using too many memory hungry applications for 8GB of RAM. Open up the system monitor and see what’s using your memory; it’s entirely possible that the actual cause is lots of tabs in your web browser, for example, depending on how the OOM killer ranks the processes on your system (in particular, the way that beeper allocates its memory might make it particularly attractive).
I’d definitely second setting of some form of swap for the system. zram is a pretty good choice, but you may actually benefit from a swap file as RAM appears to be very tight. See Arch Wiki on Swap, and in particular Section 3: Swap File for more details.
I concur that too many tabs in my browser seems to be an issue… system will hang if the only thing I’m doing is using my librewolf browser…
cscs
23 March 2024 18:42
20
Pretty impressive if you can get nothing but the browser to eat 8G of ram though.
I cant manage to do so even with hundreds of tabs.
Regardless … You definitely want swap.
I guess ‘we will see’ if you still get runaway memory usage.
(I expect you will … because pamac seems to cause it in general right now)
(( and because I notice the link above is still not clicked … heres another: Bizarre Pamac & Pacman behavior: used 62GiB memory, took 10min to refresh DBs - #29 by aZero ))
dgdg
23 March 2024 20:00
21
If LibreWolf looks to be the problem, then I would recommend going to about:processes in the browser (edit: tried to make a link, but it looks like the link won’t work in this forum software). That will give you a detailed breakdown of everything that LibreWolf is doing, including in terms of memory (works on all Firefox based browsers). That will include if there’s a problem with extensions using up lots of memory.
However, it’s also potentially worth looking at System Monitor and sorting by memory usage, or perhaps posting the output of ps aux --sort -rss | head.
