Hi,
at boot time, when the system do the fsck on my root parition , before the start of the login manages, I have the following error, that slows down the loading of LightDM
proc: unrecognized mount option "hidepid=invisible" or missing value
My uname -ra
Linux salome 4.4.271-1-MANJARO #1 SMP PREEMPT Thu Jun 3 13:28:02 UTC 2021 x86_64 GNU/Linux
Here my sudo dmesg|grep proc
[ 0.000000] tsc: Detected 2992.129 MHz processor
[ 0.012316] process: using mwait in idle threads
[ 0.242068] smpboot: Total of 4 processors activated (23946.40 BogoMIPS)
[ 10.613817] proc: unrecognized mount option "hidepid=invisible" or missing value
[ 11.447250] proc: unrecognized mount option "hidepid=invisible" or missing value
[ 12.510502] proc: unrecognized mount option "hidepid=invisible" or missing value
This is my /etc/fstab
# Created by Manjaro Live-Installer
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=0ea07c5e-2976-475c-b2f3-9f43dcf1267c / ext4 rw,relatime,data=ordered 0 1
UUID=ba299950-950e-4e07-a076-db0ad75b3554 /boot ext4 defaults 0 0
UUID=063629e1-678f-4e40-9388-45d2b00167a8 swap swap defaults 0 0
#ram Drive using tmpfs#
tmp /tmp tmpfs rw,mode=1777 0 0
vartmp /var/tmp tmpfs rw,mode=1777 0 0
https://lists.openembedded.org/g/openembedded-core/message/146725
Is there a way to avoid this error message at the startup?
