Hi there.
I reinstalled Manjaro KDE because I was having some problems.
Now I am having different problems. Texts in settings menu are sometimes distorted, especially when I’m scrolling thru the menu.
See the text in the left side of the window.
Text rendering is not the only problem however. Wayland-session is acting weird generally. I’m experiencing some bugs&stuff. And the biggest one is this: After I enter my password in the lock screen, screen stays black. I can see my cursor, I can move it. After like 10-15 seconds, my desktop & panels & wallpaper becomes visible.
I am using video-linux driver and OpenGL 3.1. But it is the same with OpenGL 2.0 too.
Kernel: 5.15.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=c93def77-6fc1-4dcc-8258-e43679fbfb4a rw quiet
resume=UUID=fec6d4e2-394a-4cd7-a31a-b240dc9b55c0 udev.log_priority=3
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_wayland vt: 2 dm: SDDM
Type: Laptop System: Apple product: MacBookAir6,2 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-7DF21CB3ED6977E5
Mobo: Apple model: Mac-7DF21CB3ED6977E5 v: MacBookAir6,2
serial: <superuser required> UEFI: Apple v: 122.0.0.0.0 date: 06/10/2020
ID-1: BAT0 charge: 21.2 Wh (62.0%) condition: 34.2/54.3 Wh (62.9%)
volts: 7.4 min: 7.6 model: SMP bq20z451 type: Li-ion serial: N/A
status: Discharging cycles: 2684
RAM: total: 3.77 GiB used: 2.77 GiB (73.4%)
RAM Report:
Info: model: Intel Core i5-4250U bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1317 high: 1352 min/max: 800/2600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1352 2: 1300 3: 1316
4: 1300 bogomips: 15207
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Apple driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a26 class-ID: 0300
Display: wayland server: X.org 1.21.1.3 compositor: kwin_wayland driver:
loaded: modesetting alternate: fbdev,vesa display-ID: 0
Device-1: Intel Haswell-ULT HD Audio vendor: Apple driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Device-3: Broadcom 720p FaceTime HD Camera driver: facetimehd v: kernel
bus-ID: 02:00.0 chip-ID: 14e4:1570 class-ID: 0480
Sound Server-1: ALSA v: k5.15.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
driver: wl v: kernel modules: bcma bus-ID: 03:00.0 chip-ID: 14e4:43a0
class-ID: 0280
Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-3.3:6 chip-ID: 05ac:828f class-ID: fe01
Local Storage: total: 113 GiB used: 43.47 GiB (38.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0128F size: 113 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: EA1Q scheme: GPT
ID-1: / raw-size: 104.4 GiB size: 102.2 GiB (97.89%) used: 42.75 GiB (41.8%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: c93def77-6fc1-4dcc-8258-e43679fbfb4a
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 7947-A556
ID-1: swap-1 type: partition size: 8.3 GiB used: 736.2 MiB (8.7%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: fec6d4e2-394a-4cd7-a31a-b240dc9b55c0
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Hub-2: 1-3:2
info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 1-3.3:6 info: Apple Bluetooth USB Host Controller
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
Device-2: 1-5:3 info: Apple Apple Internal Keyboard / Trackpad
type: HID,Keyboard,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 05ac:0291 class-ID: 0301
serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 2-3:2 info: Apple Internal Memory Card Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 05ac:8406 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 65.0 C mobo: N/A
Processes: 224 Uptime: 1h 10m wakeups: 2 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1388
pacman: 1380 lib: 358 flatpak: 8 Shell: Zsh v: 5.8 running-in: yakuake
inxi: 3.3.12
