Hi,
i have a big problem with my system. I have manjaro gnome 3.38 for 1 year on my hardware installed and it works fine. The system was installed on a “normal” Sata SSD from samsung. But i want to test manjaro KDE version because Gnome has not enough tweak options for me. So i buy a NVME SX8200 Adata SSD because my Gigabyte X370 AMD K5 Gaming motherboard has one slot for that. So after installing manjaro KDE V 21.01the problem began… Sometimes at the boot i see a notification that the filesystem was checked. But System boots fine. But at the shutdown sometimes the system halts for 2 minutes, shows a watchdog 5100 error and shuts down. but this occures not every time. sometimes it shuts down without this delay.
A first search shows maybe a bios problem, so i flash the newest bios. The problem still exist, so i have no idea whats cause this problem. With the Sata SSD and gnome 3.38 all works fine. But on the NVME with KDE and manjaro V21.01 sometimes not. Checked the NVME → seems ok. Bios ? → works fine with gnome 3.38 and Sata SSD. Also checked that the Gigabyte board has problems with NVME und Sata port 3-> This port is now not used. Maybe someone can see in the attached logs what can cause this problem ?
I hope that someone can help me to find the problem. KDE and Gnome systems have both the same Kernel. The KDE Desktop works fine and i began to tweak the settings to my needs… but the shutdown problem exists and i dont want to work with that as daily driver.
Journalctl
journalctl --boot=-1 | tail --lines=100
Apr 18 23:58:17 PC1 systemd[1]: Removed slice User and Session Slice.
Apr 18 23:58:17 PC1 systemd[1]: Stopped target Sockets.
Apr 18 23:58:17 PC1 systemd[1]: avahi-daemon.socket: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Apr 18 23:58:17 PC1 systemd[1]: cups.socket: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Closed CUPS Scheduler.
Apr 18 23:58:17 PC1 systemd[1]: dbus.socket: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Closed D-Bus System Message Bus Socket.
Apr 18 23:58:17 PC1 systemd[1]: snapd.socket: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Closed Socket activation for snappy daemon.
Apr 18 23:58:17 PC1 systemd[1]: Stopped target System Initialization.
Apr 18 23:58:17 PC1 systemd[1]: Stopped target Local Encrypted Volumes.
Apr 18 23:58:17 PC1 systemd[1]: systemd-ask-password-console.path: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Apr 18 23:58:17 PC1 systemd[1]: systemd-ask-password-wall.path: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Apr 18 23:58:17 PC1 audit: BPF prog-id=8 op=UNLOAD
Apr 18 23:58:17 PC1 audit: BPF prog-id=7 op=UNLOAD
Apr 18 23:58:17 PC1 systemd[1]: Stopping Set Up Additional Binary Formats…
Apr 18 23:58:17 PC1 systemd[1]: systemd-sysctl.service: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Stopped Apply Kernel Variables.
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-sysctl comm=“systemd” exe=
“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-modules-load comm=“systemd
" exe=”/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Apr 18 23:58:17 PC1 systemd[1]: systemd-modules-load.service: Succeeded.
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-update-done comm=“systemd”
exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=ldconfig comm=“systemd” exe="/usr/
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-journal-catalog-update com
m=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Apr 18 23:58:17 PC1 systemd[1]: Stopped Load Kernel Modules.
Apr 18 23:58:17 PC1 systemd[1]: Stopping Network Time Synchronization…
Apr 18 23:58:17 PC1 systemd[1]: systemd-update-done.service: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Stopped Update is Completed.
Apr 18 23:58:17 PC1 systemd[1]: ldconfig.service: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Stopped Rebuild Dynamic Linker Cache.
Apr 18 23:58:17 PC1 systemd[1]: systemd-journal-catalog-update.service: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Stopped Rebuild Journal Catalog.
Apr 18 23:58:17 PC1 systemd[1]: Stopping Update UTMP about System Boot/Shutdown…
Apr 18 23:58:17 PC1 audit[24447]: SYSTEM_SHUTDOWN pid=24447 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=’ comm=“systemd-update-utmp”
exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success’
Apr 18 23:58:17 PC1 systemd[1]: systemd-update-utmp.service: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Stopped Update UTMP about System Boot/Shutdown.
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-update-utmp comm=“systemd”
Apr 18 23:58:17 PC1 systemd[1]: systemd-binfmt.service: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Stopped Set Up Additional Binary Formats.
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-binfmt comm=“systemd” exe=
Apr 18 23:58:17 PC1 systemd[1]: systemd-timesyncd.service: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Stopped Network Time Synchronization.
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-timesyncd comm=“systemd” e
Apr 18 23:58:17 PC1 systemd[1]: systemd-tmpfiles-setup.service: Succeeded.
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-tmpfiles-setup comm=“syste
Apr 18 23:58:17 PC1 systemd[1]: Stopped Create Volatile Files and Directories.
Apr 18 23:58:17 PC1 systemd[1]: Stopped target Local File Systems.
Apr 18 23:58:17 PC1 systemd[1]: Unmounting /boot/efi…
Apr 18 23:58:17 PC1 systemd[1]: Unmounting /home…
Apr 18 23:58:17 PC1 systemd[1]: Unmounting Temporary Directory (/tmp)…
Apr 18 23:58:17 PC1 systemd[1]: boot-efi.mount: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Unmounted /boot/efi.
Apr 18 23:58:17 PC1 systemd[1]: systemd-fsck@dev-disk-by\x2duuid-8351\x2d5ABE.service: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Stopped File System Check on /dev/disk/by-uuid/8351-5ABE.
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-fsck@dev-disk-by\x2duuid-8
351\x2d5ABE comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Apr 18 23:58:17 PC1 systemd[1]: tmp.mount: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Unmounted Temporary Directory (/tmp).
Apr 18 23:58:17 PC1 systemd[1]: Stopped target Swap.
Apr 18 23:58:17 PC1 systemd[1]: home.mount: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Unmounted /home.
Apr 18 23:58:17 PC1 systemd[1]: Reached target Unmount All Filesystems.
Apr 18 23:58:17 PC1 systemd[1]: systemd-fsck@dev-disk-by\x2duuid-1f6d9862\x2d35ec\x2d4f52\x2d916d\x2df17bb701ab97.service: Succeeded.
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-fsck@dev-disk-by\x2duuid-1
f6d9862\x2d35ec\x2d4f52\x2d916d\x2df17bb701ab97 comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Apr 18 23:58:17 PC1 systemd[1]: Stopped File System Check on /dev/disk/by-uuid/1f6d9862-35ec-4f52-916d-f17bb701ab97.
Apr 18 23:58:17 PC1 systemd[1]: Removed slice system-systemd\x2dfsck.slice.
Apr 18 23:58:17 PC1 systemd[1]: Stopped target Local File Systems (Pre).
Apr 18 23:58:17 PC1 systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
Apr 18 23:58:17 PC1 systemd[1]: systemd-tmpfiles-setup-dev.service: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Stopped Create Static Device Nodes in /dev.
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-tmpfiles-setup-dev comm=“s
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-sysusers comm=“systemd” ex
Apr 18 23:58:17 PC1 systemd[1]: systemd-sysusers.service: Succeeded.
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-remount-fs comm=“systemd”
Apr 18 23:58:17 PC1 systemd[1]: Stopped Create System Users.
Apr 18 23:58:17 PC1 systemd[1]: systemd-remount-fs.service: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Stopped Remount Root and Kernel File Systems.
Apr 18 23:58:17 PC1 systemd[1]: lvm2-monitor.service: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=lvm2-monitor comm=“systemd” exe="/
Apr 18 23:58:17 PC1 systemd[1]: Reached target Shutdown.
Apr 18 23:58:17 PC1 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-reboot comm=“systemd” exe
Apr 18 23:58:17 PC1 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-reboot comm=“systemd” exe=
Apr 18 23:58:17 PC1 systemd[1]: Reached target Final Step.
Apr 18 23:58:17 PC1 systemd[1]: systemd-reboot.service: Succeeded.
Apr 18 23:58:17 PC1 systemd[1]: Finished Reboot.
Apr 18 23:58:17 PC1 systemd[1]: Reached target Reboot.
Apr 18 23:58:17 PC1 systemd[1]: Shutting down.
Apr 18 23:58:17 PC1 audit: BPF prog-id=4 op=UNLOAD
Apr 18 23:58:17 PC1 audit: BPF prog-id=3 op=UNLOAD
Apr 18 23:58:17 PC1 audit: BPF prog-id=6 op=UNLOAD
Apr 18 23:58:17 PC1 audit: BPF prog-id=5 op=UNLOAD
Apr 18 23:58:17 PC1 systemd[1]: Using hardware watchdog ‘SP5100 TCO timer’, version 0, device /dev/watchdog
Apr 18 23:58:17 PC1 systemd[1]: Set hardware watchdog to 10min.
Apr 18 23:58:17 PC1 kernel: watchdog: watchdog0: watchdog did not stop!
Apr 18 23:58:17 PC1 systemd-shutdown[1]: Syncing filesystems and block devices.
Apr 18 23:58:17 PC1 systemd-shutdown[1]: Sending SIGTERM to remaining processes…
Apr 18 23:58:17 PC1 systemd-journald[300]: Journal stopped
inxi
[holger@PC1 ~]$ inxi --full --admin --verbosity=7 --filter --no-host
System: Kernel: 5.10.30-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=c2a93eb3-45d6-4b4d-a9e3-8d50ddb7109a rw quiet apparmor=1
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop System: Gigabyte product: AX370-Gaming K5 v: N/A serial:
Mobo: Gigabyte model: AX370-Gaming K5-CF v: x.x serial: UEFI: American Megatrends v: F50d date: 07/02/2020
Memory: RAM: total: 15.64 GiB used: 2.86 GiB (18.3%)
CPU: Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 8 stepping: 2
microcode: 800820D cache: L2: 3 MiB bogomips: 81590
Speed: 1377 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz): 1: 1377 2: 1377 3: 1556 4: 3898 5: 1377
6: 1562 7: 1560 8: 3900 9: 1377 10: 1377 11: 1377 12: 1560
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext clflush clflushopt clzero cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fpu
fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr
mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep sev
sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA TU104 [GeForce RTX 2080] vendor: Gigabyte driver: nvidia v: 460.67 alternate: nouveau,nvidia_drm
bus-ID: 08:00.0 chip-ID: 10de:1e82 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 139 s-size: 702x392mm (27.6x15.4") s-diag: 804mm (31.7")
Monitor-1: DP-2 res: 3840x2160 hz: 60 dpi: 140 size: 698x393mm (27.5x15.5") diag: 801mm (31.5")
OpenGL: renderer: GeForce RTX 2080/PCIe/SSE2 v: 4.6.0 NVIDIA 460.67 direct render: Yes
Audio: Device-1: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:10f8
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.10.30-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.25 running: no
Network: Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac:
IP v4: type: noprefixroute scope: global broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
WAN IP:
Bluetooth: Message: No bluetooth data found.
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 3.43 TiB used: 21.62 GiB (0.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: rev: 32B3T8EA temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: rev: 1B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: rev: 1A02 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD10EZRZ-00HTKB0 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: rev: 1A01
ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST500DM002-1BD142 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: rev: KC65 scheme: GPT
Optical-1: /dev/sr0 vendor: PLEXTOR model: DVDR PX-712A rev: 1.09 dev-links: cdrom
Features: speed: 94 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r state: running
Optical-2: /dev/sr1 vendor: HL-DT-ST model: DVDRAM GSA-H62N rev: CL01 dev-links: N/A
Features: speed: 48 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
Partition: ID-1: / raw-size: 156.25 GiB size: 152.74 GiB (97.75%) used: 15.8 GiB (10.3%) fs: ext4 dev: /dev/nvme0n1p2
maj-min: 259:2 label: System uuid: c2a93eb3-45d6-4b4d-a9e3-8d50ddb7109a
ID-2: /boot/efi raw-size: 450 MiB size: 449.1 MiB (99.80%) used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1 label: UEFI BOOT uuid: 8351-5ABE
ID-3: /home raw-size: 781.25 GiB size: 767.92 GiB (98.29%) used: 5.82 GiB (0.8%) fs: ext4 dev: /dev/nvme0n1p3
maj-min: 259:3 label: Home uuid: 1f6d9862-35ec-4f52-916d-f17bb701ab97
Swap: Alert: No swap data was found.
Unmounted: ID-1: /dev/sda1 maj-min: 8:1 size: 476 MiB fs: vfat label: N/A uuid: EC98-AFB5
ID-2: /dev/sda2 maj-min: 8:2 size: 214.2 GiB fs: ext4 label: N/A uuid: 560c6537-2d4f-4b0a-a6ba-b51da1f18cb5
ID-3: /dev/sda3 maj-min: 8:3 size: 7.45 GiB fs: swap label: N/A uuid: c0d28562-5f5e-4d72-9ec8-57c649a8d491
ID-4: /dev/sdb1 maj-min: 8:17 size: 684.37 GiB fs: ext4 label: N/A uuid: 6036c0c4-09b3-4ddd-8d8b-c923e309e334
ID-5: /dev/sdb2 maj-min: 8:18 size: 247.14 GiB fs: ext4 label: N/A uuid: feee53c9-9649-4546-bac3-ceca698ab39a
ID-6: /dev/sdd1 maj-min: 8:49 size: 499 MiB fs: ntfs label: N/A uuid: 8EA803DFA803C4A5
ID-7: /dev/sdd2 maj-min: 8:50 size: 100 MiB fs: vfat label: N/A uuid: 08A9-D2FF
ID-8: /dev/sdd3 maj-min: 8:51 size: 16 MiB fs: label: N/A uuid: N/A
ID-9: /dev/sdd4 maj-min: 8:52 size: 465.16 GiB fs: ntfs label: N/A uuid: 9CF2BAA8F2BA85D4
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 1-1:2 info: Belkin ports: 4 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 050d:0231 class-ID: 0900
Device-1: 1-7:3 info: Logitech LX-700 Cordless Desktop Receiver type: Keyboard,Mouse driver: logitech,usbhid
interfaces: 2 rev: 1.1 speed: 1.5 Mb/s power: 98mA chip-ID: 046d:c512 class-ID: 0301
Device-2: 1-13:4 info: Logitech F710 Wireless Gamepad [XInput Mode] type: driver: xpad
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c21f class-ID: ff00 serial:
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-8: 7-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-9: 8-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Sensors: System Temperatures: cpu: 28.1 C mobo: 0 C gpu: nvidia temp: 38 C
Info: Processes: 251 Uptime: 17m wakeups: 1 Init: systemd v: 247 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0
Packages: pacman: 1272 lib: 329 flatpak: 0 Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.04
Sudo Journalctl -b -1
holger@PC1 ~]$ sudo journalctl --boot=-1 | tail --lines=100
[sudo] Passwort für holger:
[holger@PC1 ~]$ sudo journalctl -b -1
– Journal begins at Fri 2021-04-16 21:20:18 CEST, ends at Mon 2021-04-19 01:56:29 CEST. –
Apr 18 19:48:33 PC1 kernel: Linux version 5.10.30-1-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP Wed Apr 14 >
Apr 18 19:48:33 PC1 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=c2a93eb3-45d6-4b4d-a9e3-8d50ddb7109a rw quiet apparmor=1 >
Apr 18 19:48:33 PC1 kernel: x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
Apr 18 19:48:33 PC1 kernel: x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
Apr 18 19:48:33 PC1 kernel: x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
Apr 18 19:48:33 PC1 kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Apr 18 19:48:33 PC1 kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using ‘compacted’ format.
Apr 18 19:48:33 PC1 kernel: BIOS-provided physical RAM map:
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000009e01fff] usable
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x0000000009e02000-0x0000000009ffffff] reserved
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x000000000a200000-0x000000000a20afff] ACPI NVS
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x000000000a20b000-0x000000000affffff] usable
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x000000000b020000-0x00000000db355fff] usable
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x00000000db356000-0x00000000db4befff] reserved
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x00000000db4bf000-0x00000000db641fff] usable
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x00000000db642000-0x00000000dba5afff] ACPI NVS
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x00000000dba5b000-0x00000000dca69fff] reserved
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x00000000dca6a000-0x00000000dcafafff] type 20
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x00000000dcafb000-0x00000000deffffff] usable
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x00000000df000000-0x00000000dfffffff] reserved
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
Apr 18 19:48:33 PC1 kernel: BIOS-e820: [mem 0x00000000fd000000-0x00000000ffffffff] reserved
