KenM1
January 7, 2023, 2:59am
#1
After installing a gtx 4080 gpu, my system is exhibiting odd behaviors. When booting I enter my password to unlock the encryption on the home partition, but the entry is no longer echoed back to me. It does still unlock, but the logon screen and plasma are scaled wrong. Everything is zoomed in too close to use. The application launcher covers the entire screen.
mhwd
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.11.04 false PCI
inxi -G: Graphics: Device-1: NVIDIA AD103 [GeForce RTX 4080] driver: nvidia v: 525.60.11 Device-2: AMD Raphael driver: amdgpu v: kernel Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7 driver: N/A resolution: 1: 1920x1080~144Hz 2: 1920x1080~60Hz API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce RTX 4080/PCIe/SSE2
I’ve tried it with video-nvidia and video-hybrid-amd-nvidia-prime, it initially worked with the hybrid setup, then after reboot, the scaling problem happened.
The second tty is still stuck on the enter passphrase message although the partition is mounted.
Any ideas? Thanks.
Edit: I just tested booting into the installer image. Everything looked fine in there.
brahma
January 7, 2023, 8:40am
#2
post full system info:
inxi -Fazv7
mhwd -l -li
use formatting, click this icon in editor: </>
KenM1
January 7, 2023, 6:17pm
#3
inxi -Fazv7:
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=e5a92876-e392-4fb1-80a8-0653a7fa9230 rw rootflags=subvol=@
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: PRIME X670E-PRO WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0821
date: 11/15/2022
RAM: total: 30.5 GiB used: 3.62 GiB (11.9%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 9 7950X bits: 64 type: MT MCP arch: Zen 4 gen: 5
level: v4 note: check built: 2022 process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3187 high: 4500 min/max: 3000/5880 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3000 2: 4500
3: 3000 4: 3000 5: 3000 6: 3000 7: 3000 8: 3000 9: 3000 10: 3000 11: 3000
12: 4500 13: 3000 14: 3000 15: 3000 16: 3000 17: 3000 18: 3000 19: 3000
20: 3000 21: 3000 22: 3000 23: 3000 24: 3000 25: 4500 26: 4500 27: 3000
28: 3000 29: 3000 30: 3000 31: 3000 32: 3000 bogomips: 287574
Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avic avx
avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
fxsr_opt gfni ht hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1
xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA AD103 [GeForce RTX 4080] vendor: Gigabyte driver: nvidia
v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022-23+ pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2704 class-ID: 0300
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1,HDMI-A-1
bus-ID: 11:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 36.0 C
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x342mm (47.40x13.46")
s-diag: 1252mm (49.28")
Monitor-1: DP-0 pos: primary,left res: 1920x1080 hz: 144 dpi: 81
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
Monitor-2: HDMI-0 pos: right res: 1920x1080 hz: 60 dpi: 305
size: 160x90mm (6.3x3.54") diag: 184mm (7.23") modes: N/A
4080/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bb
class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 11:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 11:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 09:00.0
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0a:00.0 chip-ID: 14c3:0608
class-ID: 0280
IF: wlp10s0 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-2:2 chip-ID: 0a12:0001 class-ID: e001
Report: rfkill ID: hci1 rfk-id: 1 state: up address: see --recommends
Device-2: MediaTek Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-2:2 chip-ID: 0e8d:0608 class-ID: e001 serial: <filter>
Report: ID: hci0 rfk-id: 0 state: up address: N/A
Device-1: luks-e7e85d95-8163-45a5-b169-a7fcc1a191bc maj-min: 254:0
type: LUKS dm: dm-0 size: 1.82 TiB
Components:
p-1: nvme1n1p1 maj-min: 259:1 size: 1.82 TiB
Local Storage: total: 3.18 TiB used: 1.15 TiB (36.0%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital
model: WD BLACK SN770 250GB size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 731030WD temp: 30.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7 temp: 33.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EADS-00M2B0
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 0A01 scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS250G1B0A-00H9H0 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 10WD
scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD-RAM GH22NS30 rev: 2.00
dev-links: cdrom
ID-1: / raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
used: 146.79 GiB (63.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
label: N/A uuid: e5a92876-e392-4fb1-80a8-0653a7fa9230
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3 label: N/A
uuid: F455-CF0A
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 1 TiB (55.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-e7e85d95-8163-45a5-b169-a7fcc1a191bc label: N/A
uuid: be37ecf1-ac33-42df-be21-12835b83df40
ID-4: /var/cache raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
ID-5: /var/log raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
ID-1: /dev/sda1 maj-min: 8:1 size: 191.92 GiB fs: ntfs label: N/A
uuid: 01CA8D52FA4D3900
ID-2: /dev/sda2 maj-min: 8:2 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda5 maj-min: 8:5 size: 468.17 GiB fs: ntfs label: N/A
uuid: 01CA8D572D28F310
ID-4: /dev/sda6 maj-min: 8:6 size: 271.41 GiB fs: ntfs label: N/A
uuid: 01CA8D5BF2F89C40
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-2:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Device-2: 1-4:3 info: Logitech Gaming Mouse G300 type: Mouse,Keyboard
power: 200mA chip-ID: 046d:c246 class-ID: 0300
Device-3: 1-5:4 info: SYSGRATION Wired Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 05b8:3279 class-ID: 0300
Device-4: 1-8:5 info: Corsair H150iELITE type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 1b1c:0c37 class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 5 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-2:2 info: MediaTek Wireless_Device type: Bluetooth
driver: btusb interfaces: 3 rev: 2.1 speed: 480 Mb/s power: 100mA
Hub-4: 3-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-5: 3-5.3:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-5.3.1:6 info: Genesys Logic Multislot Card Reader/Writer
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 05e3:0716 class-ID: 0806
serial: <filter>
Device-2: 3-8:4 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:19af class-ID: 0300 serial: <filter>
Hub-6: 4-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-9: 7-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 7-2:2 info: Logitech F310 Gamepad [XInput Mode]
type: <vendor specific> driver: xpad interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 046d:c21d class-ID: ff00 serial: <filter>
Hub-10: 8-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-11: 9-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-12: 10-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 42.5 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 39 C fan: 0% device: amdgpu
temp: 36.0 C
Processes: 564 Uptime: 26m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1645 pm: pacman pkgs: 1627 libs: 462 tools: pamac,yay pm: flatpak
pkgs: 18 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.24
mhwd -l -li:
video-hybrid-amd-nvidia-prime 2021.11.04 false PCI
> 0000:01:00.0 (0300:10de:2704) Display controller nVidia Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:11:00.0 (0300:1002:164e) Display controller ATI Technologies Inc:
brahma
January 7, 2023, 7:06pm
#4
post also output from:
ls /etc/modprobe.d
find /etc/X11/ -name "*.conf"
create a new test user in system settings, reboot and log in with the test user and see if it has also the same issues
KenM1
January 7, 2023, 9:53pm
#5
ls /etc/modprobe.d
mhwd-gpu.conf
/etc/X11/mhwd.d/nvidia.conf
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
/etc/X11/xorg.conf.d/nvidia.conf
/etc/X11/xorg.conf.d/90-mhwd.conf
/etc/X11/xorg.conf
Test user has the same problem. Disconnection of the second monitor does fix the problem. I reconnected the monitor after logging in and reconfigured it. Then it works properly, but after rebooting the problem returns. Also the password input is being shown on the AMD graphics.
brahma
January 8, 2023, 7:45am
#6
remove the following configs:
sudo rm /etc/X11/xorg.conf.d/nvidia.conf
reboot and see if it helped
KenM1
January 8, 2023, 3:12pm
#7
Temporary success. On first reboot it worked, but on second reboot the problem returned.
brahma
January 8, 2023, 4:21pm
#8
check again if there wasnt some config recreated:
if not, delete also this:
sudo rm /etc/X11/mhwd.d/nvidia.conf
reboot
KenM1
January 8, 2023, 6:02pm
#9
No files recreated. I have a workaround solution. I used a display port to hdmi adapter to connect the second monitor. After creating a new xorg.conf with nvidia-settings the problem is gone. Confirmed with multiple reboots.
Thank you for all your help brahma.
brahma
January 8, 2023, 6:06pm
#10
excellent … so mark your post as a solution
system
Closed
January 11, 2023, 8:07am
#11
