Good day all,
I am using Manjaro xfce
as mentioned in the subject I own a GT 190 pen display by Huion. It is old and isnt even sold anymore.
I have a main HD monitor and the GT 190 as a second monitor and drawing monitor
The two main problems I had was resolution on that thing and the Input. when i try to draw it projects on both monitors which is annoying and I am not sure how to fix it.
I figured out how to change the resolution to a desired 1440 x 900 with xrandr recently but the issue of projection is still there.
I tried xwacom --list devices but the Pen Display wont show up there
I tried the Digimend kernel drivers a youtube video
but i got stuck at the sudo make dkms install command, tried to install dkms manually but it didn’t work still.
xinput does show several “Tablet Monitor Pad” but i dunno how to read them.
A solution i had on PopOS was : xsetwacom set “Tablet Monitor Pen stylus” MapToOutput HDMI-0 but it says that “Tablet Monitor Pen stylus” wasn’t found.
after consulting a friend I went to /usr/share/X11/xorg.conf.d
and found 50-digimend.conf and 70-wacom.conf
They had sections for the huion tablets with wacom drivers already and the USB"ID 256c:006e" my Tablet Monitor showed with lsusb,
Any idea where to go next? The main problem seems to be projection of the drawing area onto two monitors instead of one
