I install e-sword 13 from the website and install wine, when I try to open it, it doesn’t work, so I go back to the page and follow the instructions, thi time for the package, Linux-12:
I removed e-sword-13, as far as i can see … (the command ‘locate’ do not work for me here).
install winetricks and run winetricks -q wmp11 (as it is recomended).
Everything seems to be fine … but it doesn’t download anything, the options to download, bibles, etc are frizzy, I guess I’m missing something to do in Manjaro, wine?.
Important note 2: Before going down the path of trying to install Windows software on a GNU/Linux machine via WINE, check the distro’s package manager (in the case of Manjaro, Pamac) to see if an alternative that works natively on Linux is available:
There isn’t much info on the web, and WineHQ - e-Sword doesn’t have any test results for recent versions of e-Sword, however this WineHQ forum thread may offer some help: eSword on Linux - WineHQ Forums
Perhaps Xiphos Bible Guide, which is suggested in the WineHQ forum thread & also on the WineHQ e-Sword page (Xiphos was formerly known as GnomeSword), and is available from the Manjaro repositories, might be a solution?
[alnone@alnone-inspiron3583 ~]$ LANG=C locate wine
locate: can not stat () `/var/lib/mlocate/mlocate.db': No such file or directory
*I tried wine-staging, nothing … and now i will try with wine-staging-git
When installing wine-staging the system warns to remove wine due to incompatibility, as it did not work, I went for wine-staging-git and right now it is compiling … about an hour ago … I will come back tomorrow, thanks for your indications.
Indeed. You most likely wasted your time because you misunderstood what your package manager and myself just told you. Well, unless of course the bleeding edge wine-staging-git package fixes something. However, you don’t know if it does since from what you said, you haven’t even tried wine-staging yet.
Keep in mind you are the package maintainer of any AUR package you install. You should always use repo packages over AUR packages. As I’ve seen many times before, users will completely forget they installed an AUR package and wonder why things aren’t working after an update.
– Sorry, it is probably “my English”, I use Deepl or Google translator.
I meant it didn’t work (wine-staging)
*I understand about the risk of using packages outside of the recommended … but as long as the system does not offer them … what other alternative is there?.
