Hi. I tried the deepin installer and the main bug I notice is a strange one. While in manjaro gnome (or in deepin official) the ssid wifi network is immediately shown on the list of available networks to connect, in deepin manjaro the available network are only the weakest ones and not the strongest ones… so my wifi is not shown. no connection , no updates and so the installer is useless.
have you a workaround? am I the only one with this problem?
I faced this problem too, I solved by choosing “Connect to a hidden network” or something similar and typing SSID and password.
Facing the same problem when trying the live USB. Never had any issues with other Manjaro’s or other distros.
