Hi
this is my first post here, I am no native English speaker and and I have installed Manjaro XFCE on the SSD of my Raspi 4 2 hours ago…at least, it boots…
I installed via the Raspi Imager, which offered me a Manjaro Image (XFCE), which I choose.
Copying and boot was smooth, intro (system setup) works fine.
I connected via SSH from my GENTOO Linux PC to my Raspi 4, logged in an started the update of the system. That’s where the problems start…
I got a lot of certificate errors like “certificate validation failed”. I searched the internet for a solution and found some reports of similiar effects, but all were old.
I did a pacman-mirrors --geoip && sudo pacman -Syyu
and got tons of messages like:
can’t include the error message, because otherwise this post is rejected
Then, trying to build my local clone of the wezterm github repo I got:
error: failed to download from (URL HERE)
(LINK obfuscated by me…)
Caused by:
[60] SSL peer certificate or SSH remote key was not OK (SSL certificate problem: certificate is not yet valid)
which is interesting in so far, that exactly the same procedure works fine on my GENTOO Linux - so I think it is not a problem of the server from which I try to fetch the code.
How can I fix these certificate related problems?
Cheers!
mcc
PS: All URLs removed - otherwise my post would not be accepted
