Still looking for hints for this problem!
Some more output from my machine. This time dmesg:
[ 0.000000] microcode: microcode updated early to revision 0xde, date = 2020-05-25
[ 0.000000] Linux version 5.9.11-3-MANJARO (builduser@development) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP PREEMPT Sat Nov 28 09:08:57 UTC 2020
[ 0.000000] Command line: BOOT_IMAGE=/vmlinuz-5.9-x86_64 root=UUID=83300378-9e6b-42ab-a364-88a344b99ce3 rw quiet apparmor=1 security=apparmor udev.log_priority=3 i915.enable_dpcd_backlight=0
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ebff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009ec00-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000005a05cfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000005a05d000-0x000000005a05dfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000005a05e000-0x000000006d7b3fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000006d7b4000-0x000000006d830fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000006d831000-0x000000006dcf7fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000006dcf8000-0x0000000077ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000078000000-0x0000000078dfffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000078e00000-0x000000007f7fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000027c7fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 3.1.1 present.
[ 0.000000] DMI: Dell Inc. XPS 15 9570/0JVFJ2, BIOS 1.16.2 04/21/2020
[ 0.000000] tsc: Detected 2300.000 MHz processor
[ 0.000516] tsc: Detected 2299.968 MHz TSC
[ 0.000516] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000517] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000521] last_pfn = 0x27c800 max_arch_pfn = 0x400000000
[ 0.000524] MTRR default type: write-back
[ 0.000524] MTRR fixed ranges enabled:
[ 0.000525] 00000-9FFFF write-back
[ 0.000526] A0000-BFFFF uncachable
[ 0.000526] C0000-FFFFF write-protect
[ 0.000527] MTRR variable ranges enabled:
[ 0.000528] 0 base 0080000000 mask 7F80000000 uncachable
[ 0.000528] 1 base 007C000000 mask 7FFC000000 uncachable
[ 0.000529] 2 base 007B000000 mask 7FFF000000 uncachable
[ 0.000529] 3 disabled
[ 0.000530] 4 disabled
[ 0.000530] 5 disabled
[ 0.000530] 6 disabled
[ 0.000530] 7 disabled
[ 0.000531] 8 disabled
[ 0.000531] 9 disabled
[ 0.000864] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001032] last_pfn = 0x78e00 max_arch_pfn = 0x400000000
[ 0.006926] found SMP MP-table at [mem 0x000fd040-0x000fd04f]
[ 0.006981] check: Scanning 1 areas for low memory corruption
[ 0.006984] Using GB pages for direct mapping
[ 0.007221] RAMDISK: [mem 0x36659000-0x37323fff]
[ 0.007229] ACPI: Early table checksum verification disabled
[ 0.007231] ACPI: RSDP 0x00000000000E8D80 000024 (v02 DELL )
[ 0.007233] ACPI: XSDT 0x000000006D7CD0D0 000124 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.007237] ACPI: FACP 0x000000006D80F018 000114 (v06 DELL CBX3 01072009 AMI 00010013)
[ 0.007240] ACPI: DSDT 0x000000006D7CD288 041D8B (v02 DELL CBX3 01072009 INTL 20160527)
[ 0.007242] ACPI: FACS 0x000000006DCF6C00 000040
[ 0.007244] ACPI: APIC 0x000000006D80F130 0000BC (v04 DELL CBX3 01072009 AMI 00010013)
[ 0.007246] ACPI: FPDT 0x000000006D80F1F0 000044 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.007247] ACPI: FIDT 0x000000006D80F238 00009C (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.007249] ACPI: MCFG 0x000000006D80F2D8 00003C (v01 DELL CBX3 01072009 MSFT 00000097)
[ 0.007250] ACPI: SSDT 0x000000006D80F318 000761 (v01 SataRe SataTabl 00001000 INTL 20160527)
[ 0.007252] ACPI: SSDT 0x000000006D80FA80 0017DF (v02 CpuRef CpuSsdt 00003000 INTL 20160527)
[ 0.007254] ACPI: BOOT 0x000000006D811260 000028 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.007256] ACPI: SSDT 0x000000006D811288 001336 (v02 SaSsdt SaSsdt 00003000 INTL 20160527)
[ 0.007257] ACPI: SSDT 0x000000006D8125C0 002640 (v02 PegSsd PegSsdt 00001000 INTL 20160527)
[ 0.007259] ACPI: HPET 0x000000006D814C00 000038 (v01 INTEL CBX3 00000002 01000013)
[ 0.007261] ACPI: SSDT 0x000000006D814C38 002949 (v02 INTEL xh_cfhd4 00000000 INTL 20160527)
[ 0.007262] ACPI: UEFI 0x000000006D817588 000048 (v01 DELL\x CBX3 00000002 01000013)
[ 0.007264] ACPI: LPIT 0x000000006D8175D0 00005C (v01 INTEL CBX3 00000002 01000013)
[ 0.007266] ACPI: SSDT 0x000000006D817630 0027DE (v02 INTEL PtidDevc 00001000 INTL 20160527)
[ 0.007267] ACPI: SSDT 0x000000006D819E10 000FFE (v02 INTEL TbtTypeC 00000000 INTL 20160527)
[ 0.007269] ACPI: DBGP 0x000000006D81AE10 000034 (v01 DELL\x CBX3 00000002 01000013)
[ 0.007271] ACPI: DBG2 0x000000006D81AE48 000054 (v00 DELL\x CBX3 00000002 01000013)
[ 0.007272] ACPI: SSDT 0x000000006D81AEA0 0007DC (v02 DELL\x UsbCTabl 00001000 INTL 20160527)
[ 0.007274] ACPI: SSDT 0x000000006D81B680 00652E (v02 DptfTa DptfTabl 00001000 INTL 20160527)
[ 0.007276] ACPI: MSDM 0x000000006D821BB0 000055 (v03 DELL CBX3 06222004 AMI 00010013)
[ 0.007277] ACPI: SLIC 0x000000006D821C08 000176 (v03 DELL CBX3 01072009 MSFT 00010013)
[ 0.007279] ACPI: SSDT 0x000000006D821D80 000144 (v02 Intel ADebTabl 00001000 INTL 20160527)
[ 0.007281] ACPI: SSDT 0x000000006D821EC8 0000AE (v02 SgRef SgPeg 00001000 INTL 20160527)
[ 0.007283] ACPI: DMAR 0x000000006D821F78 0000A8 (v01 INTEL EDK2 00000002 01000013)
[ 0.007284] ACPI: NHLT 0x000000006D822020 00002D (v00 INTEL EDK2 00000002 01000013)
[ 0.007286] ACPI: BGRT 0x000000006D822050 000038 (v00 \xf3\xee 01072009 AMI 00010013)
[ 0.007288] ACPI: UEFI 0x000000006D822088 00063A (v01 INTEL RstSataE 00000000 ?? 00000000)
[ 0.007289] ACPI: UEFI 0x000000006D8226C8 00005C (v01 INTEL RstSataV 00000000 ?? 00000000)
[ 0.007291] ACPI: TPM2 0x000000006D822728 000034 (v04 DELL\x CBX3 00000001 AMI 00000000)
[ 0.007293] ACPI: ASF! 0x000000006D822760 000074 (v32 DELL\x CBX3 00000002 01000013)
[ 0.007294] ACPI: SSDT 0x000000006D8227D8 001EF0 (v01 OptRef OptTabl 00001000 INTL 20160527)
[ 0.007300] ACPI: Local APIC address 0xfee00000
[ 0.007555] No NUMA configuration found
[ 0.007555] Faking a node at [mem 0x0000000000000000-0x000000027c7fffff]
[ 0.007557] NODE_DATA(0) allocated [mem 0x27c7fa000-0x27c7fdfff]
[ 0.007574] Zone ranges:
[ 0.007575] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.007575] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.007576] Normal [mem 0x0000000100000000-0x000000027c7fffff]
[ 0.007577] Device empty
[ 0.007577] Movable zone start for each node
[ 0.007578] Early memory node ranges
[ 0.007578] node 0: [mem 0x0000000000001000-0x000000000009dfff]
[ 0.007579] node 0: [mem 0x0000000000100000-0x000000005a05cfff]
[ 0.007579] node 0: [mem 0x0000000078000000-0x0000000078dfffff]
[ 0.007580] node 0: [mem 0x0000000100000000-0x000000027c7fffff]
[ 0.008003] Zeroed struct page in unavailable ranges: 68102 pages
[ 0.008004] Initmem setup node 0 [mem 0x0000000000001000-0x000000027c7fffff]
[ 0.008005] On node 0 totalpages: 1930746
[ 0.008005] DMA zone: 64 pages used for memmap
[ 0.008006] DMA zone: 21 pages reserved
[ 0.008006] DMA zone: 3997 pages, LIFO batch:0
[ 0.008022] DMA32 zone: 5754 pages used for memmap
[ 0.008022] DMA32 zone: 368221 pages, LIFO batch:63
[ 0.009633] Normal zone: 24352 pages used for memmap
[ 0.009634] Normal zone: 1558528 pages, LIFO batch:63
[ 0.016558] Reserving Intel graphics memory at [mem 0x7b800000-0x7f7fffff]
[ 0.017446] ACPI: PM-Timer IO Port: 0x1808
[ 0.017447] ACPI: Local APIC address 0xfee00000
[ 0.017451] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.017451] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.017452] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.017452] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.017452] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.017453] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.017453] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.017453] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.017518] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.017519] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.017520] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.017521] ACPI: IRQ0 used by override.
[ 0.017521] ACPI: IRQ9 used by override.
[ 0.017522] Using ACPI (MADT) for SMP configuration information
[ 0.017523] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.017526] TSC deadline timer available
[ 0.017527] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.017541] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.017542] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009efff]
[ 0.017543] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.017543] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.017543] PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.017544] PM: hibernation: Registered nosave memory: [mem 0x5a05d000-0x5a05dfff]
[ 0.017545] PM: hibernation: Registered nosave memory: [mem 0x5a05e000-0x6d7b3fff]
[ 0.017545] PM: hibernation: Registered nosave memory: [mem 0x6d7b4000-0x6d830fff]
[ 0.017545] PM: hibernation: Registered nosave memory: [mem 0x6d831000-0x6dcf7fff]
[ 0.017546] PM: hibernation: Registered nosave memory: [mem 0x6dcf8000-0x77ffffff]
[ 0.017547] PM: hibernation: Registered nosave memory: [mem 0x78e00000-0x7f7fffff]
[ 0.017547] PM: hibernation: Registered nosave memory: [mem 0x7f800000-0xefffffff]
[ 0.017547] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xf7ffffff]
[ 0.017548] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfdffffff]
[ 0.017548] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.017548] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[ 0.017549] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.017549] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[ 0.017549] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.017550] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.017550] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.017551] [mem 0x7f800000-0xefffffff] available for PCI devices
[ 0.017552] Booting paravirtualized kernel on bare hardware
[ 0.017554] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.021319] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
[ 0.021434] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u262144
[ 0.021438] pcpu-alloc: s192512 r8192 d28672 u262144 alloc=1*2097152
[ 0.021438] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.021450] Built 1 zonelists, mobility grouping on. Total pages: 1900555
[ 0.021450] Policy zone: Normal
[ 0.021451] Kernel command line: BOOT_IMAGE=/vmlinuz-5.9-x86_64 root=UUID=83300378-9e6b-42ab-a364-88a344b99ce3 rw quiet apparmor=1 security=apparmor udev.log_priority=3 i915.enable_dpcd_backlight=0
[ 0.021776] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.021930] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.021985] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ 0.035737] Memory: 7471716K/7722984K available (14339K kernel code, 1529K rwdata, 4760K rodata, 1664K init, 2888K bss, 251008K reserved, 0K cma-reserved)
[ 0.035743] random: get_random_u64 called from __kmem_cache_create+0x26/0x520 with crng_init=0
[ 0.035834] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.035844] Kernel/User page tables isolation: enabled
[ 0.035855] ftrace: allocating 41080 entries in 161 pages
[ 0.046512] ftrace: allocated 161 pages with 3 groups
[ 0.046592] rcu: Preemptible hierarchical RCU implementation.
[ 0.046592] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.046593] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[ 0.046593] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.046594] Trampoline variant of Tasks RCU enabled.
[ 0.046594] Rude variant of Tasks RCU enabled.
[ 0.046595] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.046595] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.048762] NR_IRQS: 20736, nr_irqs: 2048, preallocated irqs: 16
[ 0.049371] Console: colour dummy device 80x25
[ 0.049374] printk: console [tty0] enabled
[ 0.049385] ACPI: Core revision 20200717
[ 0.049834] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.049976] APIC: Switch to symmetric I/O mode setup
[ 0.049978] DMAR: Host address width 39
[ 0.049979] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.049984] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[ 0.049984] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.049987] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.049988] DMAR: RMRR base: 0x0000006f846000 end: 0x0000006fa8ffff
[ 0.049988] DMAR: RMRR base: 0x0000007b000000 end: 0x0000007f7fffff
[ 0.049990] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.049990] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.049991] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.053069] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.053070] x2apic enabled
[ 0.053101] Switched APIC routing to cluster x2apic.
[ 0.062286] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.076641] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x212717146a7, max_idle_ns: 440795291431 ns
[ 0.076644] Calibrating delay loop (skipped), value calculated using timer frequency.. 4601.60 BogoMIPS (lpj=7666560)
[ 0.076646] pid_max: default: 32768 minimum: 301
[ 0.076669] LSM: Security Framework initializing
[ 0.076673] Yama: becoming mindful.
[ 0.076687] AppArmor: AppArmor initialized
[ 0.076706] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.076715] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.076920] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.076935] process: using mwait in idle threads
[ 0.076937] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.076937] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.076939] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.076940] Spectre V2 : Mitigation: Full generic retpoline
[ 0.076940] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.076941] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.076942] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.076942] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.076943] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.076947] SRBDS: Mitigation: Microcode
[ 0.076947] MDS: Mitigation: Clear CPU buffers
[ 0.077142] Freeing SMP alternatives memory: 32K
[ 0.080057] smpboot: CPU0: Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[ 0.080124] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.080131] ... version: 4
[ 0.080132] ... bit width: 48
[ 0.080132] ... generic registers: 4
[ 0.080132] ... value mask: 0000ffffffffffff
[ 0.080133] ... max period: 00007fffffffffff
[ 0.080133] ... fixed-purpose events: 3
[ 0.080133] ... event mask: 000000070000000f
[ 0.080165] rcu: Hierarchical SRCU implementation.
[ 0.080623] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.080677] smp: Bringing up secondary CPUs ...
[ 0.080752] x86: Booting SMP configuration:
[ 0.080753] .... node #0, CPUs: #1 #2 #3 #4
[ 0.084474] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.084474] #5 #6 #7
[ 0.087610] smp: Brought up 1 node, 8 CPUs
[ 0.087610] smpboot: Max logical packages: 1
[ 0.087610] smpboot: Total of 8 processors activated (36814.80 BogoMIPS)
[ 0.090227] devtmpfs: initialized
[ 0.090227] x86/mm: Memory block size: 128MB
[ 0.090433] PM: Registering ACPI NVS region [mem 0x5a05d000-0x5a05dfff] (4096 bytes)
[ 0.090433] PM: Registering ACPI NVS region [mem 0x6d831000-0x6dcf7fff] (5009408 bytes)
[ 0.090433] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.090433] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.090433] pinctrl core: initialized pinctrl subsystem
[ 0.090433] PM: RTC time: 09:04:26, date: 2020-12-29
[ 0.090433] NET: Registered protocol family 16
[ 0.090511] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.090555] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.090598] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.090606] audit: initializing netlink subsys (disabled)
[ 0.090612] audit: type=2000 audit(1609232666.033:1): state=initialized audit_enabled=0 res=1
[ 0.090612] thermal_sys: Registered thermal governor 'fair_share'
[ 0.090612] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.090612] thermal_sys: Registered thermal governor 'step_wise'
[ 0.090612] thermal_sys: Registered thermal governor 'user_space'
[ 0.090612] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.090612] cpuidle: using governor ladder
[ 0.090612] cpuidle: using governor menu
[ 0.090612] Simple Boot Flag at 0x47 set to 0x80
[ 0.090612] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.090612] ACPI: bus type PCI registered
[ 0.090612] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.090612] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.090612] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[ 0.090612] PCI: Using configuration type 1 for base access
[ 0.090612] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.090871] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.090871] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.093388] ACPI: Added _OSI(Module Device)
[ 0.093388] ACPI: Added _OSI(Processor Device)
[ 0.093389] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.093389] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.093390] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.093390] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.093391] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.139961] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.139966] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.139967] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.139968] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.139970] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.139971] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.140289] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.140291] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.140292] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.140293] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.140295] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.140296] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.140602] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.140604] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.140605] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.140606] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.140608] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.140609] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.140914] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.140916] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.140916] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.140918] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.140919] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.140920] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.141227] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.141229] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.141230] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.141231] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.141232] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.141233] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.141536] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.141537] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.141538] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.141539] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.141541] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.141542] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.141844] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.141846] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.141846] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.141847] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.141849] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.141850] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.142152] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.142154] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.142154] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.142155] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.142157] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.142158] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.142461] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.142463] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.142464] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.142465] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.142467] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.142467] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.142772] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.142773] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.142774] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.142775] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.142777] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.142777] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143081] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143083] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143083] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143084] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143086] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143087] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143392] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143394] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143395] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143396] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143398] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143399] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143719] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143720] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143721] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143722] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143724] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143724] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143727] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143728] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143729] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143730] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143732] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143732] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143760] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143762] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143762] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143763] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143765] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143766] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143793] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143795] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143796] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143797] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143798] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143799] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143826] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143828] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143828] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143829] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143831] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143832] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143859] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143860] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143861] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143862] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143864] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143865] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143892] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143893] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143894] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143895] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143896] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143897] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143924] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143926] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143927] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143928] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143929] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143930] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143957] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143959] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143959] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143960] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143962] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143963] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143990] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143992] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143992] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.143993] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.143995] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.143996] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.144023] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.144024] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.144025] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.144026] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.144028] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.144028] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.144055] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._UPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.144057] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.144058] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.144059] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._PLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.144060] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.144061] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 0.148040] ACPI: 13 ACPI AML tables successfully acquired and loaded
[ 0.157015] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.165691] ACPI: Dynamic OEM Table Load:
[ 0.165696] ACPI: SSDT 0xFFFFA1A832C45000 0005CA (v02 PmRef Cpu0Ist 00003000 INTL 20160527)
[ 0.167232] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.168100] ACPI: Dynamic OEM Table Load:
[ 0.168105] ACPI: SSDT 0xFFFFA1A832B8D800 000400 (v02 PmRef Cpu0Cst 00003001 INTL 20160527)
[ 0.169574] ACPI: Dynamic OEM Table Load:
[ 0.169577] ACPI: SSDT 0xFFFFA1A832B80800 00011B (v02 PmRef Cpu0Hwp 00003000 INTL 20160527)
[ 0.170989] ACPI: Dynamic OEM Table Load:
[ 0.170993] ACPI: SSDT 0xFFFFA1A832C41800 000724 (v02 PmRef HwpLvt 00003000 INTL 20160527)
[ 0.172766] ACPI: Dynamic OEM Table Load:
[ 0.172772] ACPI: SSDT 0xFFFFA1A832C91000 000EF1 (v02 PmRef ApIst 00003000 INTL 20160527)
[ 0.174974] ACPI: Dynamic OEM Table Load:
[ 0.174977] ACPI: SSDT 0xFFFFA1A832B88000 000317 (v02 PmRef ApHwp 00003000 INTL 20160527)
[ 0.176473] ACPI: Dynamic OEM Table Load:
[ 0.176476] ACPI: SSDT 0xFFFFA1A832B8C400 00030A (v02 PmRef ApCst 00003000 INTL 20160527)
[ 0.180269] ACPI: EC: EC started
[ 0.180269] ACPI: EC: interrupt blocked
[ 0.185785] ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
[ 0.185787] ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC used to handle transactions
[ 0.185788] ACPI: Interpreter enabled
[ 0.185829] ACPI: (supports S0 S3 S4 S5)
[ 0.185830] ACPI: Using IOAPIC for interrupt routing
[ 0.185870] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.186468] ACPI: Enabled 8 GPEs in block 00 to 7F
[ 0.188431] ACPI: Power Resource [PG00] (on)
[ 0.214507] ACPI: Power Resource [WRST] (on)
[ 0.214907] ACPI: Power Resource [DRST] (on)
[ 0.227565] ACPI: Power Resource [USBC] (on)
[ 0.231341] ACPI: Power Resource [V0PR] (on)
[ 0.231734] ACPI: Power Resource [V1PR] (on)
[ 0.232116] ACPI: Power Resource [V2PR] (on)
[ 0.237664] ACPI: Power Resource [WRST] (on)
[ 0.254163] ACPI: Power Resource [PIN] (off)
[ 0.254691] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7e])
[ 0.254696] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.256416] acpi PNP0A08:00: _OSC: platform does not support [AER]
[ 0.259669] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC]
[ 0.259669] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.260658] PCI host bridge to bus 0000:00
[ 0.260659] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.260660] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.260661] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.260662] pci_bus 0000:00: root bus resource [mem 0x7f800000-0xefffffff window]
[ 0.260662] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[ 0.260663] pci_bus 0000:00: root bus resource [bus 00-7e]
[ 0.260680] pci 0000:00:00.0: [8086:3e10] type 00 class 0x060000
[ 0.260787] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[ 0.260820] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.261176] pci 0000:00:02.0: [8086:3e9b] type 00 class 0x030000
[ 0.261182] pci 0000:00:02.0: reg 0x10: [mem 0xeb000000-0xebffffff 64bit]
[ 0.261186] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff 64bit pref]
[ 0.261189] pci 0000:00:02.0: reg 0x20: [io 0x4000-0x403f]
[ 0.261344] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[ 0.261351] pci 0000:00:04.0: reg 0x10: [mem 0xed598000-0xed59ffff 64bit]
[ 0.261563] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[ 0.261570] pci 0000:00:08.0: reg 0x10: [mem 0xed5ad000-0xed5adfff 64bit]
[ 0.261796] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[ 0.261830] pci 0000:00:12.0: reg 0x10: [mem 0xed5ac000-0xed5acfff 64bit]
[ 0.262150] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[ 0.262184] pci 0000:00:14.0: reg 0x10: [mem 0xed580000-0xed58ffff 64bit]
[ 0.262320] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.262964] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[ 0.262997] pci 0000:00:14.2: reg 0x10: [mem 0xed5a4000-0xed5a5fff 64bit]
[ 0.263019] pci 0000:00:14.2: reg 0x18: [mem 0xed5ab000-0xed5abfff 64bit]
[ 0.263654] pci 0000:00:15.0: [8086:a368] type 00 class 0x0c8000
[ 0.264230] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.267131] pci 0000:00:15.1: [8086:a369] type 00 class 0x0c8000
[ 0.267707] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.270230] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[ 0.270261] pci 0000:00:16.0: reg 0x10: [mem 0xed5a8000-0xed5a8fff 64bit]
[ 0.270379] pci 0000:00:16.0: PME# supported from D3hot
[ 0.270834] pci 0000:00:17.0: [8086:282a] type 00 class 0x010400
[ 0.270882] pci 0000:00:17.0: reg 0x10: [mem 0xed590000-0xed597fff]
[ 0.270908] pci 0000:00:17.0: reg 0x14: [mem 0xed5a7000-0xed5a70ff]
[ 0.270933] pci 0000:00:17.0: reg 0x18: [io 0x4090-0x4097]
[ 0.270959] pci 0000:00:17.0: reg 0x1c: [io 0x4080-0x4083]
[ 0.270985] pci 0000:00:17.0: reg 0x20: [io 0x4060-0x407f]
[ 0.271011] pci 0000:00:17.0: reg 0x24: [mem 0xed500000-0xed57ffff]
[ 0.271156] pci 0000:00:17.0: PME# supported from D3hot
[ 0.271502] pci 0000:00:1b.0: [8086:a340] type 01 class 0x060400
[ 0.271754] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.271798] pci 0000:00:1b.0: PTM enabled (root), 4ns granularity
[ 0.272170] pci 0000:00:1c.0: [8086:a338] type 01 class 0x060400
[ 0.272365] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.272415] pci 0000:00:1c.0: PTM enabled (root), 4ns granularity
[ 0.272800] pci 0000:00:1c.4: [8086:a33c] type 01 class 0x060400
[ 0.272987] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.273031] pci 0000:00:1c.4: PTM enabled (root), 4ns granularity
[ 0.273423] pci 0000:00:1f.0: [8086:a30e] type 00 class 0x060100
[ 0.273762] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040380
[ 0.273828] pci 0000:00:1f.3: reg 0x10: [mem 0xed5a0000-0xed5a3fff 64bit]
[ 0.273925] pci 0000:00:1f.3: reg 0x20: [mem 0xed100000-0xed1fffff 64bit]
[ 0.274083] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.275266] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[ 0.275438] pci 0000:00:1f.4: reg 0x10: [mem 0xed5a6000-0xed5a60ff 64bit]
[ 0.275652] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.276046] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[ 0.276070] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.276295] pci 0000:01:00.0: [10de:1c8d] type 00 class 0x030200
[ 0.276302] pci 0000:01:00.0: reg 0x10: [mem 0xec000000-0xecffffff]
[ 0.276308] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.276314] pci 0000:01:00.0: reg 0x1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
[ 0.276318] pci 0000:01:00.0: reg 0x24: [io 0x3000-0x307f]
[ 0.276322] pci 0000:01:00.0: reg 0x30: [mem 0xed000000-0xed07ffff pref]
[ 0.276333] pci 0000:01:00.0: Enabling HDA controller
[ 0.276502] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.276504] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff]
[ 0.276506] pci 0000:00:01.0: bridge window [mem 0xec000000-0xed0fffff]
[ 0.276508] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.276665] pci 0000:00:1b.0: PCI bridge to [bus 02-3a]
[ 0.276673] pci 0000:00:1b.0: bridge window [mem 0xd4000000-0xea0fffff]
[ 0.276682] pci 0000:00:1b.0: bridge window [mem 0x90000000-0xb1ffffff 64bit pref]
[ 0.277301] pci 0000:3b:00.0: [168c:003e] type 00 class 0x028000
[ 0.277631] pci 0000:3b:00.0: reg 0x10: [mem 0xed200000-0xed3fffff 64bit]
[ 0.279686] pci 0000:3b:00.0: PME# supported from D0 D3hot D3cold
[ 0.281730] pci 0000:00:1c.0: PCI bridge to [bus 3b]
[ 0.281738] pci 0000:00:1c.0: bridge window [mem 0xed200000-0xed3fffff]
[ 0.281930] pci 0000:3c:00.0: [10ec:525a] type 00 class 0xff0000
[ 0.281970] pci 0000:3c:00.0: reg 0x14: [mem 0xed400000-0xed400fff]
[ 0.282150] pci 0000:3c:00.0: supports D1 D2
[ 0.282151] pci 0000:3c:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.282357] pci 0000:00:1c.4: PCI bridge to [bus 3c]
[ 0.282366] pci 0000:00:1c.4: bridge window [mem 0xed400000-0xed4fffff]
[ 0.285126] ACPI: PCI Interrupt Link [LNKA] (IRQs) *0
[ 0.285161] ACPI: PCI Interrupt Link [LNKB] (IRQs) *1
[ 0.285193] ACPI: PCI Interrupt Link [LNKC] (IRQs) *0
[ 0.285224] ACPI: PCI Interrupt Link [LNKD] (IRQs) *0
[ 0.285256] ACPI: PCI Interrupt Link [LNKE] (IRQs) *0
[ 0.285288] ACPI: PCI Interrupt Link [LNKF] (IRQs) *0
[ 0.285319] ACPI: PCI Interrupt Link [LNKG] (IRQs) *0
[ 0.285350] ACPI: PCI Interrupt Link [LNKH] (IRQs) *0
[ 0.297822] ACPI: EC: interrupt unblocked
[ 0.297823] ACPI: EC: event unblocked
[ 0.297833] ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
[ 0.297833] ACPI: EC: GPE=0x6e
[ 0.297835] ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC initialization complete
[ 0.297835] ACPI: \_SB_.PCI0.LPCB.ECDV: EC: Used to handle transactions and events
[ 0.297909] iommu: Default domain type: Translated
[ 0.297918] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.297918] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.297918] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.297918] vgaarb: loaded
[ 0.297918] SCSI subsystem initialized
[ 0.297918] libata version 3.00 loaded.
[ 0.297918] ACPI: bus type USB registered
[ 0.297918] usbcore: registered new interface driver usbfs
[ 0.297918] usbcore: registered new interface driver hub
[ 0.297918] usbcore: registered new device driver usb
[ 0.297918] pps_core: LinuxPPS API ver. 1 registered
[ 0.297918] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.297918] PTP clock support registered
[ 0.297918] EDAC MC: Ver: 3.0.0
[ 0.297918] NetLabel: Initializing
[ 0.297918] NetLabel: domain hash size = 128
[ 0.297918] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.297918] NetLabel: unlabeled traffic allowed by default
[ 0.297918] PCI: Using ACPI for IRQ routing
[ 0.326664] PCI: pci_cache_line_size set to 64 bytes
[ 0.327187] e820: reserve RAM buffer [mem 0x0009ec00-0x0009ffff]
[ 0.327188] e820: reserve RAM buffer [mem 0x5a05d000-0x5bffffff]
[ 0.327188] e820: reserve RAM buffer [mem 0x78e00000-0x7bffffff]
[ 0.327189] e820: reserve RAM buffer [mem 0x27c800000-0x27fffffff]
[ 0.327201] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.327203] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.329304] clocksource: Switched to clocksource tsc-early
[ 0.334905] VFS: Disk quotas dquot_6.6.0
[ 0.334916] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.334991] AppArmor: AppArmor Filesystem Enabled
[ 0.335017] pnp: PnP ACPI init
[ 0.335242] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.335244] system 00:00: [io 0x164e-0x164f] has been reserved
[ 0.335247] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.335262] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.335349] system 00:02: [io 0x1854-0x1857] has been reserved
[ 0.335351] system 00:02: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.335453] pnp 00:03: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.335465] pnp 00:04: Plug and Play ACPI device, IDs DLL087c PNP0f13 (active)
[ 0.335642] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.335643] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.335644] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.335645] system 00:05: [mem 0xf0000000-0xf7ffffff] has been reserved
[ 0.335646] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.335647] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.335648] system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.335648] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.335651] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.335860] system 00:06: [io 0x1800-0x18fe] could not be reserved
[ 0.335861] system 00:06: [mem 0xfd000000-0xfd69ffff] has been reserved
[ 0.335861] system 00:06: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[ 0.335863] system 00:06: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 0.335864] system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.335865] system 00:06: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 0.335866] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[ 0.335868] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.336150] system 00:07: [io 0x2000-0x20fe] has been reserved
[ 0.336152] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.337187] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.347094] pnp: PnP ACPI: found 9 devices
[ 0.352695] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.352748] NET: Registered protocol family 2
[ 0.352848] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.352880] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.352977] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.353033] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.353075] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[ 0.353102] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.353120] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.353183] NET: Registered protocol family 1
[ 0.353186] NET: Registered protocol family 44
[ 0.353192] pci 0000:00:1b.0: bridge window [io 0x1000-0x0fff] to [bus 02-3a] add_size 1000
[ 0.353199] pci 0000:00:15.0: BAR 0: assigned [mem 0x7f800000-0x7f800fff 64bit]
[ 0.353484] pci 0000:00:15.1: BAR 0: assigned [mem 0x7f801000-0x7f801fff 64bit]
[ 0.353751] pci 0000:00:1b.0: BAR 13: assigned [io 0x5000-0x5fff]
[ 0.353753] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.353755] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff]
[ 0.353757] pci 0000:00:01.0: bridge window [mem 0xec000000-0xed0fffff]
[ 0.353758] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.353761] pci 0000:00:1b.0: PCI bridge to [bus 02-3a]
[ 0.353767] pci 0000:00:1b.0: bridge window [io 0x5000-0x5fff]
[ 0.353774] pci 0000:00:1b.0: bridge window [mem 0xd4000000-0xea0fffff]
[ 0.353778] pci 0000:00:1b.0: bridge window [mem 0x90000000-0xb1ffffff 64bit pref]
[ 0.353787] pci 0000:00:1c.0: PCI bridge to [bus 3b]
[ 0.353796] pci 0000:00:1c.0: bridge window [mem 0xed200000-0xed3fffff]
[ 0.353809] pci 0000:00:1c.4: PCI bridge to [bus 3c]
[ 0.353815] pci 0000:00:1c.4: bridge window [mem 0xed400000-0xed4fffff]
[ 0.353829] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.353830] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.353831] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.353831] pci_bus 0000:00: resource 7 [mem 0x7f800000-0xefffffff window]
[ 0.353832] pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[ 0.353833] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.353834] pci_bus 0000:01: resource 1 [mem 0xec000000-0xed0fffff]
[ 0.353835] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.353835] pci_bus 0000:02: resource 0 [io 0x5000-0x5fff]
[ 0.353836] pci_bus 0000:02: resource 1 [mem 0xd4000000-0xea0fffff]
[ 0.353837] pci_bus 0000:02: resource 2 [mem 0x90000000-0xb1ffffff 64bit pref]
[ 0.353838] pci_bus 0000:3b: resource 1 [mem 0xed200000-0xed3fffff]
[ 0.353839] pci_bus 0000:3c: resource 1 [mem 0xed400000-0xed4fffff]
[ 0.353992] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.354538] PCI: CLS 64 bytes, default 64
[ 0.354565] Trying to unpack rootfs image as initramfs...
[ 0.451418] Freeing initrd memory: 13100K
[ 0.451449] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.451450] software IO TLB: mapped [mem 0x5605d000-0x5a05d000] (64MB)
[ 0.451610] check: Scanning for low memory corruption every 60 seconds
[ 0.451849] Initialise system trusted keyrings
[ 0.451863] Key type blacklist registered
[ 0.451898] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[ 0.452661] zbud: loaded
[ 0.458923] Key type asymmetric registered
[ 0.458924] Asymmetric key parser 'x509' registered
[ 0.458929] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.458957] io scheduler mq-deadline registered
[ 0.458958] io scheduler kyber registered
[ 0.458972] io scheduler bfq registered
[ 0.463196] pcieport 0000:00:01.0: PME: Signaling with IRQ 122
[ 0.463412] pcieport 0000:00:1b.0: PME: Signaling with IRQ 123
[ 0.463442] pcieport 0000:00:1b.0: pciehp: Slot #20 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.463747] pcieport 0000:00:1c.0: PME: Signaling with IRQ 124
[ 0.464005] pcieport 0000:00:1c.4: PME: Signaling with IRQ 125
[ 0.464120] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.464180] vesafb: mode is 1920x1080x32, linelength=7680, pages=0
[ 0.464181] vesafb: scrolling: redraw
[ 0.464182] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.464189] vesafb: framebuffer at 0x80000000, mapped to 0x00000000feb637d6, using 8128k, total 8128k
[ 0.464210] fbcon: Deferring console take-over
[ 0.464210] fb0: VESA VGA frame buffer device
[ 0.464220] intel_idle: MWAIT substates: 0x11142120
[ 0.464221] intel_idle: v0.5.1 model 0x9E
[ 0.464515] intel_idle: Local APIC timer is reliable in all C-states
[ 0.464596] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.470049] ACPI: Lid Switch [LID0]
[ 0.470074] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.470255] ACPI: Power Button [PBTN]
[ 0.470279] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 0.470291] ACPI: Sleep Button [SBTN]
[ 0.470311] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 0.473330] ACPI: Power Button [PWRF]
[ 0.476032] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.476033] ACPI: Thermal Zone [THM] (25 C)
[ 0.476245] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.476819] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.476819] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[ 0.477805] ahci 0000:00:17.0: version 3.0
[ 0.477936] ahci 0000:00:17.0: Found 1 remapped NVMe devices.
[ 0.477937] ahci 0000:00:17.0: Switch your BIOS from RAID to AHCI mode to use them.
[ 0.478010] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x4 impl RAID mode
[ 0.478011] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part deso sadm sds apst
[ 0.478596] scsi host0: ahci
[ 0.478707] scsi host1: ahci
[ 0.478804] scsi host2: ahci
[ 0.478836] ata1: DUMMY
[ 0.478836] ata2: DUMMY
[ 0.478842] ata3: SATA max UDMA/133 abar m524288@0xed500000 port 0xed500200 irq 16
[ 0.478870] usbcore: registered new interface driver usbserial_generic
[ 0.478872] usbserial: USB Serial support registered for generic
[ 0.478896] rtc_cmos 00:01: RTC can wake from S4
[ 0.479958] rtc_cmos 00:01: registered as rtc0
[ 0.480218] rtc_cmos 00:01: setting system clock to 2020-12-29T09:04:26 UTC (1609232666)
[ 0.480228] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram
[ 0.480273] intel_pstate: Intel P-state driver initializing
[ 0.480878] intel_pstate: Disabling energy efficiency optimization
[ 0.480878] intel_pstate: HWP enabled
[ 0.480922] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.480985] ashmem: initialized
[ 0.481025] intel_pmc_core INT33A1:00: initialized
[ 0.481084] drop_monitor: Initializing network drop monitor service
[ 0.481181] NET: Registered protocol family 10
[ 0.485211] Segment Routing with IPv6
[ 0.485212] RPL Segment Routing with IPv6
[ 0.485224] NET: Registered protocol family 17
[ 0.485875] microcode: sig=0x906ea, pf=0x20, revision=0xde
[ 0.486050] microcode: Microcode Update Driver: v2.2.
[ 0.486053] IPI shorthand broadcast: enabled
[ 0.486059] sched_clock: Marking stable (478620938, 7427251)->(512420602, -26372413)
[ 0.486255] registered taskstats version 1
[ 0.486260] Loading compiled-in X.509 certificates
[ 0.488679] Loaded X.509 cert 'Build time autogenerated kernel key: 00c10b0ba9d05395b3960e2a8b3ae7d67466c42a'
[ 0.489728] zswap: loaded using pool zstd/z3fold
[ 0.489896] Key type ._fscrypt registered
[ 0.489897] Key type .fscrypt registered
[ 0.489897] Key type fscrypt-provisioning registered
[ 0.489941] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.491654] PM: Magic number: 0:683:71
[ 0.491808] RAS: Correctable Errors collector initialized.
[ 0.797012] ata3: SATA link down (SStatus 4 SControl 300)
[ 0.803247] Freeing unused decrypted memory: 2040K
[ 0.803890] Freeing unused kernel image (initmem) memory: 1664K
[ 0.804002] Write protecting the kernel read-only data: 22528k
[ 0.805117] Freeing unused kernel image (text/rodata gap) memory: 2044K
[ 0.805634] Freeing unused kernel image (rodata/data gap) memory: 1384K
[ 0.846381] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.846382] x86/mm: Checking user space page tables
[ 0.885573] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.885576] Run /init as init process
[ 0.885577] with arguments:
[ 0.885577] /init
[ 0.885577] with environment:
[ 0.885578] HOME=/
[ 0.885578] TERM=linux
[ 0.885578] BOOT_IMAGE=/vmlinuz-5.9-x86_64
[ 0.944364] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.944891] i8042: Warning: Keylock active
[ 0.946914] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.946953] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.956266] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.956270] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 0.957373] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[ 0.957381] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 0.957627] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 0.957628] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.957629] usb usb1: Product: xHCI Host Controller
[ 0.957630] usb usb1: Manufacturer: Linux 5.9.11-3-MANJARO xhci-hcd
[ 0.957631] usb usb1: SerialNumber: 0000:00:14.0
[ 0.957791] hub 1-0:1.0: USB hub found
[ 0.957826] hub 1-0:1.0: 16 ports detected
[ 0.959598] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.959607] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 0.959614] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 0.959673] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[ 0.959674] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.959676] usb usb2: Product: xHCI Host Controller
[ 0.959677] usb usb2: Manufacturer: Linux 5.9.11-3-MANJARO xhci-hcd
[ 0.959678] usb usb2: SerialNumber: 0000:00:14.0
[ 0.959771] hub 2-0:1.0: USB hub found
[ 0.959793] hub 2-0:1.0: 10 ports detected
[ 0.960253] usb: port power management may be unreliable
[ 0.966121] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 1.286708] usb 1-2: new low-speed USB device number 2 using xhci_hcd
[ 1.431328] usb 1-2: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[ 1.431333] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.431337] usb 1-2: Product: USB Optical Mouse
[ 1.431339] usb 1-2: Manufacturer: PixArt
[ 1.441560] hid: raw HID events driver (C) Jiri Kosina
[ 1.444129] usbcore: registered new interface driver usbhid
[ 1.444130] usbhid: USB HID core driver
[ 1.445324] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:093A:2510.0001/input/input6
[ 1.445382] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:14.0-2/input0
[ 1.470347] tsc: Refined TSC clocksource calibration: 2304.023 MHz
[ 1.470356] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x21360d99447, max_idle_ns: 440795269529 ns
[ 1.470418] clocksource: Switched to clocksource tsc
[ 1.550477] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 1.568553] usb 2-1: New USB device found, idVendor=0781, idProduct=55a3, bcdDevice= 1.00
[ 1.568558] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.568561] usb 2-1: Product: Ultra Luxe
[ 1.568564] usb 2-1: Manufacturer: SanDisk
[ 1.568567] usb 2-1: SerialNumber: 0101830ba89dada307036810029196a287651510560ad3f5dd6eaa87d57f81e72a9200000000000000000000f4a6855900175100a3558107b626ac60
[ 1.579584] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 1.580266] scsi host3: usb-storage 2-1:1.0
[ 1.580550] usbcore: registered new interface driver usb-storage
[ 1.584567] usbcore: registered new interface driver uas
[ 1.690305] usb 1-4: new full-speed USB device number 3 using xhci_hcd
[ 1.832893] usb 1-4: New USB device found, idVendor=0cf3, idProduct=e300, bcdDevice= 0.01
[ 1.832898] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.960311] usb 1-7: new full-speed USB device number 4 using xhci_hcd
[ 2.102673] usb 1-7: New USB device found, idVendor=27c6, idProduct=5395, bcdDevice= 1.00
[ 2.102678] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.102682] usb 1-7: Product: Goodix Fingerprint Device
[ 2.102685] usb 1-7: Manufacturer: HTMicroelectronics
[ 2.102687] usb 1-7: SerialNumber: HTK32
[ 2.230297] usb 1-12: new high-speed USB device number 5 using xhci_hcd
[ 2.388250] usb 1-12: New USB device found, idVendor=0c45, idProduct=671d, bcdDevice=81.31
[ 2.388255] usb 1-12: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 2.388259] usb 1-12: Product: Integrated_Webcam_HD
[ 2.388262] usb 1-12: Manufacturer: CN0VGCNHLOG0093DAJFNA00
[ 2.592051] scsi 3:0:0:0: Direct-Access SanDisk Ultra Luxe 1.00 PQ: 0 ANSI: 6
[ 2.593230] sd 3:0:0:0: [sda] 120176640 512-byte logical blocks: (61.5 GB/57.3 GiB)
[ 2.594503] sd 3:0:0:0: [sda] Write Protect is off
[ 2.594509] sd 3:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 2.595117] sd 3:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 2.633942] sda: sda1 sda2 sda3 sda4
[ 2.636899] sd 3:0:0:0: [sda] Attached SCSI removable disk
[ 2.642819] random: fast init done
[ 3.570352] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.171318] systemd[1]: systemd 246.6-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 4.187143] systemd[1]: Detected architecture x86-64.
[ 4.233529] systemd[1]: Set hostname to <roger>.
[ 5.193417] systemd[1]: Queued start job for default target Graphical Interface.
[ 5.196075] systemd[1]: Created slice system-getty.slice.
[ 5.196714] systemd[1]: Created slice system-modprobe.slice.
[ 5.197262] systemd[1]: Created slice Cryptsetup Units Slice.
[ 5.197903] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 5.198402] systemd[1]: Created slice User and Session Slice.
[ 5.198572] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 5.198716] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.199153] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.199277] systemd[1]: Reached target Login Prompts.
[ 5.199347] systemd[1]: Reached target Remote File Systems.
[ 5.199380] systemd[1]: Reached target Slices.
[ 5.199427] systemd[1]: Reached target Swap.
[ 5.199626] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 5.206607] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 5.207708] systemd[1]: Listening on LVM2 poll daemon socket.
[ 5.212481] systemd[1]: Listening on Process Core Dump Socket.
[ 5.212896] systemd[1]: Listening on Journal Audit Socket.
[ 5.213180] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.213598] systemd[1]: Listening on Journal Socket.
[ 5.213923] systemd[1]: Listening on udev Control Socket.
[ 5.214147] systemd[1]: Listening on udev Kernel Socket.
[ 5.216406] systemd[1]: Mounting Huge Pages File System...
[ 5.218720] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.221127] systemd[1]: Mounting Kernel Debug File System...
[ 5.223676] systemd[1]: Mounting Kernel Trace File System...
[ 5.225170] systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
[ 5.227371] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 5.228999] systemd[1]: Starting Load AppArmor profiles...
[ 5.230312] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 5.231438] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 5.232657] systemd[1]: Starting Load Kernel Module drm...
[ 5.244472] systemd[1]: Starting Set Up Additional Binary Formats...
[ 5.244651] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 5.250877] systemd[1]: Starting Journal Service...
[ 5.260315] systemd[1]: Starting Load Kernel Modules...
[ 5.260868] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.260901] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 5.261403] systemd[1]: Starting Coldplug All udev Devices...
[ 5.262509] systemd[1]: Mounted Huge Pages File System.
[ 5.262603] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.262672] systemd[1]: Mounted Kernel Debug File System.
[ 5.262757] systemd[1]: Mounted Kernel Trace File System.
[ 5.262836] systemd[1]: Mounted Temporary Directory (/tmp).
[ 5.263112] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 5.263218] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 260 (systemd-binfmt)
[ 5.263752] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 5.265224] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 5.275483] Linux agpgart interface v0.103
[ 5.280128] EXT4-fs (sda2): re-mounted. Opts: (null)
[ 5.281059] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 5.281179] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 5.329439] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 5.330196] systemd[1]: Starting Load/Save Random Seed...
[ 5.330251] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 5.330792] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 5.331081] systemd[1]: modprobe@drm.service: Succeeded.
[ 5.331290] systemd[1]: Finished Load Kernel Module drm.
[ 5.331633] systemd[1]: Finished Set Up Additional Binary Formats.
[ 5.353856] random: lvm: uninitialized urandom read (4 bytes read)
[ 5.374687] systemd[1]: Finished Coldplug All udev Devices.
[ 5.433598] systemd[1]: Finished Load Kernel Modules.
[ 5.433740] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 5.434289] systemd[1]: Mounting Kernel Configuration File System...
[ 5.434809] systemd[1]: Starting Apply Kernel Variables...
[ 5.435991] systemd[1]: Mounted Kernel Configuration File System.
[ 5.466120] systemd[1]: Finished Apply Kernel Variables.
[ 5.489849] systemd[1]: Starting CLI Netfilter Manager...
[ 5.516464] systemd[1]: Started Journal Service.
[ 5.516556] audit: type=1130 audit(1609232671.530:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.534677] audit: type=1130 audit(1609232671.550:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ufw comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.586923] audit: type=1130 audit(1609232671.603:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.587959] audit: type=1334 audit(1609232671.603:5): prog-id=5 op=LOAD
[ 5.588095] audit: type=1334 audit(1609232671.603:6): prog-id=6 op=LOAD
[ 5.694235] audit: type=1400 audit(1609232671.706:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=278 comm="apparmor_parser"
[ 5.708832] audit: type=1400 audit(1609232671.723:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=282 comm="apparmor_parser"
[ 5.709600] audit: type=1400 audit(1609232671.723:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=282 comm="apparmor_parser"
[ 5.730175] random: crng init done
[ 5.753023] audit: type=1130 audit(1609232671.766:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.787088] audit: type=1400 audit(1609232671.800:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=280 comm="apparmor_parser"
[ 6.694121] ACPI: AC Adapter [AC] (off-line)
[ 6.734797] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[ 6.735413] wmi_bus wmi_bus-PNP0C14:05: WQBC data block query control method not found
[ 6.735414] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[ 6.741814] input: Intel HID events as /devices/platform/INT33D5:00/input/input7
[ 6.744373] intel-hid INT33D5:00: platform supports 5 button array
[ 6.744395] input: Intel HID 5 button array as /devices/platform/INT33D5:00/input/input8
[ 6.754162] battery: ACPI: Battery Slot [BAT0] (battery present)
[ 6.754430] acpi PNP0C14:06: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[ 6.762024] tpm_tis MSFT0101:00: 2.0 TPM (device-id 0xFC, rev-id 1)
[ 6.766322] acpi PNP0C14:07: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[ 6.963736] mei_me 0000:00:16.0: enabling device (0004 -> 0006)
[ 6.964134] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[ 6.964441] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 6.981351] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[ 6.981673] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 6.997080] i2c_hid i2c-SYNA2393:00: supply vdd not found, using dummy regulator
[ 6.997097] i2c_hid i2c-SYNA2393:00: supply vddl not found, using dummy regulator
[ 7.017506] intel_rapl_common: Found RAPL domain package
[ 7.017506] intel_rapl_common: Found RAPL domain dram
[ 7.017680] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[ 7.043913] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 7.043975] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 7.054146] i801_smbus 0000:00:1f.4: Accelerometer lis3lv02d is present on SMBus but its address is unknown, skipping registration
[ 7.054149] i2c i2c-2: 2/2 memory slots populated (from DMI)
[ 7.054794] i2c i2c-2: Successfully instantiated SPD at 0x50
[ 7.122226] input: PC Speaker as /devices/platform/pcspkr/input/input9
[ 7.136373] intel-spi 0000:00:1f.5: gd25q256 (32768 Kbytes)
[ 7.136399] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.140029] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 7.147690] input: SYNA2393:00 06CB:7A13 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-SYNA2393:00/0018:06CB:7A13.0002/input/input11
[ 7.147820] input: SYNA2393:00 06CB:7A13 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-SYNA2393:00/0018:06CB:7A13.0002/input/input12
[ 7.147930] hid-generic 0018:06CB:7A13.0002: input,hidraw1: I2C HID v1.00 Mouse [SYNA2393:00 06CB:7A13] on i2c-SYNA2393:00
[ 7.248496] Creating 1 MTD partitions on "0000:00:1f.5":
[ 7.248498] 0x000000000000-0x000002000000 : "BIOS"
[ 7.261639] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ 7.261641] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 7.261641] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 7.261642] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 7.261643] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 7.261643] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 7.519753] cryptd: max_cpu_qlen set to 1000
[ 7.539197] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.4)
[ 7.544663] ath10k_pci 0000:3b:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 7.620645] AVX2 version of gcm_enc/dec engaged.
[ 7.620647] AES CTR mode by8 optimization enabled
[ 7.624949] checking generic (80000000 7f0000) vs hw (eb000000 1000000)
[ 7.624951] checking generic (80000000 7f0000) vs hw (80000000 10000000)
[ 7.624952] fb0: switching to inteldrmfb from VESA VGA
[ 7.626227] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 7.652231] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 7.667965] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 7.697673] input: Dell WMI hotkeys as /devices/platform/PNP0C14:05/wmi_bus/wmi_bus-PNP0C14:05/PNP0C14:05-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input14
[ 7.751069] MXM: GUID detected in BIOS
[ 7.751130] ACPI Warning: \_SB.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200717/nsarguments-59)
[ 7.751243] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200717/nsarguments-59)
[ 7.759104] pci 0000:01:00.0: optimus capabilities: enabled, status dynamic power, hda bios codec supported
[ 7.759108] VGA switcheroo: detected Optimus DSM method \_SB_.PCI0.PEG0.PEGP handle
[ 7.759109] nouveau: detected PR support, will not use DSM
[ 7.759422] nouveau 0000:01:00.0: NVIDIA GP107 (137000a1)
[ 7.853620] ath10k_pci 0000:3b:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 1a56:1535
[ 7.853623] ath10k_pci 0000:3b:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[ 7.854104] ath10k_pci 0000:3b:00.0: firmware ver WLAN.RM.4.4.1-00157-QCARMSWPZ-1 api 6 features wowlan,ignore-otp,mfp crc32 90eebefb
[ 7.867534] iTCO_vendor_support: vendor-support=0
[ 7.886556] nouveau 0000:01:00.0: bios: version 86.07.63.00.6e
[ 7.895872] intel_rapl_common: Found RAPL domain package
[ 7.895874] intel_rapl_common: Found RAPL domain core
[ 7.895875] intel_rapl_common: Found RAPL domain uncore
[ 7.895876] intel_rapl_common: Found RAPL domain dram
[ 7.896344] ee1004 2-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 7.906142] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 7.934273] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 7.935232] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 7.935328] iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 7.935548] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 7.942483] ath10k_pci 0000:3b:00.0: board_file api 2 bmi_id N/A crc32 318825bf
[ 7.987415] nouveau 0000:01:00.0: pmu: firmware unavailable
[ 8.011935] input: SYNA2393:00 06CB:7A13 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-SYNA2393:00/0018:06CB:7A13.0002/input/input15
[ 8.012011] input: SYNA2393:00 06CB:7A13 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-SYNA2393:00/0018:06CB:7A13.0002/input/input16
[ 8.012072] hid-multitouch 0018:06CB:7A13.0002: input,hidraw1: I2C HID v1.00 Mouse [SYNA2393:00 06CB:7A13] on i2c-SYNA2393:00
[ 8.049762] ath10k_pci 0000:3b:00.0: htt-ver 3.60 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 8.079661] mousedev: PS/2 mouse device common for all mice
[ 8.113034] nouveau 0000:01:00.0: fb: 4096 MiB GDDR5
[ 8.130512] ath: EEPROM regdomain: 0x6c
[ 8.130513] ath: EEPROM indicates we should expect a direct regpair map
[ 8.130514] ath: Country alpha2 being used: 00
[ 8.130515] ath: Regpair used: 0x6c
[ 8.136592] ath10k_pci 0000:3b:00.0 wlp59s0: renamed from wlan0
[ 8.325121] mc: Linux media interface: v0.10
[ 8.350133] Bluetooth: Core ver 2.22
[ 8.350151] NET: Registered protocol family 31
[ 8.350152] Bluetooth: HCI device and connection manager initialized
[ 8.350155] Bluetooth: HCI socket layer initialized
[ 8.350157] Bluetooth: L2CAP socket layer initialized
[ 8.350160] Bluetooth: SCO socket layer initialized
[ 8.355575] videodev: Linux video capture interface: v2.00
[ 8.428078] device-mapper: uevent: version 1.0.3
[ 8.428156] device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: dm-devel@redhat.com
[ 8.443543] cdc_acm 1-7:1.0: ttyACM0: USB ACM device
[ 8.443692] usbcore: registered new interface driver cdc_acm
[ 8.443692] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 8.448364] [TTM] Zone kernel: Available graphics memory: 3746120 KiB
[ 8.448364] [TTM] Zone dma32: Available graphics memory: 2097152 KiB
[ 8.448365] [TTM] Initializing pool allocator
[ 8.448367] [TTM] Initializing DMA pool allocator
[ 8.448378] nouveau 0000:01:00.0: DRM: VRAM: 4096 MiB
[ 8.448379] nouveau 0000:01:00.0: DRM: GART: 536870912 MiB
[ 8.448380] nouveau 0000:01:00.0: DRM: BIT table 'A' not found
[ 8.448381] nouveau 0000:01:00.0: DRM: BIT table 'L' not found
[ 8.448382] nouveau 0000:01:00.0: DRM: Pointer to TMDS table not found
[ 8.448383] nouveau 0000:01:00.0: DRM: DCB version 4.1
[ 8.448858] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[ 8.449185] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 1
[ 8.449186] nouveau 0000:01:00.0: DRM: Disabling PCI power management to avoid bug
[ 8.500239] fbcon: Taking over console
[ 8.500403] usbcore: registered new interface driver btusb
[ 8.505264] Bluetooth: hci0: using rampatch file: qca/rampatch_usb_00000302.bin
[ 8.505266] Bluetooth: hci0: QCA: patch rome 0x302 build 0x3e8, firmware rome 0x302 build 0x111
[ 8.563946] Bluetooth: hci0: using NVM file: qca/nvm_usb_00000302.bin
[ 8.574591] uvcvideo: Found UVC 1.00 device Integrated_Webcam_HD (0c45:671d)
[ 8.580300] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.0/input/input18
[ 8.580438] usbcore: registered new interface driver uvcvideo
[ 8.580439] USB Video Class driver (1.1.1)
[ 9.150538] [drm] Initialized i915 1.6.0 20200715 for 0000:00:02.0 on minor 0
[ 9.183853] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 9.195094] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input19
[ 9.195413] ACPI: Video Device [PEGP] (multi-head: no rom: yes post: no)
[ 9.195489] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/LNXVIDEO:01/input/input20
[ 9.196095] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 9.196335] vga_switcheroo: enabled
[ 9.201438] fbcon: i915drmfb (fb0) is primary device
[ 10.345194] Console: switching to colour frame buffer device 240x67
[ 10.377900] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 10.499544] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3266: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 10.499550] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 10.499554] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 10.499557] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 10.499560] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 10.499564] snd_hda_codec_realtek hdaudioC0D0: Headset Mic=0x18
[ 10.499567] snd_hda_codec_realtek hdaudioC0D0: Headphone Mic=0x1a
[ 10.499570] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 10.578277] input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[ 10.578360] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 10.578433] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[ 10.578528] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[ 10.578584] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[ 10.578651] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
[ 13.591301] kauditd_printk_skb: 14 callbacks suppressed
[ 13.591302] audit: type=1131 audit(1609232679.606:26): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.731316] Key type trusted registered
[ 26.739656] Key type encrypted registered
[ 26.833692] audit: type=1130 audit(1609232692.850:27): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-cryptsetup@luks\x2dae6eaac8\x2da2f9\x2d468f\x2da12e\x2dd33184ca3973 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.894104] audit: type=1130 audit(1609232692.910:28): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-mapper-luks\x2dae6eaac8\x2da2f9\x2d468f\x2da12e\x2dd33184ca3973 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.915851] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[ 27.020358] audit: type=1130 audit(1609232693.036:29): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.043297] audit: type=1127 audit(1609232693.056:30): pid=805 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 27.054080] audit: type=1130 audit(1609232693.070:31): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.346232] audit: type=1130 audit(1609232693.360:32): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.350658] audit: type=1130 audit(1609232693.366:33): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.352391] audit: type=1130 audit(1609232693.366:34): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.356026] audit: type=1334 audit(1609232693.370:35): prog-id=7 op=LOAD
[ 27.356052] audit: type=1334 audit(1609232693.370:36): prog-id=8 op=LOAD
[ 28.221989] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 28.221994] Bluetooth: BNEP filters: protocol multicast
[ 28.222003] Bluetooth: BNEP socket layer initialized
[ 28.244826] NET: Registered protocol family 38
[ 28.800783] loop: module loaded
[ 28.841157] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 32.275459] nouveau 0000:01:00.0: gr: intr 00000040
[ 34.107238] kauditd_printk_skb: 34 callbacks suppressed
[ 34.107241] audit: type=1131 audit(1609232700.123:71): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 37.687442] audit: type=1334 audit(1609232703.703:72): prog-id=12 op=LOAD
[ 37.687522] audit: type=1334 audit(1609232703.703:73): prog-id=13 op=LOAD
[ 37.931826] audit: type=1130 audit(1609232703.946:74): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.966899] audit: type=1334 audit(1609232704.983:75): prog-id=14 op=LOAD
[ 38.967097] audit: type=1334 audit(1609232704.983:76): prog-id=15 op=LOAD
[ 39.020180] audit: type=1131 audit(1609232705.036:77): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 39.107927] audit: type=1130 audit(1609232705.123:78): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 39.289888] rfkill: input handler disabled
[ 39.362605] audit: type=1130 audit(1609232705.376:79): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 39.428173] audit: type=1130 audit(1609232705.443:80): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 39.472436] audit: type=1130 audit(1609232705.486:81): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.489957] audit: type=1130 audit(1609232706.503:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 49.218595] wlp59s0: authenticate with b0:98:2b:72:58:dd
[ 49.278651] wlp59s0: send auth to b0:98:2b:72:58:dd (try 1/3)
[ 49.285108] wlp59s0: authenticated
[ 49.293367] wlp59s0: associate with b0:98:2b:72:58:dd (try 1/3)
[ 49.298516] wlp59s0: RX AssocResp from b0:98:2b:72:58:dd (capab=0x431 status=0 aid=5)
[ 49.301083] wlp59s0: associated
[ 49.301272] ath: EEPROM regdomain: 0x8114
[ 49.301275] ath: EEPROM indicates we should expect a country code
[ 49.301277] ath: doing EEPROM country->regdmn map search
[ 49.301280] ath: country maps to regdmn code: 0x37
[ 49.301284] ath: Country alpha2 being used: DE
[ 49.301286] ath: Regpair used: 0x37
[ 49.301289] ath: regdomain 0x8114 dynamically updated by country element
[ 49.377681] IPv6: ADDRCONF(NETDEV_CHANGE): wlp59s0: link becomes ready
[ 49.691852] audit: type=1130 audit(1609232715.706:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 58.659038] audit: type=1100 audit(1609232724.673:84): pid=1395 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="roger" exe="/usr/lib/gdm-session-worker" hostname=roger addr=? terminal=/dev/tty1 res=success'
[ 58.663260] audit: type=1101 audit(1609232724.676:85): pid=1395 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="roger" exe="/usr/lib/gdm-session-worker" hostname=roger addr=? terminal=/dev/tty1 res=success'
[ 58.666684] audit: type=1103 audit(1609232724.680:86): pid=1395 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="roger" exe="/usr/lib/gdm-session-worker" hostname=roger addr=? terminal=/dev/tty1 res=success'
[ 58.683877] audit: type=1006 audit(1609232724.700:87): pid=1395 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 58.728404] audit: type=1130 audit(1609232724.743:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 58.746104] audit: type=1101 audit(1609232724.760:89): pid=1399 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="roger" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 58.746214] audit: type=1103 audit(1609232724.760:90): pid=1399 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="roger" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 58.746366] audit: type=1006 audit(1609232724.760:91): pid=1399 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=4 res=1
[ 58.759728] audit: type=1105 audit(1609232724.773:92): pid=1399 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="roger" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 58.778111] audit: type=1334 audit(1609232724.793:93): prog-id=16 op=LOAD
[ 61.079456] rfkill: input handler enabled
[ 61.206896] nouveau 0000:01:00.0: gr: intr 00000040
[ 61.612689] fuse: init (API version 7.31)
[ 63.139035] Bluetooth: RFCOMM TTY layer initialized
[ 63.139045] Bluetooth: RFCOMM socket layer initialized
[ 63.139051] Bluetooth: RFCOMM ver 1.11
[ 63.696164] kauditd_printk_skb: 4 callbacks suppressed
[ 63.696165] audit: type=1130 audit(1609232729.683:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 65.227134] rfkill: input handler disabled
[ 67.802943] audit: type=1106 audit(1609232733.777:99): pid=883 uid=0 auid=120 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=roger addr=? terminal=/dev/tty1 res=success'
[ 67.803125] audit: type=1104 audit(1609232733.780:100): pid=883 uid=0 auid=120 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=roger addr=? terminal=/dev/tty1 res=success'
[ 69.665697] audit: type=1130 audit(1609232735.636:101): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fwupd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 71.057249] audit: type=1131 audit(1609232737.027:102): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 77.965442] audit: type=1131 audit(1609232743.927:103): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 77.995998] audit: type=1131 audit(1609232743.957:104): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 95.376720] audit: type=1131 audit(1609232761.337:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 95.469632] audit: type=1334 audit(1609232761.430:106): prog-id=10 op=UNLOAD
[ 95.469639] audit: type=1334 audit(1609232761.430:107): prog-id=9 op=UNLOAD
[ 98.206275] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.PEG0.PEGP.BRT6.LCD], AE_NOT_FOUND (20200717/psargs-330)
[ 98.206295] ACPI Error: Aborting method \_SB.PCI0.PEG0.PEGP.BRT6 due to previous error (AE_NOT_FOUND) (20200717/psparse-529)
[ 98.206511] ACPI Error: Aborting method \EV5 due to previous error (AE_NOT_FOUND) (20200717/psparse-529)
[ 98.206656] ACPI Error: Aborting method \SMEE due to previous error (AE_NOT_FOUND) (20200717/psparse-529)
[ 98.206804] ACPI Error: Aborting method \SMIE due to previous error (AE_NOT_FOUND) (20200717/psparse-529)
[ 98.206948] ACPI Error: Aborting method \NEVT due to previous error (AE_NOT_FOUND) (20200717/psparse-529)
[ 98.207092] ACPI Error: Aborting method \_SB.PCI0.LPCB.ECDV._Q66 due to previous error (AE_NOT_FOUND) (20200717/psparse-529)
[ 99.073862] audit: type=1131 audit(1609232765.034:108): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 101.085150] audit: type=1131 audit(1609232767.044:109): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 101.172153] audit: type=1334 audit(1609232767.131:110): prog-id=13 op=UNLOAD
[ 101.172160] audit: type=1334 audit(1609232767.131:111): prog-id=12 op=UNLOAD
[ 785.260018] audit: type=1334 audit(1609233451.225:112): prog-id=17 op=LOAD
[ 785.260076] audit: type=1334 audit(1609233451.225:113): prog-id=18 op=LOAD
[ 785.555467] audit: type=1130 audit(1609233451.521:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 815.607600] audit: type=1131 audit(1609233481.572:115): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 815.706127] audit: type=1334 audit(1609233481.672:116): prog-id=18 op=UNLOAD
[ 815.706135] audit: type=1334 audit(1609233481.672:117): prog-id=17 op=UNLOAD
[ 909.839539] audit: type=1130 audit(1609233575.805:118): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 909.839550] audit: type=1131 audit(1609233575.805:119): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 923.098906] audit: type=1130 audit(1609233589.065:120): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 928.104257] audit: type=1131 audit(1609233594.072:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 937.317963] input: IR-190 CD (AVRCP) as /devices/virtual/input/input27
[ 1773.351388] process '/usr/bin/Waveform11' started with executable stack
[ 3142.866214] audit: type=1334 audit(1609235808.851:122): prog-id=19 op=LOAD
[ 3142.866242] audit: type=1334 audit(1609235808.851:123): prog-id=20 op=LOAD
[ 3143.132862] audit: type=1130 audit(1609235809.118:124): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3173.182545] audit: type=1131 audit(1609235839.169:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3173.250890] audit: type=1334 audit(1609235839.239:126): prog-id=20 op=UNLOAD
[ 3173.250898] audit: type=1334 audit(1609235839.239:127): prog-id=19 op=UNLOAD
[ 3866.087937] audit: type=1130 audit(1609236532.083:128): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3876.041838] audit: type=1131 audit(1609236542.036:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4223.780483] wlp59s0: authenticate with b0:98:2b:72:58:de
[ 4223.818003] wlp59s0: send auth to b0:98:2b:72:58:de (try 1/3)
[ 4223.823244] wlp59s0: authenticated
[ 4223.825028] wlp59s0: associate with b0:98:2b:72:58:de (try 1/3)
[ 4223.827106] wlp59s0: RX AssocResp from b0:98:2b:72:58:de (capab=0x411 status=0 aid=1)
[ 4223.829642] wlp59s0: associated
[ 4223.849689] wlp59s0: disassociated from b0:98:2b:72:58:de (Reason: 2=PREV_AUTH_NOT_VALID)
[ 4265.701093] wlp59s0: authenticate with b0:98:2b:72:58:dd
[ 4265.749921] wlp59s0: send auth to b0:98:2b:72:58:dd (try 1/3)
[ 4265.793718] wlp59s0: authenticated
[ 4265.794496] wlp59s0: associate with b0:98:2b:72:58:dd (try 1/3)
[ 4265.799732] wlp59s0: RX AssocResp from b0:98:2b:72:58:dd (capab=0x431 status=0 aid=2)
[ 4265.802921] wlp59s0: associated
[ 4265.803040] ath: EEPROM regdomain: 0x8114
[ 4265.803042] ath: EEPROM indicates we should expect a country code
[ 4265.803043] ath: doing EEPROM country->regdmn map search
[ 4265.803044] ath: country maps to regdmn code: 0x37
[ 4265.803046] ath: Country alpha2 being used: DE
[ 4265.803047] ath: Regpair used: 0x37
[ 4265.803049] ath: regdomain 0x8114 dynamically updated by country element
[ 4265.880175] IPv6: ADDRCONF(NETDEV_CHANGE): wlp59s0: link becomes ready
[ 4266.274501] audit: type=1130 audit(1609236932.274:130): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4277.036722] audit: type=1131 audit(1609236943.038:131): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4300.765017] wlp59s0: deauthenticated from b0:98:2b:72:58:dd (Reason: 6=CLASS2_FRAME_FROM_NONAUTH_STA)
[ 4300.939885] wlp59s0: authenticate with b0:98:2b:72:58:dd
[ 4300.988362] wlp59s0: send auth to b0:98:2b:72:58:dd (try 1/3)
[ 4301.090772] wlp59s0: send auth to b0:98:2b:72:58:dd (try 2/3)
[ 4301.204085] wlp59s0: send auth to b0:98:2b:72:58:dd (try 3/3)
[ 4301.236299] wlp59s0: authenticated
[ 4301.240733] wlp59s0: associate with b0:98:2b:72:58:dd (try 1/3)
[ 4301.280403] wlp59s0: RX AssocResp from b0:98:2b:72:58:dd (capab=0x431 status=0 aid=1)
[ 4301.283592] wlp59s0: associated
[ 4301.283770] ath: EEPROM regdomain: 0x8114
[ 4301.283772] ath: EEPROM indicates we should expect a country code
[ 4301.283774] ath: doing EEPROM country->regdmn map search
[ 4301.283776] ath: country maps to regdmn code: 0x37
[ 4301.283778] ath: Country alpha2 being used: DE
[ 4301.283780] ath: Regpair used: 0x37
[ 4301.283782] ath: regdomain 0x8114 dynamically updated by country element
[ 4301.322609] wlp59s0: disassociated from b0:98:2b:72:58:dd (Reason: 2=PREV_AUTH_NOT_VALID)
[ 4301.447897] audit: type=1130 audit(1609236967.452:132): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4312.035289] audit: type=1131 audit(1609236978.038:133): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4326.824305] audit: type=1130 audit(1609236992.829:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4337.032189] audit: type=1131 audit(1609237003.035:135): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4351.175932] wlp59s0: authenticate with b0:98:2b:72:58:de
[ 4351.210148] wlp59s0: send auth to b0:98:2b:72:58:de (try 1/3)
[ 4351.215623] wlp59s0: authenticated
[ 4351.220076] wlp59s0: associate with b0:98:2b:72:58:de (try 1/3)
[ 4351.222432] wlp59s0: RX AssocResp from b0:98:2b:72:58:de (capab=0x411 status=0 aid=3)
[ 4351.225525] wlp59s0: associated
[ 4351.478392] audit: type=1130 audit(1609237017.479:136): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4362.034825] audit: type=1131 audit(1609237028.036:137): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5091.645241] audit: type=1130 audit(1609237757.657:138): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5096.652075] audit: type=1131 audit(1609237762.667:139): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5359.565418] audit: type=1334 audit(1609238025.584:140): prog-id=21 op=LOAD
[ 5359.565421] audit: type=1334 audit(1609238025.584:141): prog-id=22 op=LOAD
[ 5359.811387] audit: type=1130 audit(1609238025.831:142): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5399.482392] audit: type=1131 audit(1609238065.501:143): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5399.613744] audit: type=1334 audit(1609238065.631:144): prog-id=22 op=UNLOAD
[ 5399.613748] audit: type=1334 audit(1609238065.631:145): prog-id=21 op=UNLOAD
[ 6082.889692] audit: type=1334 audit(1609238748.918:146): prog-id=23 op=LOAD
[ 6082.889725] audit: type=1334 audit(1609238748.918:147): prog-id=24 op=LOAD
[ 6083.155464] audit: type=1130 audit(1609238749.184:148): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6113.202748] audit: type=1131 audit(1609238779.231:149): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6113.293872] audit: type=1334 audit(1609238779.325:150): prog-id=24 op=UNLOAD
[ 6113.293878] audit: type=1334 audit(1609238779.325:151): prog-id=23 op=UNLOAD
[ 6207.600243] audit: type=1334 audit(1609238873.629:152): prog-id=25 op=LOAD
[ 6207.600284] audit: type=1334 audit(1609238873.629:153): prog-id=26 op=LOAD
[ 6207.859057] audit: type=1130 audit(1609238873.886:154): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6237.909609] audit: type=1131 audit(1609238903.940:155): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6238.022893] audit: type=1334 audit(1609238904.053:156): prog-id=26 op=UNLOAD
[ 6238.022906] audit: type=1334 audit(1609238904.053:157): prog-id=25 op=UNLOAD
[ 6294.487863] audit: type=1334 audit(1609238960.517:158): prog-id=27 op=LOAD
[ 6294.487902] audit: type=1334 audit(1609238960.517:159): prog-id=28 op=LOAD
[ 6294.762329] audit: type=1130 audit(1609238960.794:160): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6324.817424] audit: type=1131 audit(1609238990.848:161): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6324.971054] audit: type=1334 audit(1609238991.004:162): prog-id=28 op=UNLOAD
[ 6324.971063] audit: type=1334 audit(1609238991.004:163): prog-id=27 op=UNLOAD
[ 6691.469770] audit: type=1334 audit(1609239357.506:164): prog-id=29 op=LOAD
[ 6691.469852] audit: type=1334 audit(1609239357.506:165): prog-id=30 op=LOAD
[ 6691.718550] audit: type=1130 audit(1609239357.753:166): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6721.766730] audit: type=1131 audit(1609239387.804:167): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6721.874903] audit: type=1334 audit(1609239387.914:168): prog-id=30 op=UNLOAD
[ 6721.874912] audit: type=1334 audit(1609239387.914:169): prog-id=29 op=UNLOAD
[ 7331.089713] audit: type=1131 audit(1609239997.146:170): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fwupd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8003.148116] audit: type=1130 audit(1609240669.220:171): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8003.154248] wlp59s0: deauthenticating from b0:98:2b:72:58:de by local choice (Reason: 3=DEAUTH_LEAVING)
[ 8003.517615] PM: suspend entry (s2idle)
[ 8004.347577] Filesystems sync: 0.829 seconds
[ 8004.348651] Freezing user space processes ... (elapsed 0.003 seconds) done.
[ 8004.352266] OOM killer disabled.
[ 8004.352267] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 8004.353665] printk: Suspending console(s) (use no_console_suspend to debug)
[ 8004.675039] ACPI: EC: interrupt blocked
[ 8486.166827] ACPI: EC: interrupt unblocked
[ 8487.639644] ata3: SATA link down (SStatus 4 SControl 300)
[ 8487.669229] OOM killer enabled.
[ 8487.669230] Restarting tasks ... done.
[ 8487.730223] PM: suspend exit
[ 8487.967654] audit: type=1130 audit(1609241153.800:172): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8487.967656] audit: type=1131 audit(1609241153.800:173): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8488.079820] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 8488.942915] audit: type=1130 audit(1609241154.776:174): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8494.265319] audit: type=1100 audit(1609241160.100:175): pid=11155 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="roger" exe="/usr/lib/gdm-session-worker" hostname=roger addr=? terminal=/dev/tty1 res=success'
[ 8494.266792] audit: type=1101 audit(1609241160.100:176): pid=11155 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="roger" exe="/usr/lib/gdm-session-worker" hostname=roger addr=? terminal=/dev/tty1 res=success'
[ 8494.267830] audit: type=1110 audit(1609241160.100:177): pid=11155 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="roger" exe="/usr/lib/gdm-session-worker" hostname=roger addr=? terminal=/dev/tty1 res=success'
[ 8494.389575] audit: type=1131 audit(1609241160.223:178): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8508.296827] wlp59s0: authenticate with b0:98:2b:72:58:de
[ 8508.333462] wlp59s0: send auth to b0:98:2b:72:58:de (try 1/3)
[ 8508.338781] wlp59s0: authenticated
[ 8508.348203] wlp59s0: associate with b0:98:2b:72:58:de (try 1/3)
[ 8508.350420] wlp59s0: RX AssocResp from b0:98:2b:72:58:de (capab=0x411 status=0 aid=3)
[ 8508.353953] wlp59s0: associated
[ 8508.378874] IPv6: ADDRCONF(NETDEV_CHANGE): wlp59s0: link becomes ready
[ 8508.579637] audit: type=1130 audit(1609241174.413:179): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8518.394360] audit: type=1131 audit(1609241184.227:180): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8519.385374] audit: type=1131 audit(1609241185.220:181): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8547.233771] audit: type=1334 audit(1609241213.067:182): prog-id=31 op=LOAD
[ 8547.233806] audit: type=1334 audit(1609241213.067:183): prog-id=32 op=LOAD
[ 8547.490828] audit: type=1130 audit(1609241213.327:184): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8577.543179] audit: type=1131 audit(1609241243.378:185): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8577.623899] audit: type=1334 audit(1609241243.461:186): prog-id=32 op=UNLOAD
[ 8577.623902] audit: type=1334 audit(1609241243.461:187): prog-id=31 op=UNLOAD
[ 8781.433038] audit: type=1130 audit(1609241447.272:188): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8784.644485] audit: type=1100 audit(1609241450.485:189): pid=12294 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="roger" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 8784.645332] audit: type=1101 audit(1609241450.485:190): pid=12294 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="roger" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 8784.645460] audit: type=1110 audit(1609241450.485:191): pid=12294 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 8784.646268] audit: type=1105 audit(1609241450.485:192): pid=12294 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
