Problems with audio input - ASRock B450 Gaming K4
So I was using my microphone and then it suddendly stopped working, I switched to a backup and after some days it too stopped. For a brief moment (before unpluging it) my old microphone started working again. Is there a reason as to why this is happening? Any ideas anyone?
  Kernel: 6.6.30-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=cdd3fd40-78bf-4352-beb4-1a546769a9eb rw nvidia-drm.modeset=1
  Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.1.0
    wm: kwin_x11 tools: avail: hyprlock vt: 2 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: ASRock model: B450 Gaming K4 serial: <superuser required>
    uuid: <superuser required> UEFI-[Legacy]: American Megatrends v: P3.90
    date: 12/12/2019
  System RAM: total: 16 GiB available: 15.55 GiB used: 5 GiB (32.1%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 3000 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3000C16-8GISB serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
    level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
    model-id: 8 stepping: 2 microcode: 0x800820D
    L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
    desc: 2x8 MiB
  Speed (MHz): avg: 2354 high: 3897 min/max: 1550/3400 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1380 2: 1550
    3: 1365 4: 1557 5: 3897 6: 2295 7: 1550 8: 3893 9: 1451 10: 1557 11: 3860
    12: 3894 bogomips: 81483
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: ASUSTeK
    driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none off: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 0a:00.0
    chip-ID: 10de:21c4 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1360x768 s-dpi: 21 s-size: 1645x929mm (64.76x36.57")
    s-diag: 1889mm (74.38")
  Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: LG (GoldStar) TV
    serial: <filter> built: 2017 res: 1360x768 hz: 60 dpi: 22 gamma: 1.2
    size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9 modes:
    max: 1360x768 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
    memory: 5.86 GiB
  API: Vulkan v: 1.3.279 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1660 SUPER driver: nvidia v: 550.78 device-ID: 10de:21c4
    surfaces: xcb,xlib
  Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
    bus-ID: 0a:00.1 chip-ID: 10de:1aeb class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0c:00.3
    chip-ID: 1022:1457 class-ID: 0403
  API: ALSA v: k6.6.30-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.14 TiB used: 61.19 GiB (5.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Patriot model: P300 256GB
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: S1111H0L temp: 47.9 C
    scheme: MBR
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-60WN4A1
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A03 scheme: MBR
  ID-1: / raw-size: 119.23 GiB size: 116.8 GiB (97.96%) used: 61.19 GiB (52.4%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: cdd3fd40-78bf-4352-beb4-1a546769a9eb
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 119.24 GiB fs: ntfs label: N/A
    uuid: 54D21BF9D21BDE54
  ID-2: /dev/sda1 maj-min: 8:1 size: 465.75 GiB fs: ntfs label: Win 1TB
    uuid: 31676935625B1755
  ID-3: /dev/sda2 maj-min: 8:2 size: 465.75 GiB fs: ext4 label: Lin 1TB
    uuid: 3b45f49b-0f8c-450a-aabb-00212d03ef71
  Hub-2: 1-8:2 info: NEC HighSpeed Hub ports: 4 rev: 2.0
    chip-ID: 0409:005a class-ID: 0900
  Hub-3: 1-8.4:3 info: NEC HighSpeed Hub ports: 4 rev: 2.0
  Device-1: 1-8.4.1:4 info: SINO WEALTH Gaming KB type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 258a:002a class-ID: 0300
  Device-2: 1-8.4.4:5 info: Speedy Supplies Pte. USB Gaming Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 1017:8003 class-ID: 0300
  Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-8: 6-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 48.8 C mobo: N/A gpu: nvidia temp: 40 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 26%
  Processes: 342 Power: uptime: 21m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: 1510 pm: pacman pkgs: 1502 libs: 396 tools: pamac,yay pm: flatpak
    pkgs: 8 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: konsole inxi: 3.3.34
I suggest update BIOS to latest non-beta version 5.60 - ASRock > Fatal1ty B450 Gaming K4
If microphone is still not working after BIOS update, check audio settings in ALSA
amixer --card=1
And audio cards and profiles in PipeWire
pactl list cards
