Problems with AMD CPU integrated graphics and nvidia GPU
  Kernel: 5.8.1-3-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=16b2b3a4-3d2d-4a9a-acbe-1fe4b14bc9ab rw quiet
  cryptdevice=UUID=7dac0c1b-8747-400d-a776-086e1da77528:luks-7dac0c1b-8747-400d-a776-086e1da77528
  root=/dev/mapper/luks-7dac0c1b-8747-400d-a776-086e1da77528 apparmor=1
  security=apparmor
  resume=/dev/mapper/luks-7442edda-8193-449d-b8b7-0fa374e07632
  udev.log_priority=3
  Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <filter>
  UEFI: American Megatrends v: FX505DT.308 date: 09/19/2019
  ID-1: BAT0 charge: 41.5 Wh condition: 42.6/48.1 Wh (89%) volts: 11.8/11.7
  model: FX50442 type: Li-ion serial: N/A status: Discharging
  Topology: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
  bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 18 (24)
  stepping: 1 microcode: 8108102 L2 cache: 2048 KiB
  bogomips: 33550
  Speed: 1222 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
  1: 1222 2: 1222 3: 1222 4: 1319 5: 1276 6: 1395 7: 1241 8: 1343
  disabled, RSB filling
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] driver: nouveau
  v: kernel bus ID: 01:00.0 chip ID: 10de:1f91
  Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
  bus ID: 05:00.0 chip ID: 1002:15d8
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
  bus ID: 3-1:2 chip ID: 13d3:56a2 serial: <filter>
  Display: x11 server: X.Org 1.20.8 compositor: kwin_x11
  driver: amdgpu,modesetting,nouveau FAILED: ati alternate: fbdev,nv,vesa
  display ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP res: 1920x1080 hz: 120 dpi: 142 size: 344x194mm (13.5x7.6")
  diag: 395mm (15.5")
  OpenGL: renderer: AMD RAVEN (DRM 3.38.0 5.8.1-3-MANJARO LLVM 10.0.1)
  v: 4.6 Mesa 20.1.5 direct render: Yes
  Device-1: NVIDIA driver: snd_hda_intel v: kernel bus ID: 01:00.1
  chip ID: 10de:10fa
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
  Sound Server: ALSA v: k5.8.1-3-MANJARO
  vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus ID: 02:00.0
  chip ID: 10ec:8168
  Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
  vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: c000
  bus ID: 04:00.0 chip ID: 10ec:c822
  IF: wlp4s0 state: up mac: <filter>
  Local Storage: total: 238.47 GiB used: 9.99 GiB (4.2%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: RBUSNS8154P3256GJ3
  size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
  lanes: 2 serial: <filter> rev: E8FK11.T scheme: GPT
  ID-1: / raw size: 229.37 GiB size: 224.77 GiB (97.99%) used: 9.99 GiB (4.4%)
  fs: ext4 dev: /dev/dm-0
  ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/dm-1
  System Temperatures: cpu: 38.2 C mobo: N/A
  GPU: device: amdgpu temp: 38 C device: nouveau temp: N/A
  Processes: 241 Uptime: 7m Memory: 15.51 GiB used: 1.39 GiB (9.0%)
  Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1217 lib: 344
  flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
I just switched to Manjaro KDE on my laptop and when I install the nvidia proprietary driver, my laptop won’t make it to the boot menu. I was able to fix this issue on Mint when I had it installed but I just can’t figure out how to fix it on Manjaro. Any help would be greatly appreciated!
can you please returns
sudo mhwd -li
sudo mhwd -l
Absolutely. Here you go:
Installed PCI configs:
           video-linux            2018.05.04                true            PCI
0000:02:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
> 0000:01:00.0 (0300:10de:1f91) Display controller nVidia Corporation:
video-hybrid-amd-nvidia-450xx-prime            2019.10.25               false            PCI
video-hybrid-amd-nvidia-440xx-prime            2019.10.25               false            PCI
video-hybrid-amd-nvidia-435xx-prime            2019.10.25               false            PCI
    video-nvidia-450xx            2019.10.25               false            PCI
    video-nvidia-440xx            2019.10.25               false            PCI
    video-nvidia-435xx            2019.10.25               false            PCI
    video-nvidia-430xx            2019.10.25               false            PCI
    video-nvidia-418xx            2019.10.25               false            PCI
> 0000:05:00.0 (0300:1002:15d8) Display controller ATI Technologies Inc:
then you should add
sudo mhwd -i pci video-hybrid-amd-nvidia-450xx-prime
and reboot
glxinfo | grep 'renderer string'
prime-run glxinfo | grep 'renderer string'
# Nvidia render-offload alias
alias nvr="__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia"
alias vkr="__NV_PRIME_RENDER_OFFLOAD=1"
after you close/open terminal the alias for both will be set and then it’s
#opengl
nvr glxgears
#vulkan
vkr vkcube
after running this i got:
invalid option: pci
Usage: mhwd [OPTIONS] <config(s)>
  --pci                                 list only pci devices and driver configs
  --usb                                 list only usb devices and driver configs
  -h/--help                             show help
  -v/--version                          show version of mhwd
  -f/--force                            force reinstallation
  -d/--detail                           show detailed info for -l/-li/-lh
  -l/--list                             list available configs for devices
  -la/--listall                         list all driver configs
  -li/--listinstalled                   list installed driver configs
  -lh/--listhardware                    list hardware information
  -i/--install <usb/pci> <config(s)>    install driver config(s)
  -ic/--installcustom <usb/pci> <path>  install custom config(s)
  -r/--remove <usb/pci> <config(s)>     remove driver config(s)
  -a/--auto <usb/pci> <free/nonfree> <classid>  auto install configs for classid
  --pmcachedir <path>                   set package manager cache path
  --pmconfig <path>                     set package manager config
  --pmroot <path>                       set package manager root
should i change pci in that command to --pci? sorry if i seem clueless, i just want to make sure i do everything properly as to not mess anything up.
ok so i’ve done everything up to this part. once i input either of these commands i just get :
bash: nvr: command not found
bash: vkr: command not found
add theses alias before
ok so i got nvr glxgears to run but i’m getting this for vkr vkcube:
bash: vkcube: command not found
edit: sorry i pasted the wrong line originally
Hi!
the command to install the driver would be something like this
sudo mhwd -i pci driver
To add the alias lines you have two opcions
  1. Open the file .bashrc and add those lines at the end, save, and run
    source .basrc
  2. run this lines from the terminal
    echo " alias nvr="__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia" >> .bashrc "
    echo " alias vkr="__NV_PRIME_RENDER_OFFLOAD=1" >> .bashrc "
    then again
    source .bashrc
hey, i think this worked. it looks like my laptop is now using nvidia v 450.57 as its main driver. thank you and thanks to stephane for all the help. i truly appreciate it!
