Problems with Alias after Konsole changes
Hello dear Commuity,
some time ago I wrote some aliases to make my use of Manjaro easier.
But I have the problem that they are not found anymore and I guess it is because I made changes in Konsole. Actually I just created a new profile to be able to see more lines, more precisely infinite.
Since then my aliases have stopped working.
If I enter an alias and want to use it as I did back then
backhome > ~/Dokumente/_Terminal/backhome241324.txt
I only get an error message:
bash: backhome: Kommando nicht gefunden.
If I enter source ~/.bashrc, there is no output and no error message.
If I enter source ~/.zshrc, I get a whole bunch of output:
bash: setopt: Kommando nicht gefunden.
bash: zstyle: Kommando nicht gefunden.
bash: ${(s.:.)LS_COLORS}: Falsche Substitution.
bash: bindkey: Kommando nicht gefunden.
bash: autoload: Kommando nicht gefunden.
bash: compinit: Kommando nicht gefunden.
Color escapes are \e[${value};...;${value}m
Values 30..37 are foreground colors
Values 40..47 are background colors
Value  1 gives a  bold-faced look
  \e[30m    TEXT BOLD  \e[30;41m TEXT BOLD  \e[30;42m TEXT BOLD  \e[30;43m TEXT BOLD  \e[30;44m TEXT BOLD  \e[30;45m TEXT BOLD  \e[30;46m TEXT BOLD  \e[30;47m TEXT BOLD
  \e[31m    TEXT BOLD  \e[31;41m TEXT BOLD  \e[31;42m TEXT BOLD  \e[31;43m TEXT BOLD  \e[31;44m TEXT BOLD  \e[31;45m TEXT BOLD  \e[31;46m TEXT BOLD  \e[31;47m TEXT BOLD
  \e[32m    TEXT BOLD  \e[32;41m TEXT BOLD  \e[32;42m TEXT BOLD  \e[32;43m TEXT BOLD  \e[32;44m TEXT BOLD  \e[32;45m TEXT BOLD  \e[32;46m TEXT BOLD  \e[32;47m TEXT BOLD
  \e[33m    TEXT BOLD  \e[33;41m TEXT BOLD  \e[33;42m TEXT BOLD  \e[33;43m TEXT BOLD  \e[33;44m TEXT BOLD  \e[33;45m TEXT BOLD  \e[33;46m TEXT BOLD  \e[33;47m TEXT BOLD
  \e[34m    TEXT BOLD  \e[34;41m TEXT BOLD  \e[34;42m TEXT BOLD  \e[34;43m TEXT BOLD  \e[34;44m TEXT BOLD  \e[34;45m TEXT BOLD  \e[34;46m TEXT BOLD  \e[34;47m TEXT BOLD
  \e[35m    TEXT BOLD  \e[35;41m TEXT BOLD  \e[35;42m TEXT BOLD  \e[35;43m TEXT BOLD  \e[35;44m TEXT BOLD  \e[35;45m TEXT BOLD  \e[35;46m TEXT BOLD  \e[35;47m TEXT BOLD
  \e[36m    TEXT BOLD  \e[36;41m TEXT BOLD  \e[36;42m TEXT BOLD  \e[36;43m TEXT BOLD  \e[36;44m TEXT BOLD  \e[36;45m TEXT BOLD  \e[36;46m TEXT BOLD  \e[36;47m TEXT BOLD
  (default) TEXT BOLD  \e[41m    TEXT BOLD  \e[42m    TEXT BOLD  \e[43m    TEXT BOLD  \e[44m    TEXT BOLD  \e[45m    TEXT BOLD  \e[46m    TEXT BOLD  \e[47m    TEXT BOLD
bash: alias: -L: Ungültige Option.
alias: Aufruf: alias [-p] [Name[=Wert] ... ]
bash: unalias: -m: Ungültige Option.
unalias: Aufruf: unalias [-a] Name [Name ...]
bash: 0=${(%):-%N}: Falsche Substitution.
bash: /.version: Datei oder Verzeichnis nicht gefunden
bash: /.revision-hash: Datei oder Verzeichnis nicht gefunden
bash: is-at-least: Kommando nicht gefunden.
bash: /usr/share/zsh/plugins/zsh-syntax-highlighting/zsh-syntax-highlighting.zsh: Zeile 242: Syntaxfehler beim unerwarteten Symbol »always«
bash: /usr/share/zsh/plugins/zsh-syntax-highlighting/zsh-syntax-highlighting.zsh: Zeile 242: `        } always {'
bash: zle: Kommando nicht gefunden.
bash: zmodload: Kommando nicht gefunden.
bash: /usr/share/zsh/plugins/zsh-history-substring-search/zsh-history-substring-search.zsh: Zeile 165: Syntaxfehler beim unerwarteten Symbol »)«
bash: /usr/share/zsh/plugins/zsh-history-substring-search/zsh-history-substring-search.zsh: Zeile 165: `      () {'
bash: /usr/share/zsh/manjaro-zsh-config: Zeile 155: Syntaxfehler beim unerwarteten Symbol »<«
bash: /usr/share/zsh/manjaro-zsh-config: Zeile 155: `      <->) # %number argument:'
bash: /usr/share/zsh/manjaro-zsh-prompt: Zeile 1: Syntaxfehler beim unerwarteten Symbol »)«
bash: /usr/share/zsh/manjaro-zsh-prompt: Zeile 1: `() {'
Something is going wrong here, but I don’t know exactly what’s going on and what I should do.
Looks like you have zsh set up and configured by default.
Then you created a new profile.
And didnt set it to zsh.
Then you tried to load (both, but the only existing one was) .zshrc from a bash shell.
A: Change your profile shell to zsh
( Something like Konsole > Edit Current Profile > General > General Settings > Command : /usr/bin/zsh )
OK, but please explain how.
Or thats how I have the equivalent set for bash (/usr/bin/bash) anyways.
Given that all your rc lines produce errors beginning with bash, I assume that is the current shell.
OK, your answer was almost perfect.
I had to change to
Konsole > Edit Current Profile > General > General Settings > Command : /usr/zsh
because i have no directory named bash in bin.
But now it’s working thanks a lot anyway and merry xmas.
… are we sure this is the correct path ?
The path I suggested was /usr/bin/zsh
And I dont think it should be any other path…
oh sorry, i meant
Konsole > Edit Current Profile > General > General Settings > Command : /bin/zsh
That should ‘work’ because /bin is a symlink to /usr/bin.
So if you prefer it :person_shrugging:
(The file that is installed by the package zsh is /usr/bin/zsh)
