# systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
● systemd-backlight@backlight:acpi_video1.service loaded failed failed Load/Save Screen Backlight Brightness of backlight:acpi_video1
● systemd-backlight@backlight:amdgpu_bl1.service loaded failed failed Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
2 loaded units listed.
# inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=71d09306-dd24-41a2-82dc-f006eb4f8ebf rw quiet apparmor=1
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Device-1: NVIDIA TU117M vendor: Lenovo driver: nvidia v: 455.38
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f99
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus ID: 05:00.0
chip ID: 1002:1636
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus ID: 1-3:2 chip ID: 13d3:56ff
Display: x11 server: X.Org 1.20.9 driver: nvidia display ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x572mm (40.0x22.5")
s-diag: 1166mm (45.9")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 163
size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA 455.38
direct render: Yes
