I’m having trouble sharing my screen using Wayland in Manjaro. At least in browsers like Chrome, I found that you can share the browser tab by enabling chrome://flags/#enable-webrtc-pipewire-capturer. But if I want to share the entire computer screen, I can’t. Is it possible to fix this without using Xorg?
Manjaro still use by default PulseAudio. You need replace it with Pipewire. Do it by install manjaro-pipewire:
sudo pacman -S manjaro-pipewire
If you don’t run on Pipewire this flag does nothing.
Thanks!
