Problems updating
I use manjaro linux with the xfce DE and for roughly a month I have not done any updates recently I ran:
sudo pacman -Syu
which did not work so per the instructions on the manjaro ([Stable Update] 2023-10-13 - Pipewire, Mattermost, Qt5, Haskell, Python - #2 by philm) forum I instead ran:
sudo pacman -Syu glibc-locales --overwrite /usr/lib/locale/\*/\*
which worked the problem is after restarting my computer I get an error:
error: file `/wrong` not found.
Press any key to continue...
in the GRUB menu I am given two options one called Manjaro Linux (Kernel: wrong) and another called Manjaro Linux (Kernel: directory) which gives the same error
I would appreciate any help
update:
help I followed these instruction [HowTo] Recovering from an interrupted update/upgrade and now I am seeing this:
Seems like you might have a bad entry in /etc/fstab
.. now with the updated info .. it might still be the case, with mounting failing.
You will need access to the system somehow. By chroot, etc.
Thanks for your reply, this is the output of manjaro-chroot -a and the fstab file in question. I am new to this and do I do not know what to look for if you could point out an issue or point me to a resource I could use to try to fix it myself I would really appreciated it, as for what you mean by ā€œmounting failingā€ could you clarify?
==> Mounting (ManjaroLinux) [/dev/nvme0n1p2]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=3077-D02F                            /boot/efi      vfat    umask=0077 0 2
UUID=304ed894-b2cb-454b-ba43-bfffb9ad218f /              ext4    defaults,noatime 0 1
UUID=c4d0b91b-c5fc-4741-8a32-eafad561e4de swap           swap    defaults,noatime 0 0
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
/dev/sda1    /hdd    ext4    defaults    0    0
… and now compare to the UUID’s from output of
sudo blkid
By the way:
This is not smart, rather use UUID or label as /dev/sda1 is not reliably the same partition, always.
The output of sudo blkid:
/dev/loop1: BLOCK_SIZE="262144" TYPE="squashfs"
/dev/nvme0n1p3: LABEL="swap" UUID="c4d0b91b-c5fc-4741-8a32-eafad561e4de" TYPE="swap" PARTUUID="d5067299-b144-144b-8294-f0da5d2f6ed6"
/dev/nvme0n1p1: LABEL_FATBOOT="NO_LABEL" LABEL="NO_LABEL" UUID="3077-D02F" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="b0ebd32f-b70c-6249-a09b-f4045fcb6375"
/dev/nvme0n1p2: UUID="304ed894-b2cb-454b-ba43-bfffb9ad218f" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="root" PARTUUID="f85ad3da-9765-3f4b-afc7-d1c0de8007e5"
/dev/sdb2: SEC_TYPE="msdos" LABEL_FATBOOT="VTOYEFI" LABEL="VTOYEFI" UUID="7CDB-00D9" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="66cc8833-02"
/dev/sdb1: LABEL="Ventoy" UUID="7CAB-0091" BLOCK_SIZE="512" TYPE="exfat" PARTUUID="66cc8833-01"
/dev/loop2: BLOCK_SIZE="262144" TYPE="squashfs"
/dev/loop0: BLOCK_SIZE="262144" TYPE="squashfs"
/dev/mapper/ventoy: BLOCK_SIZE="2048" UUID="2023-09-19-08-52-05-00" LABEL="MANJARO_XFCE_2302" TYPE="iso9660" PTTYPE="dos"
/dev/sda1: UUID="d52cfe93-a014-49ed-aa4d-8eeabc75ccf2" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="35dd2527-01"
/dev/loop3: BLOCK_SIZE="262144" TYPE="squashfs"
I still do not see what is wrong with the fstabs file.
Thanks for pointing that out I will look into it if I get my system running again.
Have you deleted manually some snap files?
If yes, boot a live ISO, boot with manjaro-chroot into the system and disable all of the snap mount units in /etc/systemd/system/multi-user.target.wants/.
I tried disabling mount points and after restarting all I got was a blinking cursor after re enabling them that was still all I got, I cannot remember if I set it up but would an application like timeshift help in this situation?
If you would have saved a snapshot before the incident - yes.
