Problems updating latte-dock-git
When I try to run sudo pacman -Syu kpeoplevcard
I get the following error:
:: installing plasma-framework5 (5.111.0-1) breaks dependency 'plasma-framework' required by latte-dock-git
:: installing knewstuff5 (5.111.0-1) breaks dependency 'knewstuff' required by latte-dock-git
@ghostwind, latte-dock-git is from AUR, so you might need to remove this first, then update and try to re-install it afterwards. Re-install could be an issue if the package is not synched by the maintainer with current Manjaro repos.
Thanks, I’ll give that a try
I switched to latte-dock and the upgrade went seamlessly. @Wollie: thanks for the help!
