Problems to update: error: GPGME error: No data
Hi, I have problems to update, using pacman:
sudo pacman -Syyu is giving me…
 core                  143,2 KiB   197 KiB/s 00:01 [######################] 100%
 extra                   8,3 MiB  3,72 MiB/s 00:02 [######################] 100%
 multilib              147,9 KiB  1138 KiB/s 00:00 [######################] 100%
error: failed to synchronize all databases (invalid or corrupted database (PGP signature))
I tried the usual approach (below) already, but this didn’t fix it. What else do I need to do? Thanks!
sudo cp -f "/etc/pacman.conf" "/etc/pacman.conf.orig"
sudo sed -i 's/SigLevel.*/SigLevel = Never/' /etc/pacman.conf
sudo pacman -Syy gnupg archlinux-keyring manjaro-keyring --ignore manjaro-system
sudo mv -f "/etc/pacman.conf.orig" "/etc/pacman.conf"
sudo pacman -Syu
The message you provided
Points to the sig files being html instead of binary
file /var/lib/pacman/sync/*.sig
The only thing you didn’t do was changing your primary mirror.
sudo pacman-mirrors --continent
Be sure to remove all sig files before syncing again
sudo rm /var/lib/pacman/sync/*.sig
Worked like a charm. Thanks!
