Hello, I come here in search of some guidance, I was trying to repair grub after having formatted my Windows partition and installed Windows 11, since I lost access to Linux and grub4win does not detect it in principle. I ran the Manjaro chroot command from a live usb drive and it generated the following
==> Mounting (ManjaroLinux) [/dev/nvme0n1p5]
→ mount: [/mnt]
mount: /mnt: /dev/nvme0n1p5 already mounted on /mnt.
dmesg(1) may have more information after failed mount system call.
→ mount: [/mnt/boot/efi]
mount: /mnt/boot/efi: special device /dev/disk/by-uuid/B203-4C2B does not exist.
mount: /mnt/sys: sys already mounted on /sys.
I understand that it recognizes the partition but that it is missing others, how can it be solved?
Most likely windows has (or you have) deleted the EFI partition which was known by Manjaro and which contains boot files for Manjaro and also for Windows. You would need to reinstall grub in that case.
…and for this reason better put the EFI of Manjaro on the Manjaro-system-disk.
And chainload Winndows. BIOS: Manjaro start as default.
If all systems are only on one Disk better ask Megavolt.
Hi, I ran the commands you mention and it returned this
sudo parted -l
//Before write about the other disk and the flash drive, I omit it because it is not relevant
Model: WDC WDS500G2B0C-00PXH0 (nvme)
Disk /dev/nvme0n1: 500GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 106MB 105MB fat32 EFI system partition boot, esp, no_automount
2 106MB 123MB 16,8MB Microsoft reserved partition msftres, no_automount
3 123MB 370GB 370GB ntfs Basic data partition msftdata
4 370GB 371GB 720MB ntfs hidden, diag, no_automount
5 371GB 500GB 129GB ext4 root
As far as I understand, nvme0n1p5 is the partition where Manjaro is installed.
Hi, yes, I have followed that guide, specifically I tried to install it with the manjaro-chroot method and what I published in the first post is the result of the command
~ manjaro-chroot -a ✔
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
[manjaro /]# cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=B203-4C2B /boot/efi vfat umask=0077 0 2
UUID=2c4fe4df-c53c-44a9-8820-722530ed4c11 / ext4 defaults,noatime 0 1
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
They are different from what I understand, aren’t they?
imgur. com/a/WDsEulf
Something like that is what it should be, right? I cannot send images or links, sorry to send that in that form
so 2 possibilities :
1 - correct on /etc/fstab UUID under chroot , ( nano /etc/fstab , Ctrl + X confirm changes )
also check ls /boot/efi/* , you will see manjaro and grub
exit and reboot
2 - if there no grub manjaro , you will have to reinstall grub under chroot in this case /boot/efi have to be mounted by chroot , so UUID have to be correct before chroot for restaure Grub
Great, I made the switch that you suggested with gpart, I was rereading the conversation for a while and I was able to go ahead and solve the problem, thanks!
After making the UUID change to the chroot file, it recognized the partitions, from there I followed the guide and no problem. I only had to do a few extra commands because Manjaro’s grub didn’t recognize Windows at first, but it wasn’t a big problem.
@stephane The solution was to reinstall grub con chroot, Can I then have to see the partitions to verify that there are no problems? I noticed that there was about 400mb of unallocated space.
