keos
1
Hello,
The Leela Chess Zero an Engine in AUR does can’t be downloaded:
curl: (28) Failed to connect to data.lczero.org port 80: Connection timed out
==> ERROR: Failure while downloading ://data.lczero.org/files/networks/00af53b081e80147172e6f281c01daf5ca19ada173321438914c730370aa4267
Aborting …
:: Unable to build lc0 - makepkg exited with code: 1
= >> Try again? [y / N]: n
I have it installed and running on MXLinux. What can be done …?.
Thanks!
mbod
3
What exactly was the command you used?
keos
4
i used yay, of course, and octopi too …
I forgot to said that for some reason i’m not able to post the whole thing here at the forum now because it not allow to show up any link.
Just this:
[keos@keoss ~]$ yay -S lc0
:: Checking for conflicts…
:: Checking for inner conflicts…
[Repo Make:3] ninja-1.10.1-1 meson-0.55.1-1 gtest-1.10.0-1
[Aur:1] lc0-0.26.1-1
I can reproduce the error as data.lczero.org appears to be down. You may want to leave a comment on the AUR page to let the maintainer know.
keos
7
The post was removed (?)
They recommended to install: lc0-blas-git i tried, same result.
