Hello. I’m used to using global scaling (110-120%) and night color scheme at night for eye comfort. On wayland, I have problems with this. When the screen is scaled globally, the font becomes bad, and the night scheme does not work at all. These are the basic problems. There is also a double cursor and a blinking mouse pointer. Also lags the Start menu.
I set up wayland according to the instructions in YouTube. And I’m wondering if this setting is not correct or it’s in the wayland itself.
Plasma-wayland-session and egl-wayland were installed according to the instructions.
Changed /etc/mkinitcpio.conf to
MODULES=“nvidia nvidia_modeset nvidia_uvm nvidia_drm”
(I don’t remember what was originally in this line).
sudo mkinitcpio -p linux510
sudo cat /sys/module/nvidia_drm/parameters/modeset
Y
Added nvidia-drm.modeset=1 to etc/default/grub GRUB_CMDLINE_LINUX_DEFAULT
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor nvidia-drm.modeset=1 resume=UUID=e7943d40-f1aa-4936-95da-cdc8ca3ee9cc udev.log_priority=3"
sudo update grub
The system has been updated. Sorry if something is not clear, I am writing through a translator.
inxi -Fxs
Host: manjaro Kernel: 5.10.93-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 11.1.0 Desktop: KDE Plasma 5.23.5 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: BIOSTAR model: H81MDC v: 5.0
serial: <superuser required> BIOS: American Megatrends v: 4.6.5
date: 06/09/2014
Info: dual core model: Intel Pentium G3220 bits: 64 type: MCP arch: Haswell
rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 1108 high: 1417 min/max: 800/3000 cores: 1: 799 2: 1417
bogomips: 11990
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: NVIDIA GF108 [GeForce GT 730] vendor: Palit Microsystems
driver: nvidia v: 390.147 bus-ID: 01:00.0
Display: wayland server: X.Org 1.21.1.4 compositor: kwin_wayland driver:
loaded: nvidia resolution: 1600x900~60Hz
Device-1: Intel 8 Series/C220 Series High Definition Audio
vendor: Biostar Microtech Intl Corp driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0
Device-2: NVIDIA GF108 High Definition Audio vendor: Palit Microsystems
driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Sound Server-1: ALSA v: k5.10.93-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.43 running: yes
vendor: Biostar Microtech Intl Corp driver: r8169 v: kernel port: d000
bus-ID: 03:00.0
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: b8:97:5a:73:4e:b1
Local Storage: total: 465.76 GiB used: 57.51 GiB (12.3%)
ID-1: /dev/sda vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-1: / size: 161.02 GiB used: 57.46 GiB (35.7%) fs: btrfs dev: /dev/sda6
ID-2: /home size: 161.02 GiB used: 57.46 GiB (35.7%) fs: btrfs
dev: /dev/sda6
ID-3: /var/log size: 161.02 GiB used: 57.46 GiB (35.7%) fs: btrfs
dev: /dev/sda6
ID-1: swap-1 type: partition size: 3.91 GiB used: 51.8 MiB (1.3%)
dev: /dev/sda5
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 180 Uptime: 3h 19m Memory: 3.79 GiB used: 942.5 MiB (24.3%)
Init: systemd Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1485
Shell: Zsh v: 5.8 inxi: 3.3.12
