Hello everybody,
I have successfully followed a tutorial and I have been able to install Manjaro Ornara 21.0.4 on Hyper-V with enhanced session.
However, there is one thing that is not working properly: I have edited my .xinitrc file according the instructions provided in the tutorial, but the xfce session was not starting after the xrdp login, and after some seconds I was back to xrdp login window.
So I commented out the line with exec command in .xinitrc and manually added the following line:
exec dbus-launch --sh-syntax xfce4-session
In this way xfce starts, but I have problems with authorizations: I cannot update or add any software using Add/Remove Software gui because I get an âauthenticationâ failed message.
This seems related to an issue discussed here:
No user session created with xrdp and pam_systemd_home account module
I then applied one of the workaround there described, that is to comment out all lines with reference to pam_systemd_home.so
in /etc/pam.d/system-auth
In this way everything seems to work. I just wanted to know if others are facing the same problem, even if I know this is not a very common situation.
