I have a 64 gb swap. It is empty according to the free -h
command.
Here is the command output you asked:
osbm@ymir ~> inxi --admin --verbosity=8 --filter --no-host --width
Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=a5b7f842-debc-473b-aea6-38c52885cd37 rw quiet splash
resume=UUID=99660756-290f-4d2e-b33b-d939145e03f3 udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop Mobo: Micro-Star model: PRO B760-P WIFI DDR4 (MS-7D98) v: 1.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 1.60 date: 07/13/2023
System RAM: total: 64 GiB available: 62.64 GiB used: 2.98 GiB (4.8%)
Device-1: Controller0-DIMMA1 type: no module installed
Device-2: Controller0-DIMMA2 type: DDR4 detail: synchronous size: 32 GiB
speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: N/A part-no: DDR4 PC 32G 3200
serial: <filter>
Device-3: Controller1-DIMMB1 type: no module installed
Device-4: Controller1-DIMMB2 type: DDR4 detail: synchronous size: 32 GiB
serial: <filter>
Info: model: Intel Core i7-14700KF bits: 64 type: MST AMCP arch: Raptor Lake
gen: core 14 level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xB7 (183) stepping: 1 microcode: 0x123
Topology: cpus: 1x cores: 20 mt: 8 tpc: 2 st: 12 threads: 28 smt: enabled
cache: L1: 1.8 MiB desc: d-12x32 KiB, 8x48 KiB; i-8x32 KiB, 12x64 KiB
L2: 28 MiB desc: 8x2 MiB, 3x4 MiB L3: 33 MiB desc: 1x33 MiB
Speed (MHz): avg: 800 min/max: 800/5500:5600:4300 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 25: 800 26: 800 27: 800 28: 800 bogomips: 191436
de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
sdbg sep serialize sha_ni smap smep split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Palit Microsystems
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2684 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 118 s-size: 413x231mm (16.26x9.09")
s-diag: 473mm (18.63")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Dell E1916HV
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 305 gamma: 1.2
chroma: red: x: 0.643 y: 0.333 green: x: 0.318 y: 0.627 blue: x: 0.149
y: 0.047 white: x: 0.314 y: 0.329 size: 160x90mm (6.3x3.54")
diag: 470mm (18.5") ratio: 16:9 modes: 1920x1080, 1280x1024, 1280x720,
1024x768, 800x600, 720x480, 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 550.78 device-ID: 10de:2684
surfaces: xcb,xlib
Device-1: Intel Raptor Lake High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
Device-2: NVIDIA AD102 High Definition Audio vendor: Palit Microsystems
bus-ID: 01:00.1 chip-ID: 10de:22ba class-ID: 0403
API: ALSA v: k6.6.32-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0033
class-ID: e001
Local Storage: total: 3.68 TiB used: 617.72 GiB (16.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: SSD 2TB size: 1.86 TiB block-size:
physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD
serial: <filter> fw-rev: H230509a temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: ST2000LM003 HN-M201RAD
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 1.8 TiB size: 1.77 TiB (98.37%) used: 617.72 GiB (34.2%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: a5b7f842-debc-473b-aea6-38c52885cd37
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 0C65-0ADD
ID-1: swap-1 type: partition size: 68.9 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 99660756-290f-4d2e-b33b-d939145e03f3
ID-1: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ntfs label: athena
uuid: 388C386205267EF3
Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-3: 1-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-9:4 info: HP HP Wired Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 98mA chip-ID: 03f0:6941 class-ID: 0300
Device-2: 1-10:5 info: [Maxxter] Optical gaming mouse type: mouse,keyboard
lanes: 1 mode: 1.0 power: 100mA chip-ID: 18f8:0f99 class-ID: 0300
Device-3: 1-11:6 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7d98 class-ID: 0300
serial: <filter>
Device-4: 1-14:7 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-4: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
System Temperatures: cpu: 37.0 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Packages: pm: pacman pkgs: 1389 libs: 367 tools: pamac
1: https://mirrors.netix.net/manjaro/stable/$repo/$arch
2: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
3: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
4: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
6: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
7: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
8: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 475
1: cpu: 11.0% command: firefox pid: 1719 mem: 510.4 MiB (0.7%)
2: cpu: 3.9% command: firefox pid: 2786 mem: 332.7 MiB (0.5%)
3: cpu: 2.1% command: firefox pid: 2857 mem: 207.9 MiB (0.3%)
4: cpu: 1.0% command: Xorg pid: 1153 mem: 87.2 MiB (0.1%)
5: cpu: 1.0% command: kwin_x11 pid: 1308 mem: 151.1 MiB (0.2%)
Memory top: 5 of 475
1: mem: 510.4 MiB (0.7%) command: firefox pid: 1719 cpu: 11.0%
2: mem: 332.7 MiB (0.5%) command: firefox pid: 2786 cpu: 3.9%
3: mem: 314.2 MiB (0.4%) command: plasmashell pid: 1344 cpu: 0.8%
4: mem: 207.9 MiB (0.3%) command: firefox pid: 2857 cpu: 2.1%
5: mem: 180.5 MiB (0.2%) command: firefox pid: 2621 cpu: 0.7%
Processes: 475 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.04 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 17.0.6 gcc: 14.1.1 alt: 12 Shell: fish v: 3.7.1
running-in: tmux: inxi: 3.3.34
This command is awesome. It shows everything. I will be saving it.
What do you think is the issue?
