Problems of ssh connection
To connect via ssh to a remote server, I have to add this line before the address. ssh -oHostKeyAlgorithms=+ssh-dss Is it possible to make this line with this address so that it is entered automatically ?
Yes, create a config for this specific server.
OpenSSH - ArchWiki
ssh_config(5) — Arch manual pages
I can put in ssh_config for exemple: "Host freehost HostName IP ADDRESS Port 22 User root IdentityFile /root/.ssh/id_rsa or Host DB1 HostName db1.server.uk Port 2222 User adminDB " Where should I put the line “ssh -oHostKeyAlgorithms=+ssh-dss” ?
Not in ssh_config. This is for every user and every connection. Unless you want add an insecure algorithm to the list for every connection, don’t do this.
Create a config for the user you use to connect to this server. Do you use root on your local machine for this? Then it would be /root/.ssh/config .
This is an example for a connection.
Host DB1
    Hostname  db1.server.uk
    Port  2222
    User  adminDB
    HostKeyAlgorithms  +ssh-dss
then use only ssh DB1
Also see the example in the release notes.
Thanks . Now It work
