Problems installing ungoogled-chromium
install is failing to download ungoogled-chromium , Gets a 403 from storage.googleapis.com
yay -S ungoogled-chromium
curl: (22) The requested URL returned error: 403
==> ERROR: Failure while downloading https://commondatastorage.googleapis.com/chromium-browser-official/chromium-114.0.5735.133.tar.xz
    Aborting...
 -> error downloading sources: ~/.cache/yay/ungoogled-chromium
	 context: exit status 1
Hi @Usr2023,
As you mentioned,
…and according to this:
403 Forbidden
Request does not specify the file name, or the directory or the file does not have the permission that allows the pages to be viewed from the web
…and I just tested the link, and it works. So it would seem your IP/Connection is disallowed for whatever reason. This isn’t a Manjaro problem, the reason is your ISP I think.
Edit:
Try the following, just for in case:
pamac build ungoogled-chromium-bin
Thanks
