Hi ![]()
I am having trouble connecting to Wi-Fi as usual (in my case that is clicking on Networks in the status bar and so on).
I am having the same problem with every Wi-Fi connection (work, phone).
However, connecting via nmtui-connect DOES WORK ![]()
I tried to search for solutions by myself but so far could not resolve the issue.
This is my inxi output:
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "en_US:de",
LC_ALL = (unset),
LC_ADDRESS = "de_DE.UTF-8",
LC_NAME = "de_DE.UTF-8",
LC_MONETARY = "de_DE.UTF-8",
LC_PAPER = "de_DE.UTF-8",
LC_IDENTIFICATION = "de_DE.UTF-8",
LC_TELEPHONE = "de_DE.UTF-8",
LC_MEASUREMENT = "de_DE.UTF-8",
LC_TIME = "de_DE.UTF-8",
LC_NUMERIC = "de_DE.UTF-8",
LANG = "en_DE.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
Kernel: 5.10.117-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=01a2051d-307b-47a0-949c-d91184d04a00 rw quiet apparmor=1
security=apparmor resume=UUID=6ddeca3b-b0ad-4b3d-813e-20cae7be215d
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20FAS1NF00 v: ThinkPad T460s
Mobo: LENOVO model: 20FAS1NF00 v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N1CET79W (1.47 )
date: 11/25/2019
ID-1: BAT0 charge: 8.6 Wh (43.2%) condition: 19.9/23.5 Wh (84.5%)
volts: 11.1 min: 11.4 model: SMP 00HW023 type: Li-poly serial: <filter>
status: discharging
ID-2: BAT1 charge: 18.4 Wh (100.0%) condition: 18.4/26.3 Wh (69.9%)
volts: 12.7 min: 11.4 model: SANYO 01AV405 type: Li-ion serial: <filter>
status: full
RAM: total: 15.49 GiB used: 1.97 GiB (12.7%)
RAM Report:
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 500 min/max: 400/3000 scaling: driver: intel_pstate
governor: powersave cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 20004
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
hle ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good rtm
sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Acer ThinkPad P50 Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:5 chip-ID: 5986:0706 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14b1 built: 2015 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 308x173mm (12.13x6.81") diag: 353mm (13.9")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 22.0.4
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.10.117-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: wwp0s20f0u2c3 state: down mac: <filter>
bus-ID: 1-7:4 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 238.47 GiB used: 113.44 GiB (47.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 MTFDDAV256TBN
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: U001 scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%)
used: 113.44 GiB (50.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 01a2051d-307b-47a0-949c-d91184d04a00
used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 5986-57EC
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 6ddeca3b-b0ad-4b3d-813e-20cae7be215d
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-2:2 info: Huawei ME906s LTE M.2 Module
type: Communication,CDC-Data driver: cdc_mbim,option,option1 interfaces: 3
rev: 2.1 speed: 480 Mb/s power: 2mA chip-ID: 12d1:15c1 class-ID: 0a00
serial: <filter>
Device-2: 1-5:3 info: Alcor Micro AU9540 Smartcard Reader type: Smart Card
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 50mA
chip-ID: 058f:9540 class-ID: 0b00
Device-3: 1-7:4 info: Intel Bluetooth wireless interface type: Bluetooth
Device-4: 1-8:5 info: Acer ThinkPad P50 Integrated Camera type: Video
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 37.0 C pch: 37.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 207 Uptime: 46m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1888 pacman: 1873 lib: 456
flatpak: 0 snap: 15 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
This is my ip addr output:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp0s31f6: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 50:7b:9d:dd:68:e8 brd ff:ff:ff:ff:ff:ff
3: wlp4s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether e4:b3:18:d7:9d:c1 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.18/24 brd 192.168.1.255 scope global dynamic noprefixroute wlp4s0
valid_lft 603085sec preferred_lft 603085sec
inet6 fe80::858:7bc1:44e5:276/64 scope link noprefixroute
5: wwp0s20f0u2c3: <BROADCAST,MULTICAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 9a:e8:8d:3d:59:b4 brd ff:ff:ff:ff:ff:ff
This is the content of /etc/resolv.conf
# Generated by NetworkManager
search localdomain
nameserver 192.168.1.1
The /etc/NetworkManager/NetworkManager.conf is empty, I guess since I tried to fix by restarting the NetworkManager.service.
This is my iw dev output:
phy#0
Unnamed/non-netdev interface
wdev 0x3
addr e4:b3:18:d7:9d:c1
type P2P-device
txpower 0.00 dBm
Interface wlp4s0
ifindex 3
wdev 0x1
ssid o2-WLAN03
type managed
channel 44 (5220 MHz), width: 80 MHz, center1: 5210 MHz
txpower 22.00 dBm
multicast TXQ:
qsz-byt qsz-pkt flows drops marks overlmt hashcol tx-bytes tx-packets
0 0 0 0 0 0 0 0 0
Thanks for considering to help, I hope I did not make any mistake in asking this question, if I did: sorry ![]()
