Thank you. Here’s my output for inxi -zv8:
Kernel: 6.17.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.17-x86_64
root=UUID=30df83e3-f608-4071-98b0-7cea88d40a9d rw quiet
cryptdevice=UUID=3bafe492-8b5a-4e57-8eb0-41bc6d7137c1:luks-3bafe492-8b5a-4e57-8eb0-41bc6d7137c1
root=/dev/mapper/luks-3bafe492-8b5a-4e57-8eb0-41bc6d7137c1 apparmor=1
security=apparmor
resume=/dev/mapper/luks-3858f910-eea1-4d79-b2c7-13e364708e79
udev.log_priority=3
Desktop: i3 v: 4.24 with: i3bar tools: avail: i3lock,xautolock vt: 7
dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: Micro-Star model: PRO B650M-A WIFI (MS-7D77) v: 1.0
serial: uuid: Firmware: UEFI
vendor: American Megatrends LLC. v: 1.F1 date: 01/04/2024
System RAM: total: 128 GiB available: 124.99 GiB used: 2.78 GiB (2.2%)
Device-1: DIMMA1 type: DDR5 detail: synchronous unbuffered (unregistered)
size: 32 GiB speed: spec: 4800 MT/s actual: 3600 MT/s volts: note: check
curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Kingston part-no: KF560C36-32 serial:
Device-2: DIMMA2 type: DDR5 detail: synchronous unbuffered (unregistered)
Device-3: DIMMB1 type: DDR5 detail: synchronous unbuffered (unregistered)
Device-4: DIMMB2 type: DDR5 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120A
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 2983 min/max: 426/5053 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2983 2: 2983 3: 2983
4: 2983 5: 2983 6: 2983 7: 2983 8: 2983 9: 2983 10: 2983 11: 2983 12: 2983
13: 2983 14: 2983 15: 2983 16: 2983 bogomips: 134398
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid
cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht
hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2
pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed
rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves xtopology
Type: spectre_v1 mitigation: usercopy/swapgs barriers and \__user pointer
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA AD107 \[GeForce RTX 4060\] vendor: Micro-Star MSI
driver: nvidia v: 580.119.02 alternate: nouveau,nova_core,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-11) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s ports:
active: none off: DP-6 empty: DP-4,DP-5,HDMI-A-2 bus-ID: 01:00.0
chip-ID: 10de:2882 class-ID: 0300
Device-2: Advanced Micro Devices \[AMD/ATI\] Raphael vendor: Micro-Star MSI
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-1, DP-2, DP-3, HDMI-A-1, Writeback-1 bus-ID: 10:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 42.0 C
Device-3: Microdia JOYACCESS JA-Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2
chip-ID: 0c45:6362 class-ID: 0102 serial:
Display: x11 server: X.org v: 1.21.1.21 compositor: Picom v: 12.5 driver:
X: loaded: amdgpu,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa dri: radeonsi gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: DP-6 mapped: DP-4 note: disabled model: MSI G32C4X built: 2022
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 70 gamma: 1.2 chroma: red:
x: 0.675 y: 0.314 green: x: 0.282 y: 0.655 blue: x: 0.149 y: 0.071 white:
x: 0.314 y: 0.329 size: 698x393mm (27.48x15.47") diag: 801mm (31.5")
ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960,
1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
EDID-Warnings: 1: parse_edid: unhandled CEA mode 76
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.119.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060/PCIe/SSE2
memory: 7.81 GiB
Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
x11: xprop,xrandr
Device-1: NVIDIA AD107 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: nova_core pcie: gen: 4
speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
Device-2: Advanced Micro Devices \[AMD/ATI\] Radeon High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: Advanced Micro Devices \[AMD\] Ryzen HD Audio
speed: 16 GT/s lanes: 16 bus-ID: 10:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Microdia JOYACCESS JA-Webcam driver: snd-usb-audio,uvcvideo
Device-5: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1.4:5
chip-ID: 0d8c:0005 class-ID: 0300 serial:
API: ALSA v: k6.17.12-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0c:00.0
IF: enp12s0 state: down mac:
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 0d:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp13s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
WAN IP:
Device-1: luks-3bafe492-8b5a-4e57-8eb0-41bc6d7137c1 maj-min: 253:0
type: LUKS dm: dm-0 size: 1.81 TiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 1.81 TiB
Device-2: luks-3858f910-eea1-4d79-b2c7-13e364708e79 maj-min: 253:1
type: LUKS dm: dm-1 size: 8.8 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 8.8 GiB
Local Storage: total: 1.82 TiB used: 584.93 GiB (31.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SFYRD2000G
lanes: 4 tech: SSD serial: fw-rev: EIFK31.6 temp: 34.9 C
scheme: GPT
ID-1: / raw-size: 1.81 TiB size: 1.78 TiB (98.37%) used: 584.93 GiB (32.1%)
fs: ext4 dev: /dev/dm-0 maj-min: 253:0
mapped: luks-3bafe492-8b5a-4e57-8eb0-41bc6d7137c1 label: N/A
uuid: 30df83e3-f608-4071-98b0-7cea88d40a9d
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: D761-C6C4
dev: /dev/dm-1 maj-min: 253:1
mapped: luks-3858f910-eea1-4d79-b2c7-13e364708e79 label: swap
uuid: ee7dd785-4294-4578-9576-0a6bee069a33
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-8:2 info: ASETEK \[NZXT Kraken X60\] type:
driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 50mA chip-ID: 2433:b200 class-ID: 0000 serial:
Device-2: 1-11:3 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7d77 class-ID: 0300
serial:
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
Device-1: 3-2:2 info: Microdia JOYACCESS JA-Webcam type: video,audio
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 5-1:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Device-1: 5-1.1:3 info: Apple Aluminium Keyboard (ANSI)
type: keyboard,mouse driver: apple,usbhid interfaces: 2 rev: 2.0
chip-ID: 05ac:024f class-ID: 0301
Device-2: 5-1.2:4 info: Areson Corp 2.4G Wireless Receiver
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 25a7:fa11 class-ID: 0301
Device-3: 5-1.4:5 info: C-Media Blue Snowball type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Hub-7: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-8: 6-1:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
System Temperatures: cpu: 44.2 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: nvidia screen: :0.0 temp: 47 C fan: 0% device: amdgpu
temp: 42.0 C
Packages: pm: pacman pkgs: 1728 libs: 442 tools: pamac,yay
1: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
2: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 370
1: cpu: 4.7% command: firefox pid: 2067 mem: 532.8 MiB (0.4%)
2: cpu: 2.1% command: firefox pid: 2488 mem: 298.1 MiB (0.2%)
3: cpu: 1.9% command: Xorg pid: 1018 mem: 124.1 MiB (0.0%)
4: cpu: 0.7% command: picom pid: 1995 mem: 62.2 MiB (0.0%)
5: cpu: 0.5% command: firefox pid: 2479 mem: 214.0 MiB (0.1%)
Memory top: 5 of 370
1: mem: 532.8 MiB (0.4%) command: firefox pid: 2067 cpu: 4.7%
2: mem: 298.1 MiB (0.2%) command: firefox pid: 2488 cpu: 2.1%
3: mem: 214.0 MiB (0.1%) command: firefox pid: 2479 cpu: 0.5%
4: mem: 161.2 MiB (0.1%) command: firefox pid: 2330 cpu: 0.2%
5: mem: 159.6 MiB (0.1%) command: firefox pid: 2399 cpu: 0.3%
Processes: 370 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 49.93 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 258
Compilers: clang: 21.1.6 gcc: 15.2.1 alt: 13/14 Shell: Zsh v: 5.9
running-in: urxvtd inxi: 3.3.40
mod edit: formatting
p.s. where are the leading spaces? this still looks like a wall of text
