Could not boot after update so hacked around with grub commands and was subsequently able to boot but monitors are not acting right. Tried disconnecting #2 of two monitor but did not help. Number 2 goes black when the cursor is there. Grabbing and moving anything in the #1 monitor causes flickering and erratic behavior.
Kernel: 6.18.63-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
clocksource: tsc
Desktop: KDE Plasma v: 6.8.2 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
Mobo: ASUSTeK model: PRIME Z690-A v: Rev 1.xx serial: <filter>
part-nu: SKU uuid: 33749e89-c292-8d37-8465-50ebf6cec84a Firmware: UEFI
vendor: American Megatrends v: 4101 date: 12/03/2024
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
status: discharging
System RAM: total: 128 GiB available: 125.53 GiB used: 5.03 GiB (4.0%)
igpu: 64 MiB
Array-1: capacity: 256 GiB slots: 4 modules: 4 EC: None
max-module-size: 64 GiB note: est.
Device-1: Controller0-DIMM0 type: DDR5 detail: synchronous size: 32 GiB
speed: 4000 MT/s volts: 1.1 width (bits): data: 64 total: 64
manufacturer: Crucial Technology part-no: CT32G48C40U5.M16A1
serial: <filter>
Device-2: Controller0-DIMM1 type: DDR5 detail: synchronous size: 32 GiB
serial: <filter>
Device-3: Controller1-DIMM0 type: DDR5 detail: synchronous size: 32 GiB
serial: <filter>
Device-4: Controller1-DIMM1 type: DDR5 detail: synchronous size: 32 GiB
serial: <filter>
Info: 12-core (8-mt/4-st) model: 12th Gen Intel Core i7-12700 bits: 64
type: MST AMCP smt: enabled arch: Alder Lake rev: 2 cache: L1: 1024 KiB
L2: 12 MiB L3: 25 MiB
Speed (MHz): avg: 800 min/max: 800/4800:4900:3600 volts: 1.2 V
ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
17: 800 18: 800 19: 800 20: 800 bogomips: 84500
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel Alder Lake-S GT1 [UHD Graphics 770] vendor: ASUSTeK
driver: i915 v: kernel arch: Xe ports: active: HDMI-A-1 empty: DP-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0300
Device-2: NVIDIA GF119 [GeForce GT 520] vendor: EVGA driver: nouveau
v: kernel arch: Fermi pcie: speed: 2.5 GT/s lanes: 16 ports: active: DVI-I-1
empty: DVI-I-2,HDMI-A-3 bus-ID: 01:00.0 chip-ID: 10de:1040 class-ID: 0300
temp: 43.0 C
Display: unspecified server: X.Org v: 24.1.15 with: Xwayland v: 24.1.15
alternate: fbdev,vesa dri: iris,nouveau gpu: i915,nouveau display-ID: :1
screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.00x12.48")
s-diag: 1064mm (41.9") monitors: <missing: xrandr>
Monitor-1: DVI-I-1 model: Samsung SyncMaster serial: <filter>
res: 1920x1200 dpi: 94 size: 518x324mm (20.39x12.76") diag: 611mm (24.1")
modes: max: 1920x1200 min: 720x400
Monitor-2: HDMI-A-1 model: Acer G276HL serial: <filter> res: 1920x1080
dpi: 82 size: 598x336mm (23.54x13.23") diag: 686mm (27") modes:
max: 1920x1080 min: 720x400
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
device: 0 drv: nouveau device: 1 drv: iris device: 2 drv: swrast gbm:
drv: nouveau surfaceless: drv: nouveau x11: drv: nouveau inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.3 vendor: mesa v: 26.2.7-arch1.1 glx-v: 1.4
direct-render: yes renderer: NVD9 device-ID: 10de:1040
API: Vulkan v: 1.4.363 layers: 2 surfaces: N/A device: 0
type: integrated-gpu driver: mesa intel device-ID: 8086:4680
Device-1: Intel 600 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:7ad0
class-ID: 0403
Device-2: NVIDIA GF119 HDMI Audio vendor: EVGA driver: snd_hda_intel
v: kernel pcie: speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e08
class-ID: 0403
API: ALSA v: k6.18.63-3-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: sndiod v: N/A status: off
Server-2: JACK v: 1.9.22 status: off
Server-3: PipeWire v: 1.6.11 status: n/a (root, process) with:
3: pipewire-alsa type: plugin
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: TP-Link Bluetooth USB Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 bus-ID: 1-7:7 chip-ID: 2357:0604
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 5.91 TiB used: 2.12 TiB (35.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 PRO 2TB size: 1.82 TiB
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7
temp: 31.9 C scheme: GPT
ID-2: /dev/sda vendor: SanDisk model: SSD PLUS 2000GB size: 1.82 TiB
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 04RL scheme: MBR
ID-3: /dev/sdb vendor: Samsung model: SSD 870 EVO 500GB size: 465.76 GiB
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-4: /dev/sdc vendor: Western Digital model: WD20SDRW-11VUUS0
size: 1.82 TiB type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 tech: HDD rpm: 5400
serial: <filter> fw-rev: 1034 scheme: GPT
ID-1: / size: 48.95 GiB used: 37.71 GiB (77.0%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 511 MiB used: 344 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 1.73 TiB used: 86.53 GiB (4.9%) fs: ext4
dev: /dev/nvme0n1p4
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2
System Temperatures: cpu: 29.8 C mobo: N/A gpu: nouveau temp: 43.0 C
Fan Speeds (rpm): N/A
Processes: 397 Power: uptime: 22m states: freeze,mem,disk suspend: deep
wakeups: 0 hibernate: platform Init: systemd v: 262 default: graphical
Packages: pm: pacman pkgs: 1894 Compilers: clang: 23.1.5 gcc: 16.2.1
Shell: Sudo (sudo) v: 1.9.17p2 default: Bash v: 5.3.20 running-in: konsole
inxi: 3.3.41
Tried both open source and Nvidia drivers (Huong’s fault?) but no relief.
Any help greatly appreciated.
