Here (inxi -Fza
Kernel: 5.15.142-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=51a3a5b3-a6d6-456e-bbe3-935c914bd2fe rw rootflags=subvol=@
Desktop: GNOME v: 45.2 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM
v: 45.0.1 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: N/A model: HX90 serial: <superuser required>
UEFI: American Megatrends LLC. v: 5.19 date: 10/11/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
Info: model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1336 high: 2459 min/max: 1200/4679 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1396 2: 1397
3: 1197 4: 1197 5: 1196 6: 1197 7: 1198 8: 1370 9: 1196 10: 1197 11: 2459
12: 1195 13: 1395 14: 1396 15: 1197 16: 1196 bogomips: 105440
Type: spec_rstack_overflow mitigation: safe RET, no microcode
prctl and seccomp
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2
bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 34.0 C
Device-2: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2.3:5
chip-ID: 041e:40a0 class-ID: 0102 serial: <filter>
Display: wayland server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 model: BenQ LCD serial: <filter> built: 2022
res: 2560x1440 dpi: 123 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-2 model: LG (GoldStar) IPS224 built: 2011 res: 1920x1080
dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55") diag: 547mm (21.5")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
16.0.6 DRM 3.42 5.15.142-1-MANJARO) device-ID: 1002:1638 memory: 500 MiB
unified: no display-ID: :0.0
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Realtek
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Device-4: C-Media Audio Adapter (Unitek Y-247A)
driver: cmedia_hs100b,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0d8c:0014 class-ID: 0300
Device-5: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
API: ALSA v: k5.15.142-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0 chip-ID: 8086:15f3
class-ID: 0200
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:0608
class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 0e8d:0608
Local Storage: total: 3.64 TiB used: 1.34 TiB (36.9%)
model: WD Green SN350 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 33006000 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LX001-1RG174
tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM1 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 822.85 GiB (44.2%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 822.85 GiB (44.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
System Temperatures: cpu: 40.4 C mobo: N/A gpu: amdgpu temp: 34.0 C
Fan Speeds (rpm): N/A
Processes: 451 Uptime: 2h 10m wakeups: 0 Memory: total: 32 GiB note: est.
available: 30.78 GiB used: 4.99 GiB (16.2%) Init: systemd v: 254
Packages: 2350 pm: pacman pkgs: 2296 libs: 504
tools: gnome-software,pamac,yay pm: flatpak pkgs: 42 pm: snap pkgs: 12
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.31
the same, after rebooting in 6.6: (still not locked…)
Kernel: 6.6.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
Speed (MHz): avg: 2017 high: 4542 min/max: 400/4680 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 3645 3: 3650
4: 400 5: 3959 6: 400 7: 3795 8: 400 9: 400 10: 400 11: 400 12: 400
13: 4541 14: 400 15: 4542 16: 4541 bogomips: 105444
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 45.0 C
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
16.0.6 DRM 3.54 6.6.5-1-MANJARO) device-ID: 1002:1638 memory: 500 MiB
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3 speed: 8 GT/s
class-ID: 0403
API: ALSA v: k6.6.5-1-MANJARO status: kernel-api with: aoss
class-ID: 0200
class-ID: 0280
fw-rev: 33006000 temp: 48.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 822.83 GiB (44.2%)
used: 822.83 GiB (44.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 67.8 C mobo: 36.0 C gpu: amdgpu temp: 42.0 C
Processes: 442 Uptime: 2m wakeups: 0 Memory: total: 32 GiB note: est.
available: 30.78 GiB used: 3.11 GiB (10.1%) Init: systemd v: 254
