Netzwerkaufbau (Topo)
inxi -zv8 ✔ 3s
Kernel: 6.12.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=41cef9aa-b2d9-4c7b-a788-66e5b7028a33 rw
btusb.enable_autosuspend=n usbcore.autosuspend=-1 quiet
cryptdevice=UUID=dc9078ae-7aa1-437b-bcdf-c2783cd4a76c:luks-dc9078ae-7aa1-437b-bcdf-c2783cd4a76c
root=/dev/mapper/luks-dc9078ae-7aa1-437b-bcdf-c2783cd4a76c splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.13.0
Mobo: ASUSTeK model: ROG MAXIMUS Z790 HERO v: Rev 1.xx
UEFI: American Megatrends v: 2801 date: 11/29/2024
System RAM: total: 64 GiB available: 62.48 GiB used: 8.53 GiB (13.6%)
Array-1: capacity: 256 GiB slots: 4 modules: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: Controller0-DIMM0 type: no module installed
Device-2: Controller0-DIMM1 type: DDR5 detail: synchronous size: 32 GiB
speed: 6000 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: G Skill Intl part-no: F5-6000J3040G32G
serial: N/A
Device-3: Controller1-DIMM0 type: no module installed
Device-4: Controller1-DIMM1 type: DDR5 detail: synchronous size: 32 GiB
serial: N/A
Info: model: Intel Core i9-14900K bits: 64 type: MST AMCP arch: Raptor Lake
gen: core 14 level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xB7 (183) stepping: 1 microcode: 0x12C
Topology: cpus: 1x dies: 1 clusters: 12 cores: 24 threads: 32 mt: 8 tpc: 2
st: 16 smt: enabled cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32
KiB, 16x64 KiB L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 991 min/max: 800/6000:5700:4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 991 2: 991 3: 991 4: 991
5: 991 6: 991 7: 991 8: 991 9: 991 10: 991 11: 991 12: 991 13: 991 14: 991
15: 991 16: 991 17: 991 18: 991 19: 991 20: 991 21: 991 22: 991 23: 991
24: 991 25: 991 26: 991 27: 991 28: 991 29: 991 30: 991 31: 991 32: 991
bogomips: 204032
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pconfig
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand
rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: NVIDIA AD104 [GeForce RTX 4070 Ti] vendor: ASUSTeK driver: nvidia
v: 570.144 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-1,DP-3 empty: DP-2,HDMI-A-1,HDMI-A-2
bus-ID: 01:00.0 chip-ID: 10de:2782 class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 108 s-size: 1204x342mm (47.40x13.46")
s-diag: 1252mm (49.28")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: left
model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2023 res:
mode: 2560x1440 hz: 165 scale: 100% (1) dpi: 108 gamma: 1.2 chroma: red:
x: 0.686 y: 0.310 green: x: 0.263 y: 0.671 blue: x: 0.149 y: 0.055 white:
x: 0.314 y: 0.329 size: 600x340mm (23.62x13.39") diag: 690mm (27.2")
ratio: 16:9 modes: 2560x1440, 1920x1080, 1280x720, 1024x768, 800x600,
720x480, 640x480
EDID-Warnings: 1: parse_edid: unknown tag 112
Monitor-2: DP-3 mapped: DP-4 note: disabled pos: primary,right
720x480, 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.144
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070 Ti/PCIe/SSE2
memory: 11.71 GiB
API: Vulkan v: 1.4.309 layers: 10 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4070 Ti driver: nvidia v: 570.144 device-ID: 10de:2782
surfaces: xcb,xlib
Device-1: Intel Raptor Lake High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
Device-2: NVIDIA AD104 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:22bc class-ID: 0403
Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
chip-ID: 0b05:1a53 class-ID: 0300
Device-4: Corsair HS80 MAX WIRELESS Gaming Receiver
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-8.4:9 chip-ID: 1b1c:0a97 class-ID: 0300
serial: <filter>
API: ALSA v: k6.12.28-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: off with: pipewire-media-session
status: active tools: pw-cat,pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin tools: pacat,pactl
Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0
chip-ID: 8086:125c class-ID: 0200
IF: eno2 state: up speed: 2500 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:12 chip-ID: 8087:0033
class-ID: e001
Device-1: luks-dc9078ae-7aa1-437b-bcdf-c2783cd4a76c maj-min: 254:0
type: LUKS dm: dm-0 size: 1.82 TiB
Components:
p-1: nvme0n1p2 maj-min: 259:3 size: 1.82 TiB
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 4.66 TiB used: 1.13 TiB (24.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 31.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 2TB
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: USB 3.2Gen1
size: 114.6 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Extreme 55AE
size: 931.48 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 3008 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 268.33 GiB (14.6%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-dc9078ae-7aa1-437b-bcdf-c2783cd4a76c label: N/A
uuid: 41cef9aa-b2d9-4c7b-a788-66e5b7028a33
ID-2: /NetMounts/NAS01/BackUp_01 raw-size: N/A size: 21.65 TiB
used: 6.64 TiB (30.7%) fs: cifs dev: /dev/BackUp_01
ID-3: /NetMounts/NAS01/Medien_01 raw-size: N/A size: 21.65 TiB
used: 6.64 TiB (30.7%) fs: cifs dev: /dev/Medien_01
ID-4: /NetMounts/NAS01/Privat raw-size: N/A size: 21.65 TiB
used: 6.64 TiB (30.7%) fs: cifs dev: /dev/Privat
ID-5: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 452 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2 label: N/A
uuid: 6DA4-ABFA
ID-6: /run/media/miho/BKP SSD raw-size: 931.48 GiB
size: 931.46 GiB (100.00%) used: 891.88 GiB (95.8%) fs: exfat dev: /dev/sdb1
maj-min: 8:17 label: BKP SSD uuid: 6657-96BE
ID-1: /dev/nvme1n1p1 maj-min: 259:4 size: 100 MiB fs: vfat label: N/A
uuid: D69C-85D6
ID-2: /dev/nvme1n1p2 maj-min: 259:5 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme1n1p3 maj-min: 259:6 size: 499.37 GiB fs: ntfs label: Win10
uuid: D68AB2138AB1F05B
ID-4: /dev/nvme1n1p4 maj-min: 259:7 size: 525 MiB fs: ntfs label: N/A
uuid: 5012A34F12A338BC
ID-5: /dev/nvme1n1p5 maj-min: 259:8 size: 1.15 TiB fs: ntfs label: Data
uuid: E44C19954C196418
ID-6: /dev/sda1 maj-min: 8:1 size: 114.57 GiB fs: exfat label: Ventoy
uuid: F451-6EAB
ID-7: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 626B-4255
Hub-2: 1-5:2 info: Alcor Micro USB Hub ports: 4 rev: 2.0
chip-ID: 058f:6254 class-ID: 0900
Device-1: 1-6:3 info: ASUSTek USB Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
Hub-3: 1-7:4 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Device-1: 1-7.1:6 info: INSTANT USB GAMING MOUSE type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 30fa:1140 class-ID: 0300
Device-2: 1-7.3:8 info: CHERRY Corded Device type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 046a:c098 class-ID: 0300
Hub-4: 1-8:5 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
Device-1: 1-8.4:9 info: Corsair HS80 MAX WIRELESS Gaming Receiver
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 5
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA
chip-ID: 1b1c:0a97 class-ID: 0300 serial: <filter>
Hub-5: 1-10:7 info: Alcor Micro USB Hub ports: 4 rev: 2.0
Device-1: 1-10.4:13 info: Cooler Master HAF700 type: HID
driver: hid-sensor-hub,usbhid interfaces: 2 rev: 2.0
chip-ID: 2516:01c1 class-ID: 0300 serial: <filter>
Device-2: 1-11:10 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
serial: <filter>
Device-3: 1-14:12 info: Intel AX211 Bluetooth type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-6: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
Hub-7: 2-7:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
Hub-8: 2-8:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
Device-1: 2-8.2:5 info: SanDisk Extreme 55AE type: mass storage
driver: uas interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:55ae class-ID: 0806
serial: <filter>
Device-2: 2-8.3:4 info: SanDisk Ultra Flair type: mass storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5591 class-ID: 0806
serial: <filter>
Hub-9: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-10: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 37.0 C mobo: 36.0 C gpu: nvidia temp: 30 C
Fan Speeds (rpm): fan-1: 0 fan-2: 745 fan-3: 0 fan-4: 0 fan-5: 0
fan-6: 4530 fan-7: 0 gpu: nvidia fan: 0%
Packages: 1774 pm: pacman pkgs: 1712 libs: 464 tools: pamac,yay pm: flatpak
pkgs: 62
1: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
2: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
3: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
4: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
6: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 627
1: cpu: 100% command: ps pid: 48152 mem: 3.76 MiB (0.0%)
2: cpu: 26.1% command: librewolf pid: 2295 mem: 133.6 MiB (0.2%)
3: cpu: 23.1% command: librewolf pid: 2192 mem: 729.9 MiB (1.1%)
4: cpu: 22.7% command: librewolf pid: 33770 mem: 1098.7 MiB (1.7%)
5: cpu: 13.4% command: dolphin pid: 32929 mem: 222.5 MiB (0.3%)
Memory top: 5 of 627
1: mem: 1102.0 MiB (1.7%) command: plasmashell pid: 1578 cpu: 5.8%
2: mem: 1098.7 MiB (1.7%) command: librewolf pid: 33770 cpu: 22.7%
3: mem: 729.9 MiB (1.1%) command: librewolf pid: 2192 cpu: 23.1%
4: mem: 644.1 MiB (1.0%) command: librewolf pid: 37638 cpu: 1.1%
5: mem: 519.0 MiB (0.8%) command: baloo_file_extractor pid: 2072 cpu: 0.1%
Processes: 627 Power: uptime: 3h 33m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.96 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.38
journalctl -f INT ✘ 2m 16s
Mai 18 19:04:09 miho rtkit-daemon[1497]: Supervising 4 threads of 2 processes of 1 users.
Mai 18 19:04:24 miho NetworkManager[1175]: <warn> [1747587864.3988] device (wlp0s20f3): no secrets: No agents were available for this request.
Mai 18 19:04:24 miho NetworkManager[1175]: <info> [1747587864.3989] device (wlp0s20f3): state change: need-auth -> failed (reason 'no-secrets', managed-type: 'full')
Mai 18 19:04:24 miho NetworkManager[1175]: <info> [1747587864.4204] device (wlp0s20f3): set-hw-addr: set MAC address to 3E:9F:CC:27:F5:7A (scanning)
Mai 18 19:04:24 miho NetworkManager[1175]: <warn> [1747587864.4223] device (wlp0s20f3): Activation: failed for connection 'REVAL D'
Mai 18 19:04:24 miho NetworkManager[1175]: <info> [1747587864.4226] device (wlp0s20f3): state change: failed -> disconnected (reason 'none', managed-type: 'full')
Mai 18 19:04:24 miho NetworkManager[1175]: <info> [1747587864.4715] device (wlp0s20f3): supplicant interface state: inactive -> disconnected
Mai 18 19:04:24 miho NetworkManager[1175]: <info> [1747587864.4716] device (p2p-dev-wlp0s20f3): supplicant management interface state: inactive -> disconnected
Mai 18 19:04:24 miho NetworkManager[1175]: <info> [1747587864.4767] device (wlp0s20f3): supplicant interface state: disconnected -> inactive
Mai 18 19:04:24 miho NetworkManager[1175]: <info> [1747587864.4768] device (p2p-dev-wlp0s20f3): supplicant management interface state: disconnected -> inactive
Mai 18 19:04:46 miho plasmashell[1578]: qt.qml.signalhandler: Property 'onPressed' of object QQuickMouseArea_QML_107(0x5828f36d5090) is a signal handler. You should not call it directly. Make it a proper function and call that or emit the signal.
Mai 18 19:04:46 miho NetworkManager[1175]: <info> [1747587886.5372] audit: op="statistics" interface="eno2" ifindex=2 args="2000" pid=1578 uid=1000 result="success"
Mai 18 19:04:49 miho NetworkManager[1175]: <info> [1747587889.6288] device (wlp0s20f3): Activation: starting connection 'REVAL D' (181b3ee1-da23-4730-b01e-1c61aa37fde1)
Mai 18 19:04:49 miho NetworkManager[1175]: <info> [1747587889.6289] audit: op="connection-activate" uuid="181b3ee1-da23-4730-b01e-1c61aa37fde1" name="REVAL D" pid=1578 uid=1000 result="success"
Mai 18 19:04:49 miho NetworkManager[1175]: <info> [1747587889.6290] device (wlp0s20f3): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
Mai 18 19:04:49 miho NetworkManager[1175]: <info> [1747587889.6611] device (wlp0s20f3): set-hw-addr: reset MAC address to C8:5E:A9:8F:5A:D4 (preserve)
Mai 18 19:04:49 miho NetworkManager[1175]: <info> [1747587889.6643] device (wlp0s20f3): state change: prepare -> config (reason 'none', managed-type: 'full')
Mai 18 19:04:49 miho NetworkManager[1175]: <info> [1747587889.6647] device (wlp0s20f3): Activation: (wifi) access point 'REVAL D' has security, but secrets are required.
Mai 18 19:04:49 miho NetworkManager[1175]: <info> [1747587889.6647] device (wlp0s20f3): state change: config -> need-auth (reason 'none', managed-type: 'full')
Mai 18 19:04:49 miho kded6[1557]: org.kde.plasma.nm.kded: GetSecrets was called again! This should not happen, cancelling first call "/org/freedesktop/NetworkManager/Settings/38" "802-11-wireless-security"
Mai 18 19:06:49 miho NetworkManager[1175]: <warn> [1747588009.6804] device (wlp0s20f3): no secrets: No agents were available for this request.
Mai 18 19:06:49 miho NetworkManager[1175]: <info> [1747588009.6806] device (wlp0s20f3): state change: need-auth -> failed (reason 'no-secrets', managed-type: 'full')
Mai 18 19:06:49 miho NetworkManager[1175]: <info> [1747588009.7191] device (wlp0s20f3): set-hw-addr: set MAC address to 36:AC:71:35:34:C4 (scanning)
Mai 18 19:06:49 miho NetworkManager[1175]: <warn> [1747588009.7206] device (wlp0s20f3): Activation: failed for connection 'REVAL D'
Mai 18 19:06:49 miho NetworkManager[1175]: <info> [1747588009.7208] device (wlp0s20f3): state change: failed -> disconnected (reason 'none', managed-type: 'full')
