Problemas de audio en mi Dell Inspiron N4110
Buen día, no he podido hacer que funcione el micrófono de mi Diadema al conectar los dos cables 3.5 mm. en la Laptop, solamente escucho, pero no me reconoce el micrófono.
Soy digamos que novato, pero puedo seguir instrucciones para ejecutar en la terminal.
Gracias por su tiempo.
System: Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=adfe44a1-25d0-449c-8377-44759bb9f874 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3 Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Manjaro Linux base: Arch Linux Machine: Type: Portable System: Dell product: Dell System Inspiron N4110 v: N/A serial: <filter> Chassis: type: 8 v: 0.1 serial: <filter> Mobo: Dell model: 05TM8C v: A00 serial: <filter> UEFI-[Legacy]: Dell v: A12 date: 09/07/2012 Battery: ID-1: BAT0 charge: 15.2 Wh (100.0%) condition: 15.2/48.8 Wh (31.1%) volts: 12.4 min: 11.1 model: SIMPLO Dell type: Li-ion serial: <filter> status: Full CPU: Info: Dual Core model: Intel Core i3-2310M bits: 64 type: MT MCP arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F cache: L2: 3 MiB flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 16755 Speed: 798 MHz min/max: 800/2100 MHz Core speeds (MHz): 1: 798 2: 853 3: 809 4: 834 Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable Type: mds mitigation: Clear CPU buffers; SMT vulnerable Type: meltdown mitigation: PTI Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling Type: srbds status: Not affected Type: tsx_async_abort status: Not affected Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0116 class-ID: 0300 Device-2: Sunplus Innovation Dell HD Webcam type: USB driver: uvcvideo bus-ID: 1-1.4:4 chip-ID: 1bcf:2880 class-ID: 0e02 Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver: loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0 resolution: <missing: xdpyinfo> OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 21.1.6 compat-v: 3.0 direct render: Yes Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403 Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes Sound Server-2: JACK v: 1.9.19 running: no Sound Server-3: PulseAudio v: 15.0 running: yes Sound Server-4: PipeWire v: 0.3.33 running: no Network: Device-1: Intel Centrino Wireless-N 1030 [Rainbow Peak] driver: iwlwifi v: kernel port: efa0 bus-ID: 01:00.0 chip-ID: 8086:008a class-ID: 0280 IF: wlp1s0 state: down mac: <filter> Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200 IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter> Bluetooth: Device-1: Intel Centrino Advanced-N 6230 Bluetooth adapter type: USB driver: btusb v: 0.8 bus-ID: 2-1.5:4 chip-ID: 8086:0189 class-ID: e001 Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends Drives: Local Storage: total: 111.79 GiB used: 14.17 GiB (12.7%) SMART Message: Required tool smartctl not installed. Check --recommends ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37120G size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0007 scheme: MBR Partition: ID-1: / raw-size: 111.79 GiB size: 109.47 GiB (97.93%) used: 14.17 GiB (12.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 Swap: Alert: No swap data was found. Sensors: System Temperatures: cpu: 58.0 C mobo: 40.0 C sodimm: SODIMM C Fan Speeds (RPM): cpu: 0 Info: Processes: 234 Uptime: 1h 39m wakeups: 1 Memory: 7.66 GiB used: 2.85 GiB (37.2%) Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1138 lib: 294 flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
Hola @TeacherdhApps ,
Bienvenido al foro!!
He buscado en la salida que has publicado algún problema, de la salida del comando de terminal inxi no encuentro nada apreciable.
Tal vez puedas leer el siguiente vínculo e incluir alguna información adicional.
https://forum.manjaro.org/t/how-to-provide-good-information
Salida del comando inxi
<filter>
Saludos
Aquí está en un modo más presentable tu salida de inxi, intenta ponerlo así la próxima vez :slight_smile:
Summary
            base: Arch Linux
            bogomips: 16755
            Type: spectre_v2
            scheme: MBR
En la última actualizacion estable del día de hoy sugieren que si tienes problemas con Pulseaudio 15 pruebes el siguiente comando desde la terminal.
rm ~/.config/pulse/*.tdb ~/.config/pulse/cookie
Para saber qué versión de Pulseaudio estás utilizando puedes ejecutar el comando en la terminal:
pulseaudio --version
Espero que te ayude, saludos.
Buen día, gracias por su tiempo. Me regresa el siguiente mensaje la terminal.
‘’‘zsh: no matches found: /home/junior/.config/pulse/*.tdb’’’
