Hola, instalé la actualización quitando el paquete wxgtk2 y sus dependencias, y por lo que experimento afecta a veracrypt, que he actualizado, removido y vuelvo a instalar.
/build/wxwidgets/src/wxWidgets-3.2.0/src/common/sizer.cpp(2288): assert "CheckSizerFlags(!((flags) & (wxALIGN_RIGHT | wxALIGN_CENTRE_HORIZONTAL | wxALIGN_BOTTOM | wxALIGN_CENTRE_VERTICAL)))" failed in DoInsert(): wxALIGN_RIGHT | wxALIGN_CENTRE_HORIZONTAL | wxALIGN_BOTTOM | wxALIGN_CENTRE_VERTICAL will be ignored in this sizer: wxEXPAND overrides alignment flags in box sizers
DO NOT PANIC !!
If you're an end user running a program not developed by you, please ignore this message, it is harmless, and please try reporting the problem to the program developers.
You may also set WXSUPPRESS_SIZER_FLAGS_CHECK environment variable to suppress all such checks when running this program.
If you're the developer, simply remove this flag from your code to avoid getting this message. You can also call wxSizerFlags::DisableConsistencyChecks() to globally disable all such checks, but this is strongly not recommended.
ASSERT INFO:
DO NOT PANIC !!
BACKTRACE:
[1] wxBoxSizer::DoInsert(unsigned long, wxSizerItem*)
[2] wxEntry(int&, wchar_t**)
[3] __libc_start_main
