Hola , buen día, en verdad tengo problemas para instalar transcode ya sea desde la Terminal o desde el instalador gráfico, siempre me da error.
Alguna solución a esto?,es de mucha importacia este software? , estimo que si, ya que no puedo utilizar Clam Tk(antivirus) , sujeto probablemente a transcode .
Muchas gracias !!!
Kernel: 6.7.0-0-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
root=UUID=0fb091fc-3271-483e-818a-5dc21ccbd08d rw quiet apparmor=1
security=apparmor resume=UUID=e4ab7b14-ec9e-4155-b5eb-28717df67c17
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.113.0 wm: kwin_x11 tools: xscreensaver,xscreensaver-systemd vt: 2
Type: Laptop System: Dell product: Latitude 3420 v: N/A
Mobo: Dell model: 0KMD3M v: A00 serial: <superuser required> part-nu: 0A7B
uuid: <superuser required> UEFI: Dell v: 1.3.1 date: 04/23/2021
ID-1: BAT0 charge: 26.7 Wh (65.4%) condition: 40.8/40.8 Wh (100.0%)
volts: 11.2 min: 11.2 model: SMP DELL MGCM514 type: Li-poly serial: <filter>
status: discharging
Device-1: hidpp_battery_0 model: Logitech M350 Wireless Mouse
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: N/A
System RAM: total: 12 GiB available: 11.43 GiB used: 4.45 GiB (38.9%)
Device-1: DIMM 1 type: DDR4 detail: synchronous size: 8 GiB
speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: 0198000080AD part-no: 9905700-053.A00G serial: <filter>
Device-2: DIMM 2 type: DDR4 detail: synchronous size: 4 GiB
manufacturer: 01980000802C part-no: KCDT82-MIE serial: <filter>
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 400 min/max: 400/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 bogomips: 22120
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid x2apic
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3 chip-ID: 0c45:6d1a
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x07e8 built: 2019 res: 1366x768 hz: 60
dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 11.17 GiB unified: yes
API: Vulkan v: 1.3.274 layers: 4 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 23.3.3-manjaro1.1
device-ID: 8086:9a49 surfaces: xcb,xlib
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.7.0-0-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active
tools: pactl,pw-cat,pw-cli
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
vendor: Dell driver: r8169 v: kernel pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s port: 3000 bus-ID: 2c:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp44s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 1.36 TiB used: 64.13 GiB (4.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EDFK0N01 temp: 32.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 01 scheme: GPT
ID-1: / raw-size: 78.12 GiB size: 76.35 GiB (97.73%) used: 35.57 GiB (46.6%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 0fb091fc-3271-483e-818a-5dc21ccbd08d
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 1C6D-8153
ID-3: /home raw-size: 381.48 GiB size: 374.43 GiB (98.15%)
used: 28.56 GiB (7.6%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: ae4fdda7-02c7-4b07-847d-0ca5d01636a3
ID-1: swap-1 type: partition size: 5.86 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: e4ab7b14-ec9e-4155-b5eb-28717df67c17
ID-1: /dev/sda1 maj-min: 8:1 size: 1000 MiB fs: vfat label: N/A
uuid: 7616-A725
ID-2: /dev/sda2 maj-min: 8:2 size: 921.73 GiB fs: ext4 label: endeavouros
uuid: c5836b3c-5bb7-4d47-8d49-56202845d398
ID-3: /dev/sda3 maj-min: 8:3 size: 8.8 GiB fs: swap label: swap
uuid: 0a93cecb-4ed9-4925-aff6-72849d60ff7e
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-4:2 info: Logitech Unifying Receiver type: mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c52f class-ID: 0300
Device-2: 3-6:3 info: Microdia Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0c45:6d1a class-ID: 0e02
Device-3: 3-10:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
System Temperatures: cpu: 30.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 272 Power: uptime: 1h 19m states: freeze,mem,disk suspend: s2idle
wakeups: 0 hibernate: platform avail: shutdown,reboot,suspend,test_resume
image: 4.56 GiB daemons: upowerd,org_kde_powerdevil Init: systemd v: 255
Packages: 1524 pm: pacman pkgs: 1507 libs: 439 tools: pamac,yay pm: flatpak
pkgs: 17 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.21 running-in: konsole inxi: 3.3.32
